Old 11-09-2005, 11:17 AM   #1
mrtrex
Member#: 12223
2005 WRX
Default Is a VF-34 to Big For Autocross
I run SM already. Is this turbo going to have to much lag pulling out of the bends? Should I just stick with the stock td04 and get it ported and polished instead? My mods are the following:
Vishnu Reflashed ECU
Turboback Exhaust
Up-Pipe
Bigger Intercooler
mrtrex is offline   Reply With Quote
Old 11-09-2005, 11:40 AM   #2
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
I'm not 100% about this turbo ... but I can offer some general advice ...
For autocross you want more "useable" power, broader torque curve, etc rather than high peak HP/TQ numbers. So, if that's something you can get from this, then go for it.
Figure it this way, the average autocross is 2nd gear, maybe 3rd at times. So you'll want to pick your turbo based on where you're going to be in RPM's and gears. This, of course, is provided that your ultimate goal is a solod autocross car, not a high HP monster.
Car vs. Driver is offline   Reply With Quote
Old 11-09-2005, 11:44 AM   #3
fliz
Member#: 30342
I certainly hope not.
I'm installing one in my car to run locally next year. It won't compete with the 400+whp GC dwx is building, but I'm hoping it will hold it's own against the swapped Civics.
fliz is offline   Reply With Quote
Old 11-09-2005, 11:46 AM   #4
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
IMO the stock WRX turbo is laggy as is and the VF34 would only add to your top end, so maybe a port and polish would be good. Is there any data that shows a HP/TQ curve for a pnp TD04?
crystalhelix is offline   Reply With Quote
Old 11-09-2005, 01:02 PM   #5
mrtrex
Member#: 12223
2005 WRX
That is what I am thinking. The Monster Port and Polish from deadbolt looks good. I also can run that on my ecutek with out getting a retune. I just spoke to vishnu and they said that a retune would not be needed. It would shift my tq curve to the left a little and improve throttle responce.
Old 11-09-2005, 04:25 PM   #6
fliz
Member#: 30342
Have you considered leaving the turbo alone and dropping down to ESP?
With the boost deregulation, the WRX is a better competitor in ESP than SM.
Old 11-09-2005, 04:40 PM   #7
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Pick up a VF24/28 and have it ported/polished.
Or go with a TD05-16g with the same work. VF34 would be fine, if you had a 2.2 or 2.5, but with the 2.0, you would benifit more from a less larger turbo for autocross.
Just my $0.02
omahasubaru is offline   Reply With Quote
Old 11-09-2005, 04:49 PM   #8
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
why not get a tune?
unabomber was cobb stage 2 (shelf map) and pulled 223whp/xxxtq
the same day that my cobb stage 2.5 pulled a mere 243whp/232tq
he had pnp stocker pulley and other small mods but is 1000 dollars the way to be spending to make your car gain 20 hp?
unabomber ahs since gone ecutek iirc and pulled #'s extremely close to mine, but with a sick quick spool.
i'd take that 1000 and invest in an autoX school for more seat time. and maybe get a tuned map.
psyber_0ptix is offline   Reply With Quote
Old 11-09-2005, 05:09 PM   #9
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
arg...smacks self in head
Forgot to tell you toms, 99% chance next year you can change boost in ESP for the WRX. A lot of SM people will be dropping into SP classes, that's also a good option. ESP is a pretty good class here too, it would be good competition. No worries about me, I will be in BSP.
J
PS - just PM me if you need any rules clarification.
Old 11-09-2005, 05:11 PM   #10
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
oh yea, i have a vf34 and autoX, it isnt that great if you let off the throttle.
just run some sticky tires and learn to keep your foot mashed and left foot brake, or never fully lift. and you'll be fine. it really helps on straits. but its hard to drive smoothly sometimes
Old 11-09-2005, 07:14 PM   #11
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Just my $0.02
TD05-16G and VF34 are essentially the same but the VF34 is a roller bearing turbo where the16G is a thrust bearing turbo. So the VF34 will have ~200 - 300RPM quicker spool over the TD05-16G.
P&P the 16G, and you have balanced them out. P&P the VF34, and the VF34 gains again.
Samurai Jack is online now   Reply With Quote
Old 11-09-2005, 09:25 PM   #12
vintagemilano
Member#: 92528
2000 2.5RS coupe
blue ridge
If I were building a dedicated turbo car for autocross, I would be putting a smaller turbo in. Something that spools lightning quick, then tune the final car by chosing a tire size to put the gearing in the right place.
vintagemilano is offline   Reply With Quote
Old 11-10-2005, 01:28 AM   #13
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
16g
quick spool and top end (compared to vf34)
of course spool can be reduced by an aggresive TUNE
Old 11-10-2005, 10:11 AM   #14
Sideshowbob
Member#: 50304
97 TJ Wheeler
12' TSX Wagon
Originally Posted by psyber_0ptix
16g
The regulsr (non Ti) 16G isn't really much better than the VF34 for spool.
I think a VF34 is FINE for AutoX
Sideshowbob is offline   Reply With Quote
Old 11-10-2005, 10:20 AM   #15
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
i STILL think a vf34 with a tune would be much better than any off shelf vf34 map.
but it doesnt seem people want to accept or consider it
Old 11-10-2005, 10:40 AM   #16
DOHCammin
Member#: 41290
2000 OBS
I think most people agree, off the shelf maps are good for a "quick fix" but not good for safety or longevity. you can always squeeze out more power with a custom tune because off the shelf maps are way conservative for safety reasons.
looks like I have to learn auto-x in ESP class, just got my VF34 yesturday
DOHCammin is offline   Reply With Quote
Old 11-10-2005, 10:54 AM   #17
subieworx
Member#: 47769
I wouldn't even bother. You would be better of spending the extra money on suspension bits and better yet driving schools than the turbo if autox is your ultimate goal. If not, then the turbo will work alright, but is not ideal. If anything a clipped stocker would work even better.
subieworx is offline   Reply With Quote
Old 11-10-2005, 12:01 PM   #18
MattNJ2.8
Member#: 59277
2005 2009 Outback
Mazda3, Miata
I auto-x'd my VF34'd '04 WRX for a while.
Highly do NOT recommend this turbo for this application. Get a good tune, and spend that $$$ on suspension and R compounds. You will be WAY faster.
For suspension, get a big front bar, decent rear bar, and a set of decent (not TEIN) coilovers.
MattNJ2.8 is offline   Reply With Quote
Old 11-10-2005, 12:13 PM   #19
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
i have a 'small' fsb upgrade and a larger
seems to work well for me
21mm front 22 adjustable rear set to stiffest.
but want to drive fast? become a better driver.
fast cars dont make fast drivers
Old 11-10-2005, 01:24 PM   #20
mrtrex
Member#: 12223
2005 WRX
I have all the supporting suspenion mods. I think I am going with the deadbolt monster td04 and a tune. I drive the car on the street as well it is not strictly an autocross car.
Old 11-10-2005, 02:51 PM   #21
terry61oz5
Member#: 66809
04 FXT StreetTuner
Default re
Stock TD04 unpolished with 19Lbs helper spring not quite fully preloaded. It makes 16psi of down low torque very early on a 2.5L. You'll have to concentrate on the frontwheel traction (w/4:44 r&p)especially in turns under a good load. ECU compensates easily with 93+ octane.
terry61oz5 is offline   Reply With Quote
Old 11-10-2005, 06:56 PM   #22
abaxter34
Member#: 34723
fwd FTL!
isnt anti-lag legal in sm. why not go with utec and run the anti-lag for the mere 60 seconds your run lasts.
abaxter34 is offline   Reply With Quote
Old 11-10-2005, 11:02 PM   #23
WJM
Guest
Member#:
Just get on the gas earlier....unless the turbo is prepped properly for anti-lag...it will be destroyed in short order with the use of anti-lag.
Old 11-10-2005, 11:59 PM   #24
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
utec doesnt support anti-lag, thats launch control
Old 11-11-2005, 01:31 AM   #25
Duo
Member#: 38620
2005 Subaru WRX STI
you guys should make a 100 heatsoak map. You would be amazed how much torque even with a cat you can get out of your td04. I run it for rallycross, sorta the same thing. With my map I have 250ft/lbs of torque with the tdo4 on 100 octane. Mods are tbe, up pipe, and intercooler hoses also i run the eq tuning solinoid. The solinoid just helops with spool. Just thought i might offer that.
Duo is offline   Reply With Quote
FS: VF-34 to be rebuilt bxracer69 Engine/Power/Exhaust 3 01-29-2009 08:37 PM
vf 34 vs big evo 3 16g jacktheripper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 77 12-02-2007 03:00 AM
vf-34 to vf-22 jcan0045 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-15-2007 03:02 PM
vf-34 or big 16g superdupersubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 03-03-2006 10:09 AM
I've been searching but I can't find what is a vf 34??? Yea , Yea i'm noobie BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-11-2005 12:36 PM
