Welcome to the North American Subaru Impreza Owners Club Tuesday July 22, 2014
Old 11-09-2005, 09:46 AM   #1
redhouse
Member#: 91882
Default Grinding noise when turning left?
I recently installed my turbo back exhaust (APS) and I am extremely happy with. But when accelerating and turning left i hear this awful grinding noise (from what appears to be underneath me). It almost sounds as if a metal pipe was be draged across the ground.
This ONLY happens when turning left AND accelerating at the same time. The faster I go the worse it sounds. If I dont give it any gas, I dont hear it. I do only seem to hear it when I go faster than 20mph as well.
Any ideas?
redhouse is offline   Reply With Quote
Old 11-09-2005, 07:55 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Sounds like the system is rubbing against something. YOu probably need to go back under there, check the clearances around the exhaust and see where it is too close to the car.
Loosen the appropriate bolts, adjust the exhaust so it has more clearance where it had too little, tighten everything up and that should do it.
Re-test and re-adjust as necessary.
Samurai Jack is offline   Reply With Quote
Old 11-14-2005, 08:35 AM   #3
redhouse
Member#: 91882
thanks. it was exactly what you said.
Weird rubbing/grinding noise when turning hard left or right eurospek Brakes, Steering & Suspension 3 10-29-2008 07:52 PM
Weird rubbing/grinding noise when turning hard left or right eurospek Newbies & FAQs 3 10-29-2008 07:18 PM
Seems like a common problem for 2.5GT...Grinding noise when turning Mikeye Legacy Forum 10 12-22-2007 04:33 PM
Grinding noise when turning left ralliharri Brakes, Steering & Suspension 3 02-10-2007 12:28 AM
grinding noise when turning left TmR197 Transmission (AT/MT) & Driveline 3 01-21-2005 10:23 AM
