#126 | |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
Without disconnecting PCV valve, you will blow the cam seal. Do not perform DIY leak check without disconnecting it. Learned my painful lesson the harder way. ![]()
#127 |
Member#: 96448
Vehicle:02 WRX VF34 |
lol ....
#128 |
Member#: 149848
Vehicle:2011 Honda CRZ Performance White Pearl |
This is very good info! I agree that removing the other end of your IC piping may be the way to go, but impossible if you have a TMIC. lol
#129 |
Member#: 2865
NWIC
Vehicle:2006 Legacy 2.5i Wagon, 5MT, Blue |
Here is mine, 2" cap inside an aftermarket inlet hose. Also used a schraeder valve with the rubber ring and a nut that I clamped down enough to seal it from the inside. No glue or anything and worked like a charm:
![]() ![]() Unfortunately, I have a leak before the turbo that I can't seem to fix, due to the Perrin inlet hose not having a very good fit with my recirculation hose: ![]() Anyone else have this problem with the Perrin inlet? I bought mine used, so I'm not sure if I am missing something or what.... |
#130 |
Member#: 32459
I had a leak there also so I ended up using a small clamp there.
#131 |
Member#: 2865
NWIC
Does fixing a leak before the turbo really help that much? Seems like it wouldn't make much of a difference...
#132 | |
Member#: 204111
RMIC
Vehicle:2005 WRX |
I had this problem with my Gimmick inlet hose, and I have the Samco IC set so oddly enough they don't mate up very well. In fact, I'm beginning to become disappointed with even Samco's fitment. Other than the IC hoses, every other Samco hose I've purchased requires trimming with makes the hose look like crap all chopped up on the ends. I'm talking afta-MAF and radiator hoses. |
#133 |
Member#: 204111
RMIC
Vehicle:2005 WRX |
Oh but it does. In fact, I cannot find the source of my post-MAF pre-turbo vacuum leak, despite many leak tests.... this is causing my car to run "lean" and my car keeps trying to add fuel to make up for it. Lean = no bueno beans for muchacho me. Sucks.
#134 |
Member#: 32459
I doubt leak post-MAF pre-turbo vacuum leak will cause car to run lean unless it's one major leak...
1. turbo inlet to turbo connection 2. turbo inlet to BPV hose connection 3. torn turbo inlet |
#135 |
Member#: 2865
NWIC
Well the issue I am having is related to boost pressure. I have JDM V7 STi engine with a VF30 turbo. After my swap I was running 17psi (stock boost) consistently until I installed the Perrin inlet hose. After that I was only hitting wastgate boost, which I found out was because I had thrown away the hose from the wastegate T with the "pill" in it. Fixed that, but now I only boost to 10psi in first, 13psi in 2nd, and about 15psi in 3rd. I never had an issue with this until I installed the inlet hose, so I figure something has to be off.
#136 | |
Member#: 204111
RMIC
Vehicle:2005 WRX |
You should see the guys over at RomRaider. They all swear to God that's my problem. My AF trims are a little out of whack. If I had it their way, I would continue to keep throwing new parts at my car. Maybe my MAF just needed scaling. Who knows. Still can't figure it out. And yes, I've checked those connections. |
#137 |
Member#: 2865
NWIC
What kind of clamp? Got a pic?
I'm going to go to the hardware store at some point and see what I can come up with. Such a PITA to get down in there, but I wouldn't mind the peace of mind knowing that it's got a good clamp on it.... |
#138 |
Member#: 97452
South East
Vehicle:05 STi, 02 STi & 09Ltd Tribeca |
are any of you guys getting a check engine light prior to doing this test. im getting the engine too lean code that is why i think it is an intake leak which would mean im getting unmetered air into the system causing me to run lean. i think im going to try this tonight.
#139 |
Member#: 86822
VIC
Vehicle:2004 WRX PSM |
Tried to do this yesterday but can't get air into the system. Air escapes from the exhaust. I've plugged up the two vacuum lines going to the plunger valve as well and it held a little bit of air. That's as far as I got.
Any ideas? nm. figured it out. The compressor was not large enough. Last edited by jlam86; 10-12-2009 at 03:39 AM. |
#140 |
Member#: 163445
Vehicle:l33t ******* 12.07@115.9mph-EJ205 |
You have to have the engine rotated just right or you will blow air out of the exhaust...
MAKE SURE you disconnect the crank vent system. You will blow seals if not. I just put 25psi into mine and found 2 small leaks at couplings (FMIC) but most importantly proved that I DONT have a blown head gasket/cracked head/blown out cylinder wall. I'm having coolant issues and could not get it to bubble under pressure (only way to test it while sitting still). I can live with a minor leak @ 25psi until my new couplings come in ![]() AGAIN you MUST disconnect the crank vent system and allow it to VTA while doing the test (make sure you plug the intake tract where you disconnected the crank vent, otherwise you will just blow air out of that hole) You WILL do damage if you don't... -Jerod |
#141 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
Or block the hose just before the throttle body.
#142 |
Member#: 78189
Vehicle:2005 Legacy GT Wagon Blue |
Subscribed
#143 |
Member#: 147838
Vehicle:2007 WRX Limited CGM |
just did this today. instead of using the pcv piping I just used a cap from a spray can. drilled a hole in the middle, popped in the tire valve. did the whole thang and bam, leak from the bpv gasket. I don't know bout yall but I got kinda nervous putting so much air pressure in the system. I didn't even get passed 5 psi and I saw the whole inlet (silicon) expanding. changed the gasket..hopefully that gets rid of my P0171 and P1153. usually if I coast at a constant speed/throttle for bout 3 min the CEL will pop up..cruised for like 10 min and nothing yet. crossing my fingers
#144 |
Member#: 240272
South East
Vehicle:2004 WRX White |
#145 |
Member#: 151171
Vehicle:02 Subaru WRX Blue |
Can someone show a pic of exactly what hose to take off? Just take off the hose on the PCV? (wherever that is) sorry...kind of a noobie.
Or just a complete, thourough, step by step write up of how to do this properly? Making the fitting won't be a problem...I just don't want to blow gaskets when I pressurize the system. Search results gave a bazillian responses, but I don't have time to go through them all... |
#146 |
Member#: 201462
Vehicle:~ Daihatsu Charade-Recaro Spec. ED ~ |
Bump for a step by step process. Could be a sticky if someone wants to post the procedure as this is EXTREMELY important.
All the best, MvP |
#147 |
Member#: 229778
Vehicle:04 WRX WR blue |
can someone post me the link to RiftsWRX diy test, i cant find the thread
#148 |
Member#: 201462
#149 |
Member#: 171697
Vehicle:05 WRX EJ205 CGM VF48 20psi |
Here the guide on leak testing from P&L, page 9: http://pandlmotorsports.com/misc/car...ehicle-1.2.pdf
Personally I will not be unhooking PCV, that requires you to take off IC and complicates the leak test. Looks like taking off oil cap should be enough. |
#150 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
I've recently tried again to do this test. I tried to put around 15 PSI into the system, while at the same time turning the crank, to find the pressure position. Still no go for me.
It picks up and holds maybe 2-3 PSI, that's it. Later, I discovered that the purge valve was installed with the arrow in the wrong direction however. I'll try again. |
| Thread Tools | |
| Display Modes | |
| This just in - the War on Drugs is a complete failure | FightingFalcon | Political Playground | 1655 | 05-12-2013 03:33 AM |
| A complete n00b's guide to changing the oil in your WRX (with pics!) | perret318 | Service & Maintenance | 140 | 06-23-2012 12:38 PM |
| Swap complete, just lost the clutch! | SJwrx | Pre-2002 Factory Turbo Powertrain | 9 | 05-08-2010 01:56 AM |
| The longest lasting DIY paint your wheels thread | chimchimm5 | Tire & Wheel | 1 | 04-03-2010 01:26 PM |
| Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. | Chandy69 | Tri-State Area Forum | 13 | 05-09-2005 05:58 PM |
