Old 09-22-2006, 01:03 PM   #76
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Originally Posted by nhluhr View Post
dunno how many times this needs to be said, but YES it IS 2". You don't put it over it, you jam it inside. The reason is because you'll be pressurizing it. If you put it over the inlet, it will expand and blow itself off. If you put it inside the inlet, it will expand and seal itself tighter.
And I don't know how many times to say this. You are mistaken. You now have two people reporting the same issue. 2" nets the exact SAME outer diameter as the stock intake on my 2003 and now his 2002.
I swear to god man, you get an idea in your head and we need a bulldozer to get it out.
Valhakar is offline   Reply With Quote
Old 04-04-2007, 10:32 AM   #77
Robstunner
Member#: 134222
2015 WRX Limited
ISM
Originally Posted by jdgrimm View Post
ok. so i build this exact setup tonight and i couldnt get any psi when i tried to fill it up. i didnt know how much to put it but i one point i probably pumped in 20-30 seconds worth of air and it didnt even read anything. i just took the airbox off and hooked it up to my turbo inlet and gave it a whirl.
anyone have any ideas?
sorry to bump an old thread...
but i have this same problem and this leak is pissing me off hardcore
Robstunner is offline   Reply With Quote
Old 04-04-2007, 01:09 PM   #78
jcl
Member#: 132215
06 Mitsubishi Evo
Wicked White
Thinking about doing this but since I have a FMIC plugging it into the Turbo Output to test the intercooler piping.
Hoping I dont have to pull off the bumper to fix a leak.
jcl is offline   Reply With Quote
Old 04-04-2007, 11:44 PM   #79
decaman
Member#: 73055
04 STi
What did you guys use to plug the three nipples on the turbo inlet?
decaman is offline   Reply With Quote
Old 04-18-2007, 09:25 PM   #80
b0dh1
Member#: 35269
2011 WRX
I was able to run the test but the air was coming straight out of the exhaust. This is with the fitting in the turbo inlet, capped off the fittings, capped off the intercooler piping at the throttle body coupler.
I could sit there and constantly run air through and it would not compress. I sat down by the exhaust and absolutely heard air coming out. What does it all mean?
b0dh1 is offline   Reply With Quote
Old 04-18-2007, 10:28 PM   #81
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I think it's possible that all engines stop in the same positions, most of the time. It can be that in the WRX a position is with one of the cylinders having intake and exhaust valves open.
Old 04-18-2007, 10:37 PM   #82
b0dh1
Member#: 35269
2011 WRX
I don't think that's possible since I capped off before the throttle body.
Old 04-18-2007, 10:54 PM   #83
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Look, if there was no physical connection between the air supply and the engine (you disconnected and caped everything), then I don't know see how the air got into the exhaust. It would have to travel from the compressor housing into the turbine housing.
Old 04-18-2007, 11:05 PM   #84
b0dh1
Member#: 35269
2011 WRX
It seems that way doesn't it? That's why I'm posting about it. I'm ******* LOST!
It's like this...air into the turbo inlet, capped all 4 connections on that, including the bpv hose. Capped the throttle coupler at the throttle body. At that point I was thinking I would strictly be testing the intake system since everything else was bypassed but somehow the air won't compress and comes right out the exhaust. I had sure I could hear the air coming, going, coming, going, etc as he fed it.
Old 04-18-2007, 11:10 PM   #85
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
Was everything cold? Try to separate the turbo, that would confirm the finding. Did you also cap the compressor boost pickup nipple?
Old 04-18-2007, 11:14 PM   #86
b0dh1
Member#: 35269
2011 WRX
Yeah everything was completely cold. Car hasn't ran since Tuesday.
I got mad and ripped it apart. The turbo is out and sitting on the work bench.
Tomorrow I'm going to swap my TD04 back in and see if that does anything.
Far from the easiest way to diagnose but I was mad and something is telling me it's the turbo.
Old 04-19-2007, 08:13 AM   #87
187
Member#: 51427
I am having a real hard time sourcing the parts especially the rubber cap......can anyone post an internet link to somewhere that has them?
187 is offline   Reply With Quote
Old 04-19-2007, 08:33 AM   #88
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
It's weird. If the prosibility exists for a leak between compressor and turbine, probably the exhaust would come into the compressor, there's more pressure there.
Otherwise, the leak would have to be in the wastegate area.
I havent' heard of this from other forums, maybe it's a TD04 problem?
Old 04-19-2007, 06:32 PM   #89
b0dh1
Member#: 35269
2011 WRX
I'm running a VF23. What would be the best way to test the wastegate while the turbo is out of the car?
Old 04-20-2007, 07:12 PM   #90
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
This may sound stupid, but hook up the air supply to intake side of the compressor and maybe try to close the outlet with your palm. I think that this way you won't do dammage because you'll just use your judgement.
Obviously, a leak will be heard on the exhaust (turbine) side.
I got the idea from the days when I was cleaning carburetors by reving and chocking the carburetor intake with my palm.
Old 07-17-2007, 05:13 PM   #91
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
subbed for future reference!
aps2fast4u is offline   Reply With Quote
Old 07-23-2007, 04:46 AM   #92
bodyboarder050
Member#: 145425
Chapter/Region: HIIC
im gonna try make this tommarrow.. hopefully it will get me out of "limp" mode !!!! i think i have been running on wastegate since the dealership sold me the car.. bastards..
bodyboarder050 is offline   Reply With Quote
Old 07-23-2007, 11:00 AM   #93
Sooby-Doo
Member#: 147350
'03 2.5/2.0L Hybrid
308hp/320tq
Yo Erick,
Did you ever do this? Do you have a pressure tester. This not hitting full boost is really getting to me. I replaced all the vac lines in the car so the leak, if there is one, must be coming from somewhere else.
Wanna help me figure it out?
Sooby-Doo is offline   Reply With Quote
Old 08-14-2007, 12:22 AM   #94
1bugeyedrex
Member#: 145684
06 WRX STi
White/Gold
so.... what size pvc piping should I get for the stock inlet hose???
1bugeyedrex is offline   Reply With Quote
Old 08-14-2007, 02:58 AM   #95
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Originally Posted by athakur999 View Post
That's pretty neat. Now someone make something like this for the exhaust side
it can be done motor would have to be @ TDC
spoolinsti05 is offline   Reply With Quote
Old 08-14-2007, 03:00 AM   #96
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Originally Posted by Sooby-Doo View Post
Yo Erick,
mske sure your boost gauge goes right to your Manifold with no T off's in the vac hoses if there is it wont be a correct boost reading.
Old 08-14-2007, 03:00 AM   #97
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Yo Erick,
also check the stock turbo inlet when i took mine off the clamp was lose where it clamped to the turbo.
Old 08-14-2007, 08:19 AM   #98
1bugeyedrex
Member#: 145684
06 WRX STi
White/Gold
Old 08-14-2007, 10:48 AM   #99
imprezawrx1212
Member#: 117991
is it necessary to plug the ventilation ports on the inlet to perform this test?
imprezawrx1212 is offline   Reply With Quote
Old 08-22-2007, 10:59 PM   #100
GlobalWaste
Member#: 74792
Bump for an answer to this... I tried duct tape, but air leaked through it
GlobalWaste is offline   Reply With Quote
This just in - the War on Drugs is a complete failure FightingFalcon Political Playground 2753 01-09-2016 02:24 PM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
Swap complete, just lost the clutch! SJwrx Pre-2002 Factory Turbo Powertrain 9 05-08-2010 01:56 AM
The longest lasting DIY paint your wheels thread chimchimm5 Tire & Wheel 1 04-03-2010 01:26 PM
Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. Chandy69 Tri-State Area Forum 13 05-09-2005 05:58 PM
