Old 11-09-2005, 08:15 PM   #1
em199si
Member#: 70213
2007 TSX
PWP
Default Will a OEM Flywheel for a 2.5L fit on a 2.0L WRX?
My new flywheel has just arrived and I noticed is made for a 2.5L. I was wondering if this flywheel will fit on my 2.0L WRX.
OEM part #- 12342AA050
em199si is offline   Reply With Quote
Old 11-09-2005, 09:24 PM   #2
bottlediger
Member#: 47958
I know they make a STI lighter flywheel for the 2.0s but Im pretty sure you orderd an 04-06 sti flywheel
bottlediger is offline   Reply With Quote
Old 11-09-2005, 09:37 PM   #3
em199si
Member#: 70213
2007 TSX
PWP
yea, the flywheels is REALLY heavy, so i doubt it is the lighter one. Will it still fit though?
Old 11-09-2005, 09:43 PM   #4
bottlediger
Member#: 47958
I cant rember, i know you can either put a wrx on a sti or a sti on a wrx. I can not rember
Old 11-09-2005, 09:45 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....that pn crosses to the 'new' flywheel that subaru installed to fix 'shudder' issues on the '02 wrx's
Old 11-09-2005, 09:47 PM   #6
bottlediger
Member#: 47958
well you bought another stocker it sounds when I guess you where trying to get a lighter one? I would return it and go with the exedy
Old 11-10-2005, 01:01 AM   #7
em199si
Member#: 70213
2007 TSX
PWP
no, i wanted the stocker. not planning on doing any hard driving.
Old 11-10-2005, 01:03 AM   #8
em199si
Member#: 70213
2007 TSX
PWP
thanks, so this flywheel should work.
Old 11-10-2005, 05:33 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....google that pn and read a bit....
Old 11-10-2005, 05:36 AM   #10
ilivas
Member#: 56056
2004 wrx
T04R Turbo / 8k rpm 257
an sti flywheel wont work on a wrx.
ilivas is offline   Reply With Quote
Old 11-10-2005, 05:38 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by ilivas
an 6MT sti flywheel wont work on a wrx.
Old 11-10-2005, 01:09 PM   #12
wrxsubaru
Member#: 65133
I thought it would, but you had to do some slight grinding on the 5spd case?
wrxsubaru is offline   Reply With Quote
Old 11-23-2010, 02:58 AM   #13
ditto151
Member#: 261850
1994 RS
Red
so dose the wrx fit on the 2.5
ditto151 is offline   Reply With Quote
Old 11-23-2010, 08:23 AM   #14
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You need to use the clutch combo that is meant for your trans. The motor has nothing to do with it.
Tony
Will 06 OEM sti struts, tophats, and springs fit on an 09 wrx? stidriver31 Brakes, Steering & Suspension 1 03-25-2009 03:01 PM
can parts for a 2.5l fit on a 2.2l wheelingrider Impreza Forum 1 12-13-2007 11:06 PM
2.5L clutch on a 2.2l ? Toahk Transmission (AT/MT) & Driveline 1 11-19-2006 10:27 AM
Will OEM down pipe from 2.5l fit my 02 WRX? TheWeis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-04-2006 01:39 PM
Will 06 2.5L WRX tranny fit on a 02-05 WRX? gopsu Transmission (AT/MT) & Driveline 10 03-28-2006 07:45 AM
