Old 11-08-2005, 11:06 PM   #1
edjack
Member#: 99470
1998 Legacy Outback
Default Fill Plug corroded
'98 Legacy Outback, 84K miles. Want to change diff lube. Fill plug is corroded. Do I have to replace the diff cover, or is there an alternative?
edjack is offline   Reply With Quote
Old 11-09-2005, 11:10 AM   #2
Hayes
Member#: 11808
Heck no. Just wire brush the plug clean and use some permatex sealer ( the ever soft kind) and you are good as new.
Hayes is offline   Reply With Quote
Old 11-09-2005, 12:19 PM   #3
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Also, replacement fill plugs are cheap. I just bought one for about $2.75 from Jamie at subarugenuineparts.com.
jac04 is offline   Reply With Quote
Old 11-09-2005, 11:13 PM   #4
edjack
Member#: 99470
1998 Legacy Outback
Sorry, I was not being clear: the plug refuses to come out. I have even tried heat (but maybe not hot enough).
I actually put a bottle jack on the breaker bar, and put a wrap in the bar, and left it there, while heating with a heat gun. Afraid to get out my Bernz-o-matic.
Old 11-10-2005, 01:19 AM   #5
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Spray with some liquid wrench or something else that frees seized up nuts.
Then put a long piece of pipe over your wrench to get more leverage.
z is offline   Reply With Quote
Old 11-10-2005, 07:36 AM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
do you know anyone with an impact wrench? If it's never been changed before, Subaru does put some sort of black threadlocker on there, so you need to break that free - shock loading usually works (like an impact gun, or if you put the breaker bar on there and try to load it like that)
Old 11-10-2005, 12:43 PM   #7
Hayes
Member#: 11808
Yes those suckers are tight because of the thread sealer. I used a 1/2 inch braker bar and a 2 foot length of pipe.
Old 11-10-2005, 04:40 PM   #8
edjack
Member#: 99470
1998 Legacy Outback
Thanks for the inputs - I'll keep hammering at it. I began spraying Kroil on the plugs last night. I'll let you know what happens.
Old 11-16-2005, 10:22 PM   #9
edjack
Member#: 99470
1998 Legacy Outback
Default Solved!
Took it to my mechanic, he put a breaker bar and a length of pipe on it, and got it loose, on the lift. There is no Loctite on the threads, as some have posited.
RedLine 75W90 installed. Good to go.
Old 11-16-2005, 10:41 PM   #10
z
Member#: 41762
04 STi
Good to hear but, why did you pay someone else to do that when I said a few posts up to put a pipe over your wrench for leverage?
Old 11-17-2005, 11:57 PM   #11
edjack
Member#: 99470
1998 Legacy Outback
zavigm,
I couldn't get it up in the air high enough to get a long enough lever arm on it. The mechanic said he had a LOOONG pipe on the end of the breaker bar, and he could do it because he put it on a lift.
The plugs were not Loctited in; just terribly tight, and with no signs of corrosion: the threads on the plugs were shiny, with no Loctite deposits.
Old 11-18-2005, 05:03 PM   #12
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
maybe the threadlocker is a more recent development - on my car it was on both the fill and drain plugs.
Old 11-18-2005, 08:14 PM   #13
z
Member#: 41762
04 STi
edjack, at least he got it loose for ya. You should have no problem in the future getting it out if you decide to change it yourself later.
It's not loctite to keep the threads from backing off, though.
it's a liquid thread sealant that you should use so that gear oil doesn't leak out.
Help! Need a rear diff fill plug... farside62 Southern California Impreza Club Forum -- SCIC 3 04-16-2005 04:33 PM
Differential fill plug stuck! loudog800 Service & Maintenance 12 04-27-2004 06:29 PM
Where is the fill plug on the 5 speed tranny SupraTT&WRX Transmission (AT/MT) & Driveline 3 02-11-2004 12:20 PM
Where the hell is the fill plug on my transmission?? ScoobyHead1993 Legacy Forum 7 06-20-2002 07:45 PM
Transmission/differential drain/fill plug sizes Karl New England Impreza Club Forum -- NESIC 5 04-16-2002 10:23 PM
Message Board Statistics All times are GMT -4. The time now is 09:19 PM.
