Old 11-10-2005, 02:44 AM   #1
Cloaked
Member#: 71476
Default zero to top speed
Hey guys I'm hoping that someone can help me out with the length of time it takes to go from zero to the limited top speed 155mph of the 2004 Sti and what's the top speed of the 2004 Sti without the limiter. I did search but the answer wasn't there. I have a friend with a Volvo S60R that believes the Sti takes approx 33 sec. to reach top speed (155) and the Volvo "R" takes 31 secs. to reach the same speed thanks.
Cloaked is offline   Reply With Quote
Old 11-10-2005, 06:34 AM   #2
Cloaked
Member#: 71476
I found the Sti info. I only need the Volvo info. I don't expect anyone here to have that thanks.
Old 11-10-2005, 09:31 AM   #3
LeRoy
Member#: 70898
can you share the STi info?
LeRoy is offline   Reply With Quote
Old 11-10-2005, 12:52 PM   #4
mw1029h2
Member#: 87876
Sti ------------------------------ S60R
0-30 1.42------------------------ 0-30 1.9
0-40 2.49------------------------ 0-40 2.8
0-50 3.39------------------------ 0-50 4.3
0-60 4.88------------------------ 0-60 5.5
0-70 6.19 ----------------------- 0-70 7.4
0-80 8.19----------------------- 0-80 9.0
0-90 10.09---------------------- 0-90 11.0
0-100 12.49--------------------- 0-100 13.9
0-110 15.88--------------------- 0-110 16.7
0-120 19.53--------------------- 0-120 20.2
0-130 24.62----------------------0-130 25.5
0-140 33.44----------------------0-140 31.4
0-150 50.05----------------------0-150 unk
both are 2004 models
mw1029h2 is offline   Reply With Quote
Old 11-10-2005, 04:49 PM   #5
Dussander
Member#: 4798
2002 #61 STX or F125
So, I guess aero and last gear ratio make the difference from 100 on up.
Dussander is offline   Reply With Quote
Old 11-10-2005, 11:46 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I don't know the gears, but I would be willing to bet aero has a good bit to do with it
Old 11-11-2005, 01:31 AM   #7
richde
Member#: 79498
2013 XV
It's the wing's fault!
richde is offline   Reply With Quote
Old 11-11-2005, 01:51 AM   #8
REX8
Member#: 24038
Aero dominates weight at that speed surely. Really, over 80-100, weight isn't really a factor, within reason. Don't under estimate that Volvo, its one of my favorite non-subarus, its a beast....
Old 11-11-2005, 12:10 PM   #9
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
The 2004 Model STi is speed limited to 147mph from the factory. When my car was stock, it took 33-35sec to reach 140mph right at 1 mile. The VF-39 is starting to run out of juice right around there, especially with the cats on board. With the aero load increasing, it's slow going at that point. Never had enough track to test the limiter with a stock car.
TheRipler is offline   Reply With Quote
Old 11-11-2005, 12:21 PM   #10
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
Starting from a dig, the STi would be way ahead by the time both cars reached 140 mph. That's the point where the Volvo would start catching up a little bit. If your friend thinks he can beat an STi in a race because he can reach 150 faster, he is wrong. All the way up to 140, the STi was walking away.
rex n effect is offline   Reply With Quote
Old 11-11-2005, 12:24 PM   #11
REX8
Member#: 24038
No, actually after 100, the Volvo starts closing the gap, not 140. Its just not until 140 that the STi falls behind, but it was getting reeled in at EDIT, some point over the 100 mark.
The Volvo is accelerating harder at 100 than the STi is (was)
Old 11-11-2005, 01:23 PM   #12
Fred
Member#: 3560
06 STi, 02 STi
06 FXT, 94 rally car
So even though the STi is travelling at a faster speed as the Volvo reaches 100mph, the Volvo is gaining on the STi?
Set your cruise at 65mph and have someone else set theirs at 70mph and see if you can catch them. If you can, I'll give you one billion dollars.
Fred is offline   Reply With Quote
Old 11-11-2005, 01:58 PM   #13
REX8
Member#: 24038
I should have reworded that. You're right, it may never actually catch the Sti, distance wise. But it accelerates faster at 100 than the Sti does.
It takes the STi 3.39 seconds to go from 100-110, the Volvo takes 2.8. Its only a matter of time until it starts to overtake the Suby....If they don't run into their top speed first.
Start the roll on from 100 and guess who wins...a roll from 70, I bet the Volvo reels it in before its over too.
But your right, the STi has too big of a lead from a standing start to ever catch it.
Old 11-11-2005, 11:52 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
yeah, that the scoop, it's poor hood/windshield inclination...it's tall roodline/frontal area, and a poor backlight angle...
Old 11-12-2005, 02:56 AM   #15
Cloaked
Member#: 71476
So with the figures posted how many miles would it take for the Volvo to catch and pass the STi,can someone do the math thanks
Old 11-12-2005, 03:24 AM   #16
Cloaked
Member#: 71476
Here's what I found
Note: 150mph = 220 ft/s, 100mph = 146.667 ft/s
a(R) = (220 ft/s - 146.667 ft/s)/17.5s = 4.194 ft/s^2
a(STi) = (220 - 146.667)/20.95s = 3.5036 ft/s^2
So, for the R after 17.5s travels:
dist(R) = (220+146.66)/2 * 17.5s = 3208.3 ft
and at this time "t", the Sti is going about:
Vf(Sti) = 146.667ft/s + (3.5036ft/s^2*17.5s) = 207.98 ft/s = 141.8 mph
...where the R is going 150 mph
And so the STi has only traveled:
dist(Sti) = (207.98^2 - 146.667^2)/(2*3.5036) = 3103.2 ft
The difference being: 3208.3 - 3103.2 ~= 105 ft at 17.5 sec
Old 11-12-2005, 08:46 AM   #17
rex n effect
Member#: 15289
02 wrx pollen silv
You're assuming linear acceleration. If I'm not mistaken, you would need to plot the two curves (velocity vs. time). The area under the curve up to a certain time will be the distance traveled up to that time. Since there is no top speed published for the volvo, there is no telling when (if ever) it will catch the STi if they both start from 0 mph at the same point. Yes, you are correct...the volvo will win from a 100 mph roll...
Is that really useful?
Where'd you get the 150mph time for the volvo? Is it published elsewhere?
Old 11-12-2005, 10:55 AM   #18
Fred
Member#: 3560
06 STi, 02 STi
Yes retard...look at the #'s. See the gap between the two cars. At 100, look at the gap, then a 110, look at the gap. IT GOT SMALLER. The Volvo went 100-110 FASTER THAN THE STi.
You're an idiot. It takes the STi 3.39 seconds to go from 100-110, the Volvo
takes 2.8. SEE THAT, the Volvo is accelerating FASTER. AT 100 THE VOLVO IS OUTRUNNING THE STI. ITS CLOSING THE GAP
The STI is still ahead, but the Volvo is closing, its not rocket science. Do
your roll on race from 100, and Volvo will win.
To...
Now that's called changing your tune!
-Fred
(the retard idiot)
Old 11-12-2005, 11:31 AM   #19
REX8
Member#: 24038
^^^ Yeah sorry about that. I was in a tiff with the woman and I guess it showed. (Actually I jumped in the car and me and my brother did that cruise control race... ) I though I got that edit in time before any damage was done. Guess not...
Old 11-12-2005, 07:53 PM   #20
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
Dont forget the effect of the Impreza's aerodynamics, its like trying to throw an opened umbrella tied to a rock upwind in a very heavy storm LOL
Things like the scoop, spoiler and really butch front end all add up, and at speeds they add up fast.
So much so, that my Impreza does 3 mhp more (Gps measurements) with small things like mirrors folded in.
Dutch Scooby lover is offline   Reply With Quote
Old 11-13-2005, 12:51 AM   #21
Cloaked
Member#: 71476
Its limited to 155mph read that somewhere.
Old 11-13-2005, 03:06 AM   #22
rex n effect
Member#: 15289
02 wrx pollen silv
So where'd you get the time?
Old 11-13-2005, 04:26 AM   #23
sovietjet
Member#: 76600
2008 BMW M3
Yea acceleration isn't linear. Here's what I did that is very close to the truth. Plugging in the times and speeds of both vehicles on a graph the calculator came up with a best fit natural logarithm curve that is pretty accurate +- several mph.
The equations:
STI: y=36.8556ln(X) + 7.23194
VOLVO: y=40.068ln(X) - 3.9534
Taking the integral of STI equation from 12.49(100mph) to 50.05(150mph) we get 4943.09(dont feel like doing units on that)
Integral of Volvo from 13.9(100mph) to 47(approx 150mph) we get 4340.4
So from a roll 100mph to 150mph STI > Volvo
Taking integrals again from a dig we get 5765.68 for STI and 5225.8 for Volvo
Again STI > Volvo
There are of course slight errors in the above calculations due to there being no specific function for either velocity curve but they're close enough for us to see that the STI owns the Volvo either way.
sovietjet is online now   Reply With Quote
Old 11-13-2005, 08:41 AM   #24
Cloaked
Member#: 71476
http://www.fast-autos.net/volvo/volvos60r.html
http://www.rsportscars.com/eng/cars/volvo_s60r.asp
Old 11-13-2005, 02:29 PM   #25
MomoWRX
Member#: 36823
03 MBP WRX Sold :(
93.5 Single Supra :)
it all depends on the driver.......
MomoWRX is offline   Reply With Quote
Where To Test Top Speed? planetarygear Mid Atlantic Impreza Club -- MAIC 37 12-19-2005 04:52 PM
Yet another thanks to Top Speed mpaone South East Region Forum 2 04-19-2005 08:48 PM
BIG Thanks to Top Speed! WJM South East Region Forum 6 04-18-2005 01:05 PM
Thanks to Top Speed, Tom, Porter, etc. mpaone South East Region Forum 8 03-16-2005 01:31 PM
Police use Lamborghini to monitor highway, top speed 185 mph Icon25rs Off-Topic 3 05-15-2004 07:59 PM
