Old 11-07-2005, 09:59 PM   #1
Tigris
Member#: 44589
Default semi newb-wrx longblock into 99 2.5
Thought I'd ask this here because you afi guys might have looked into this. I have a blown motor and wanted to just swap a usdm wrx longblock in, but trying to avoid the whole wiring/plumbing headaches. Is the cam sensor different? I woul use an aftermarket ecu, bu What else. Thanks
Tigris is offline   Reply With Quote
Old 11-08-2005, 01:20 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
conversions forum?
As far as i know you are going to HAVE to do the wiring headache, one way or another. Either aftermarket ECU with your own custom wiring harness for everything, or getting a wrx harness modified with yours. I'd suggest the second one as you can pay someone to do up the harnesses for you. Then you can use an aftermarket ecu made for a WRX.
Master2192 is offline   Reply With Quote
Old 11-14-2005, 10:58 PM   #3
blaznc
Member#: 41862
0000 99L 2.2T, dead
93 Wagon 1.8L of fury!!
swap the shortblock, keep your heads, and cam/crank sensor, no wiring probs....
blaznc is offline   Reply With Quote
WRX swap into GD 2.5 TS nismo4life Subaru Conversions 2 10-08-2008 03:53 PM
07 WRX Transmission into 01 2.5 RS talon2.5RS Transmission (AT/MT) & Driveline 5 10-02-2008 05:58 PM
WTB: 99 2.5 RS longblock Iheartsubarus NESIC Private Classifieds 3 07-03-2007 02:56 PM
WRX seats into a 2.5 RS SneakyD Interior & Exterior Modification 13 12-03-2005 09:24 AM
02 Wrx Swap Into A 99 2.5 Rs What Cani Use What Cant I GODSON Subaru Conversions 10 10-12-2004 03:56 PM
Message Board Statistics All times are GMT -4. The time now is 01:49 PM.
