Old 11-09-2005, 06:57 PM   #1
AugustusMaximus
Member#: 63060
0005 RS, 92X
silver, red
Default Newbie STI question
Just picked up an '04 STI. This may sound silly but, do you guys use regular tap water in your intercooler sprayers? Distilled water better? Thanks!
AugustusMaximus is offline   Reply With Quote
Old 11-09-2005, 07:03 PM   #2
import111
Member#: 24447
2010 Evo GSR
GG
Not a silly question at all. Distilled water is best to use so there is less chance of any build up or anything else bad.
import111 is offline   Reply With Quote
Old 11-09-2005, 07:04 PM   #3
jason2004STI
Member#: 43340
2004 STI
Java Black Pearl
Thumbs up
I use the super secret special magic water (add Ice Cubes on race day)
Regular 'ol tap water should work just fine.
Peace
Jason
jason2004STI is offline   Reply With Quote
Old 11-09-2005, 08:45 PM   #4
IlovemyRex
Member#: 99933
05 OBXT
99 2.5 RS
Has anyone thought about using alchohol instead of water?? Just curious.
IlovemyRex is offline   Reply With Quote
Old 11-09-2005, 09:12 PM   #5
WhiteLightningSTi
Member#: 99343
2005 WRX/STi
i have thought about denatured alcohol but have yet to try it. i would like to know if it works well
WhiteLightningSTi is offline   Reply With Quote
Old 11-09-2005, 09:13 PM   #6
kedrin
Member#: 48380
works good but you have the possibility of it catching on fire in your engine bay ......
kedrin is offline   Reply With Quote
Old 11-09-2005, 10:12 PM   #7
PA04STI
Member#: 37418
0491 STi FPGreen'd
GSX Evo III 16G
should also use distilled in radiator too. Impurities like sulfur etc can clog up you IC sprayer & even radiator.
Most water out of the tap has alot of chemicals in it example Chlorine etc.
Distilled is boiled & filtered thus pure water no impurities
PA04STI is offline   Reply With Quote
Old 11-09-2005, 11:47 PM   #8
KrazyKarl
Member#: 94706
2007 STI
1995 Miata
distilled water will also evaporate more readilly, but its probably not enough to make a difference.
if you want to use alcohol, its probably a bad idea to go pure alcohol, but like 50/50 or less mixed with distilled water should give you lower temps than water.
KrazyKarl is online now   Reply With Quote
Old 11-10-2005, 05:20 AM   #9
STi-JDM
Top Scoob 023
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
I put distilled water on mine
STi-JDM is offline   Reply With Quote
Old 11-10-2005, 01:38 PM   #10
robbie
Member#: 55112
Perrier or Evian!
robbie is offline   Reply With Quote
Old 11-10-2005, 03:02 PM   #11
SoareS
Member#: 94341
2005 STi
WRB W/ silver bbs
used distilled, or if you want to waste money, buy bottled watter
SoareS is offline   Reply With Quote
Old 11-11-2005, 03:20 PM   #12
AugustusMaximus
Member#: 63060
0005 RS, 92X
silver, red
Ok, so what about winter(Im in NY)? Do you guys mix water and alcohol or antifreeze or something? Is it ok to just leave the bottle empty and unplug the pump?(dont want it to burn out)
Old 11-11-2005, 05:10 PM   #13
Turbineguy
Member#: 99889
'06 STI
If you don't want to burn out the pump stop mashing the button when half of the planet is frozen.
Turbineguy is offline   Reply With Quote
Old 11-11-2005, 05:18 PM   #14
scoobymac
Member#: 84555
2005 sti
cgs
^^^^^true that....
scoobymac is offline   Reply With Quote
Old 11-11-2005, 05:31 PM   #15
wrxpunk53
Member#: 48001
Use distilled water.
wrxpunk53 is offline   Reply With Quote
Old 11-11-2005, 05:34 PM   #16
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Distilled water. No Alcohol, widshield washer fluid, water wetter or anything else that has been speculated upon. Just plain, boring distilled water.
For the winter leave it half empty (or full depending upon your view). Although I will admit in the spring it's a bit scary to hear a very loud clunk from the rear until you realize it's just the giant ice cube in there.
Old 11-11-2005, 05:55 PM   #17
Pyr0
Member#: 90552
2005 STi
2008 Bandit 1250S
The big difference between using bottled water and distilled water is, the bottled water still contains minerals that will be left behind on your IC once the water evaporates. (minerals are supposed to be in drinking water, but you don't want them on your IC)
Use distilled water. Maybe with a little splash of rubbing alcohol to prevent freezing in the winter/algae growing in the summer. But not so much alcohol as to pose a fire hazard...whatever doesn't evaporate on the intercooler is going to drip down onto a hot engine.
Pyr0 is offline   Reply With Quote
Old 11-11-2005, 11:39 PM   #18
Lexington
Member#: 50221
I'm on internets
Racin on ur bandwidth!
OMGHi2U
... IF it lit on fire... alcohol burns fairly quickly.. it's not napalm ya know
Lexington is offline   Reply With Quote
Old 11-11-2005, 11:44 PM   #19
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
Where did you buy your STi from?
Evil STI is offline   Reply With Quote
Old 11-13-2005, 12:40 PM   #20
Picard
Member#: 100204
2006 STI (retired)
Don't laugh, but I'm a really new noob here: What about those of use who live in wet climates--doesn't the IC get wet from rain water entering the engine bay? What makes the impurities in tap water worse than what comes from the environment?
Picard is offline   Reply With Quote
Old 11-13-2005, 02:15 PM   #21
STI05
Member#: 76649
08 Z06
Victory Yellow
I'm sure it does get wet during rain - just gotta drive about 115
As for the alcohol - I doubt that the stock pump and lines are capable of dealing with alcohol. Those lines don't look too durable.
STI05 is offline   Reply With Quote
Newbie with stupid Sti questions ALIEN STi Newbies & FAQs 1 05-22-2007 09:26 AM
Newbie Insurance Question on STI DilferJr Bay Area Impreza Club Forum -- BAIC 9 08-11-2005 09:58 PM
newbie sti questions theSTIguy27 Newbies & FAQs 34 11-05-2004 08:42 PM
Newbie here! Question about STi and trailer hitches Tiggyboot Interior & Exterior Modification 33 03-25-2004 09:26 AM
STI question-newbie O1LegacyGT Subaru Conversions 7 01-22-2004 11:29 PM
