Old 04-19-2012, 02:53 AM   #1
Latteral
Member#: 317351
Default Stock 05 low power under load, poor mpg's
Hello, I'm new to the forum but have owned several wrx's.
Car: Stock 2005 wrx, 60k miles
Problem: Low power, also getting poor fuel economy. When I go to wot from normal driving engine noise becomes very deep and low sounding and the car responds very sluggishly.Also, I am not sure this is related but there is an ticking noise coming from the engine bay that becomes louder when the clutch is released, it is constant during normal driving. No cels have came on.
Checked so far: replaced plugs, air filter. Compression test. I also took it to the dealership, they said the mechanic did not find anything.
I've had the car for about 3 months and it is still covered by warranty (just). Any thoughts that you have would be appreciated.
Latteral is offline   Reply With Quote
Old 04-19-2012, 03:49 AM   #2
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
I feel like I need more information to give any feedback that might help you.
When you say you go wot from normal driving, is that crusing at 40mph in 4th gear and you punch it ? or 40mph in 3rd ? We need to know what mph and what gear your in to give any feedback here.
What were the results of your compression test ?
Get a boost leak test done, or do one yourself if you have access to an air compressor and have some spare change to make a tester.
And to address the ticking noise, I have the same symptom at idle. When I press my clutch pedal at a stop light the ticking noise gets quieter. I did my own clutch job with an ebay exedy organic material clutch but it hasn't effected my performance at all, and my clutch holds power just like it should.
04wrxhart is offline   Reply With Quote
Old 04-19-2012, 09:14 AM   #3
Latteral
Member#: 317351
I guess a better description of the problem would be, under rapid increase of the throttle the symptoms occur. So to answer your question, it would occur in both cases. The compression ranged from 138 - 145psi. I have checked the boost at wot and it seems to be steady at around 15psi. I will run a boost leak test this weekend just to check. Thanks for the advice.
Old 04-19-2012, 09:27 AM   #4
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
buy a wideband so you know your afr's. its the first thing every subaru owner should buy. no excuses. that way you can get it tuned if needed plus monitor if your running rich as hell or lean/
WhiteBgeye02 is offline   Reply With Quote
Old 04-19-2012, 10:07 AM   #5
Brock31
Member#: 128115
2004 4EAT Wagon PSM
enginuity is cool
Check all connections around your intercooler to the throttle body.
Brock31 is offline   Reply With Quote
Old 04-19-2012, 10:36 AM   #6
wrxlaunch
Member#: 181298
Sounds like u need to downshift... If u punch it at 40 in 4th... It's not gonna get up n go my friend and at the same speed in 3rd it might start to pick up but not a rapid pull
wrxlaunch is offline   Reply With Quote
Old 04-19-2012, 12:21 PM   #7
Latteral
Member#: 317351
Angry
Thanks for the suggestions everyone. I will try them out this weekend and let you know how it turns out. As far as the downshifting comment, not very helpful, if you read the previous reply you would see that the poor pick up occurs at any rpm range, and is only dependent on the change in throttle position.
Old 04-19-2012, 10:42 PM   #8
jsquared
Member#: 212052
2005 STi
My first guess would also be a minor boost leak.
jsquared is offline   Reply With Quote
Old 04-20-2012, 07:24 AM   #9
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
+1/2 the other 1/2 is it is stock, needs more power and a tune
Old 04-20-2012, 04:32 PM   #10
wag22bl
Member#: 317545
i have had this problem before it could be lots of things. in my case it was loose spark plugs, engine sounded deeper, low throttle response loss of power and gas milage.
wag22bl is offline   Reply With Quote
Old 04-20-2012, 08:39 PM   #11
Haelan
Member#: 151045
2013 Subaru STI
CBP
I'll bet money it is a clogged catalytic converter. If you can ease it up the throttle with no issues, but not rapidly, that is a dead giveaway.
Haelan is offline   Reply With Quote
Old 04-23-2012, 09:27 PM   #12
Latteral
Member#: 317351
I was able to do a boost leak test yesterday and on the first attempt the black and tan valve running from the intake to the EGR made a loud buzzing noise. After I plugged that line the system held 10 psi for quite a while before I released the pressure. However, I did notice some oil on the inlet tube on the cold side of the turbo. I pulled off the intercooler and found standing oil in the portion of intake running from the outlet of the cold side to the intercooler. Im not sure if this is common or something to be concerned about. As far as the clogged catalytic converter, I am not sure how to check this apart from visual inspection. Thanks again for the input.
Old 04-23-2012, 10:25 PM   #13
Fehnix
Member#: 300587
02 wrx wagon ej207
time for a new turbo
Fehnix is offline   Reply With Quote
Old 04-24-2012, 07:23 PM   #14
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
I agree. The 05's seemed to have a problem with it. Mine broke loose early on and I had it replaced. Then I removed it entirely. As it clogs the uppipe, your engine starts to work harder for less flow increasing the strain on the engine, decreasing mpgs.
WRXSD is offline   Reply With Quote
Old 04-27-2012, 04:17 PM   #15
Omega_2nr
Member#: 298119
Did the OP have this resolved? Sounds like the front O2 sensor might be on its way out.
Omega_2nr is offline   Reply With Quote
Very faint ticking/knocking sound at low RPM under load Dr. Ninja Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 117 05-30-2016 05:32 PM
Studdering and Loss of power under load - P0031 only code...help!!! turbobird14 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-15-2011 08:16 PM
Low power under 3k rpms? ae5eem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-10-2011 09:36 PM
ticking low rpm under load Toadfart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 11-02-2010 01:04 PM
No power under load Vacca Rabite Normally Aspirated Powertrain 5 09-30-2010 11:05 PM
