Old 11-08-2005, 01:04 PM   #1
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
Default Car can't even hit 3k rpms
I've got problems...I have no clue what it is. No CEL's. But when I'm accelerating right before 3000 the car just stops going, it stops accelerating and almost dies.
Some things you should know. I'm at the end of a long clutch install. I'm running an open downpipe. The downpipe isn't bolted on all the way, only the three nuts at the bottom. I lost the bolts but it's just temporary, I'm going to the hard ware store this afternoon.
I just had an oil leak fixed at a mechanics. No more leaks apart from a busted axle seal on the transmission. The transmission fluid is at the low mark and holding steady. I don't think the coolant is as full as it should be. There's a possibility that it's low. My temp gauge is holding steady in the middle.
icantdrive75 is offline   Reply With Quote
Old 11-08-2005, 01:07 PM   #2
boost4life
Member#: 75129
09 WRX stg 2+
Lost the boxer rumble
running any EM??
boost4life is offline   Reply With Quote
Old 11-08-2005, 01:14 PM   #3
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
Yea sorry.
Mods: Cobb AP Stg 2 Map
TurboXS stealthback, catless, open after the race pipe, Rear O2 unplugged
HKS Uppipe
Exedy Flywheel and Organic Clutch
Car was running fine before the clutch install other than the clutch slipping.
Old 11-08-2005, 01:20 PM   #4
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
And I plugged the EGT gauge in the upppipe. I was gonna put it in, but I couldn't even get it out of the old uppipe. It's still in the old one...not plugged in.
Old 11-08-2005, 01:46 PM   #5
lowblow
Member#: 56902
2009 VW Jetta SE
Is the car in valet mode with the Cobb EM?
lowblow is offline   Reply With Quote
Old 11-08-2005, 01:49 PM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
First thing I thought of too. Try reflashing the realtime map to stage 2 again...just going in to 'view current map' won't show what realtime map is running.
waktasz is offline   Reply With Quote
Old 11-08-2005, 01:51 PM   #7
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
Alright. Although I thought the cut was a soft one at 4k. This one is kinda gradual then it feels like a hard fuel cut at 3k.
Old 11-08-2005, 05:01 PM   #8
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
Intercooler popped off. Forgot the mount bolts.
Old 11-08-2005, 05:07 PM   #9
lowblow
Member#: 56902
2009 VW Jetta SE
(you should change your SN to icantinstallparts)
Sorry...glad it was an easy fix
Old 11-08-2005, 05:11 PM   #10
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
hahahaha that's so true.
Old 11-08-2005, 05:42 PM   #11
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
Plug your rear O2 sensor back in...AP does a CEL fix.
J-Rex2004 is offline   Reply With Quote
Old 11-08-2005, 05:44 PM   #12
icantdrive75
Member#: 69663
2004 WRX
Java Black Pearl
It's plugged in...I just haven't put it in the exhaust yet. I will though.
Can't even tell I hit the deer... alottaboost Mid Atlantic Impreza Club -- MAIC 11 01-28-2008 03:15 PM
Car clicks when driving in 1st gear at 2-3k rpm? em199si Brakes, Steering & Suspension 8 10-23-2005 07:51 PM
Car hesitates above 3K rpms SIMPFLY Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-02-2004 08:20 PM
car has nothing under 3k RPMs, and when it passes it bucks... Keith Service & Maintenance 5 09-29-2003 07:14 PM
my stage 4 txs car builds boost at 3k and doesn't hit full boost till 4100 rpm?? datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-25-2003 11:35 AM
