Old 11-09-2005, 01:44 PM   #1
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
Default weird reoccurring vibration
I got 1996 1.8 AWD MT impreza couple with 145,000 miles on it. That has a reoccurring vibration at high way speed.
I get on an on ramp and accelerate. Once I get going over 62-63MPH I get a very harsh vibration in the front end and steering wheel. After driving at high way speeds for around 1 mile the vibration goes away. This happens every time I get on the high way.
So far I've replaced
Both front CV joints
one of the ball joints
Switched the struts and springs with a used set of KYB AGX struts and H&R springs
Any one have any Ideas?
AFBeefcake is offline   Reply With Quote
Old 11-11-2005, 01:33 PM   #2
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
any one have any idears?
Old 11-11-2005, 11:42 PM   #3
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Have you checked for play in either the inner tie rods, wheel bearings. A belt shifting in a tire can cause a vibration, bent wheels could.. But since you say its going away, i'd lean away from the wheel idea.
On my 95, i've got a vibration, mainly at higher speeds, coming from the front end.. I have some play in the drivers side inner tie rod. I know my tires on the car are hosed, so that could be contributing to it also. But my vibration will come and go.. Usually only happens when i'm traveling in a straight line. turn the wheel enough, it'll go away.. For me, i'm pretty sure the tie rod is culprit of that.
subbyspeed is offline   Reply With Quote
Old 11-12-2005, 12:01 AM   #4
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
I've checked and I can't find any play in the wheels up and down or side to side.
Would the bad front diff bearing have these symptoms?
Old 11-12-2005, 12:16 AM   #5
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
I've experienced this vibration only once I think, and it was on a rough section of road on I-84. Anyways, I think its right behind the dash, and to rid myself of it I would have to tear apart my dash and tighten everything and mabe add some anti-rattle material type stuffs.
But I haven't looked too deeply into the issue.
Nick
Sko is offline   Reply With Quote
Old 11-12-2005, 12:28 AM   #6
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Wheel balancing for the win!
waktasz is offline   Reply With Quote
Weird plastic vibrating sound like coming from front of car Three105 Normally Aspirated Powertrain 4 06-22-2006 04:15 AM
Weird bass vibration... thsiao Car Audio, Video & Security 7 06-03-2005 02:24 AM
weird noise/vibration coming from the left side when turning hard left VajraTLR Brakes, Steering & Suspension 0 09-18-2004 03:47 PM
Weird Shudder / Vibration on my WRX delo- Texas Impreza Club Forum -- TXIC 3 06-08-2003 01:30 PM
Weird Shudder / Vibration on my WRX delo- Brakes, Steering & Suspension 0 06-07-2003 11:18 PM
