11-09-2005, 06:32 PM | #1 |
Member#: 86997
BAIC
Vehicle:2002 Impreza WRX Silver |
Cobb AP Stage 2 question
I currently have catless helix up-pipe and down-pipe, with the stock WRX catback. I'm saving up to get the borla hush and cobb AP. My question is this...can I get the AP now and run the stage 2 map (would actually be using the economy/granny driver map during the week and stage 2 on the weekends) before I put on the catback, or would it confuse the hell out of the ECU and mess everything up?
thanks guys.
11-09-2005, 07:06 PM | #2 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
Nope, the DP is all you need for stage 2.
11-09-2005, 08:17 PM | #3 |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
Yes you can run stage 2 and nope you won't confuse the ECU.
11-09-2005, 08:23 PM | #4 |
Member#: 86997
BAIC
yesssss. now to find a used 02/03 AP for $400 shipped
11-09-2005, 08:28 PM | #5 |
Member#: 73721
good luck pretty much any ap under 500 shipped gets gobbled up within 10 minutes here on the boards. i decided to quit waiting for that killer deal and got mine for 515 shipped a few weeks ago
11-09-2005, 09:22 PM | #6 |
Member#: 75122
SCIC
Vehicle:2005 Impreza WRX Wag White |
DP is all you need but you might not hit target boost AND have high EGT's. Thats pretty much what happend when I went Stage 2 with only a DP. I wouldnt risk it. Just listen to directions and use the entire turboback.
11-09-2005, 11:37 PM | #7 |
Member#: 86356
Vehicle:2018 Aprilia Tuono v4 1100 |
Granny mode is bad juju I think unless you really truthfully never get on the gas at all during the week.
11-09-2005, 11:40 PM | #8 |
Member#: 86997
BAIC
durring the week its pretty much just driving to school and work in slow traffic
11-10-2005, 05:35 PM | #9 |
Member#: 80204
Vehicle:2017 WRX Limited Ice Silver |
The Cobb website states:
The Stage 2 was tuned on a car with a full turbo-back system. If you have pieced together a less than optimal combo of parts or those that were not designed to work together you may not get the full benefits of the Stage 2 AccessECU. Boost may not come on as quickly and the peak power may be down from those that have a well designed full turbo-back system. If you have replaced the first section (second cat or downpipe section) and nothing else, then the Stage 2 map is what we would recommend. Again the results will be far less than optimal, but it will control the boost better than the Stage 1. If you have replaced sections 2-4 (third cat, mid-pipe, and muffler section then you are still Stage 1. You managed to get all except the part that makes the most difference. Again, we want to reiterate that Stage 2 will only get the intended results with a well designed complete turbo-back. Seems pretty clear to me.... |
Cobb AP Stage 2 Question | 03wrxowner | AccessPort | 0 | 07-01-2008 12:48 PM |
COBB AP Stage 2 Boost + other questions | kyoung05 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 25 | 02-10-2006 03:35 PM |
Cobb ap stage 2 question.... | DeKaP | Newbies & FAQs | 9 | 09-15-2005 05:30 PM |
Question about Cobb AP Stage 2. | sticky tires | Engine Management & Tuning | 8 | 01-06-2005 03:35 PM |
Cobb AP Stage 2 on 2005 STi questions. | twotacosfor99cents | Engine Management & Tuning | 9 | 01-06-2005 10:00 AM |
