Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 11-08-2005, 09:50 PM   #1
Member#: 100289
Default 1984 gl clutch repalcement
Hey im new to subarus and the board but im getting my first subaru tomorrow its a 1984 gl 4wd with 174,000 for $100. The clutch is out and i was wondering if you have to take out the motor to replace it or can you just drop the trans?
Also any helpful tips and general directions would be great.
thanks jacob.
dentedfender is offline   Reply With Quote
Old 11-18-2005, 06:08 AM   #2
Member#: 96964
1969 360/1987 gl 4wd
Good buy.
Don't worry about replacing the clutch, as long as you put it in neutral and RPM match the gears, you can shift it without using the clutch...
- OR -
you can just loosen the motor mounts, move the engine a little bit, and drop the tranny. It's easy, I did it on my 83 gl wagon in a matter of hours. There is this stabilizer bar that you have to loosen in order to angle the motor so the tranny can be separated from it, but other than that the engine can be left alone.
congrats on your purchase, my 83 would still be on the road today (w/ over 350,000mi) if it wasn't for some jackass who didn't know how to check his blind spot.
good luck!
cocheeze is offline   Reply With Quote
Old 11-19-2005, 01:56 AM   #3
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
Its not too hard to drop a tranny, just make sure you have good jackstands.
Personally I like to yank the engine to do clutch jobs. THen again something like a timing belt job on my cars ends up as a several hundred dollar ordeal with belts, water pumps, seals and everything that I can replace while I have the engine out and on the engine stand.
Flowmastered87GL is offline   Reply With Quote
Distributor for 1984 gl 4wd privateer 'Old School' Subaru Forum 1 07-14-2006 10:30 AM
1984 gl wagon dies for no reason?? twitch88 'Old School' Subaru Forum 3 11-20-2005 10:46 PM
1984 gl clutch replacement please help dentedfender Transmission (AT/MT) & Driveline 1 11-09-2005 10:44 PM
Low power in 1984 GL 10 ?? NitrouStang96 'Old School' Subaru Forum 8 08-04-2004 10:12 AM
Low power in 1984 GL 10? NitrouStang96 Normally Aspirated Powertrain 3 08-01-2004 12:33 AM
