Old 11-09-2005, 01:02 AM   #1
stayfido
Member#: 35726
2002 psm sedan stg 4
Default Heater problem
I have an 02 wrx and just recently the heater has been acting up. When the engine is under any type of load the heater blows hot air. But when I park and idle, the ait drastically cools off. If I rev it it will warm up a little and then cool off. This happens regardless of whether the car is warmed up or not. Also the temp of the car seems to be normal. Any ideas??
stayfido is offline   Reply With Quote
Old 11-09-2005, 01:46 PM   #2
MK1ofMnM
Member#: 6976
2006 F150
I would try checking the coolant level in radiator first. Sounds like maybe an air pocket/low coolant.
MK1ofMnM is offline   Reply With Quote
Old 11-09-2005, 05:23 PM   #3
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
This is with the a/c switched to on, and the blower on? Do you have the blower on "auto"?
z is offline   Reply With Quote
Old 11-09-2005, 08:33 PM   #4
stayfido
Member#: 35726
No auto temp mode in my car, a/c off, the blower is set to either 1 through 4 and the heat all the way to hot. I will check the coolant level, it just seems like an odd problem. Any other ideas?
Old 11-09-2005, 10:27 PM   #5
z
Member#: 41762
04 STi
Well my theory was more along the lines of the A/C fan clutch, tensioner but if the A/C isn't even on, that's out the window.
Probably more along the lines of what MK1 was thinking - something with the coolant level/ cooling system pressure.
Old 11-10-2005, 11:09 PM   #6
stayfido
Member#: 35726
duh, low coolant....problem solved, thanks!!
1985 GL Heater Problem lefty2053 'Old School' Subaru Forum 5 02-20-2005 09:01 PM
Legacy with heater problem... White2.5GT Legacy Forum 14 12-27-2004 03:46 PM
Blower Motor on heater Problem slowme Electrical & Lighting 5 11-02-2004 10:17 PM
another heater problem spoonfedb18a1 Service & Maintenance 0 05-31-2004 11:44 AM
heater problem AK_2002_WRX Service & Maintenance 1 11-04-2003 04:57 AM
