11-09-2005, 01:13 AM | #1 |
Member#: 88698
NWIC
Vehicle:'05 Best e.t. 11.8 Best Trap: 123 MPH |
Utec Flat-Foot Shifting
So I've done a ton of searching to no avail. I understand the STi UTEC does not have the option (yet) to set two different RPM points for the LC and FFS, so at what RPM am I supposed to be flat-foot shifting? Do you have to shift at the indicated RPM to get the best (smoothest) result, or does the UTEC do the same thing whenever shifting with TPS at 100%? Thanks for the help.
11-09-2005, 01:18 AM | #2 |
Member#: 96163
Vehicle:2009 IMPREZA WRB |
Info
Man good information, if you get it let me know I will be checking your thread out.
11-09-2005, 09:19 AM | #3 |
Member#: 88698
NWIC
Pre-class bump.
11-09-2005, 05:55 PM | #4 |
Member#: 88698
NWIC
bump. Somebodys gotta have some more concrete info about the secondary rev limiter - I've read every single thread ever started about this subject, yet have found no concrete answers.
11-10-2005, 10:35 AM | #5 |
Member#: 88698
NWIC
bump...seriously
11-10-2005, 11:26 AM | #6 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
If the FFS setting is at 5500 RPM, just keep your foot planted at 100% TPS when you push in the clutch instead of lifting off. It will limit the RPM then to 5500 between shifts instead of bouncing off the factory rev limit.
Post your Cobb Launch Control / FFS Experiences | BNut | AccessPort | 36 | 03-18-2009 12:46 PM |
What pins on the UTEC control LC/FFS | GeneralTJI | UTEC | 2 | 02-27-2009 03:03 PM |
LC/FFS without utec controlling fueling, timing, boost? | Zumble | UTEC | 9 | 02-04-2007 10:06 PM |
FFS/T:NH TurboXS WRX/STI Race Pipe (WS-RP) | 2gnt2wrx | Engine/Power/Exhaust | 2 | 10-27-2006 11:13 AM |
FFs fun to drive? | sabishii | Newbies & FAQs | 85 | 07-11-2005 09:27 PM |
