Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Vendor Classifieds
Old 11-10-2005, 02:20 PM   #1
Ultimate Collision Center
Vendor Sales Rating: (35)
Member#: 69072
Default Group Buy: SMC Alky Kit
ALCOHOL INJECTION KITS!!!!!!!
Price: $420 local pickup
Run higher boost with pump gas with the SMC Alcohol Injection Kit! This kit includes everything that you need to install this setup on your EVO 8, SRT-4, WRX or STI. This kit comes with a trunk mounted tank for your Evolution! These are the same kits that are being sold by Buschur Racing and Al (dynoflash) as well as maybe other vendors for over $500!! This GB will save you about $100!!!!! This kit includes the latest pump which can spray methanol, alcohol, windshield fluid, or a mix. This kit has the newest model controller as well as the map sensor built in so the alcohol pressure increases with boost pressure.
Some Features:
In Car Control Unit!
Adjustable Pump Speed Control
Adjustable Spray On Point
Test/Prime Button
"Low Alcohol" Warning Lite
"Spray On" Lite (pressure based)
"Armed" Lite
Braided Steel Alcohol Line
*New* Water/Alcohol Compatible Pump
100 psi Spray Pressure
On-Pump Line Pressure Switch
Brass Fine Spray Nozzle
I have worked very hard to get this for you guys at this price. We need 10 people to get this special pricing.
****The kit comes with a 1 gallon bottle for the trunk however for an additional $10 you can upgrade to a 2.5 gallon bottle!****
After we get 10 people I will take it from there!
Please sign up ASAP so we can get this thing going
1. Subievolved (evo-ny) 1gal PAID
2. Ultimate Collision Center (evo-ny, nasioc, srt-4mation) 1gal PAID
3. TJRCS (nasioc) 1gal PAID
4. damianhindley (evolutionm) 2.5gal PAID
5. InfamousDX (nasioc) 1gal PAID
6. nutrulz (evolutionm) 1gal PAID
7. Blue Evo 8 (evolutionm) 1gal PAID
8. HD-sw20 (nasioc) 1gal PAID
9. EvilBlueEvo8 (evolutionm) 2.5gal PAID
Ultimate Collision Center is offline   Reply With Quote
Old 11-10-2005, 02:21 PM   #2
Member#: 69072
Here are a few FAQ's
1. How does alcohol injection work?
By injecting a fine spray of alcohol into the inlet air stream of the engine you will both dramatically cool the charge air and raise the effective octane of the fuel. Both help to eliminate detonation-the enemy of any engine, especially those under boost with today's lower octane gas.
2. How much horsepower can I expect to gain?
That depends on the application...but it is common to see a 20-30% increase in HP from the added boost and/or timing you will be able to run. We have over 1,000 turbo Buicks running over 20 psi on pump gas....some running as high as 24 psi! We also have a Stage 4 WRX running 24 psi and over 400 HP on pump gas.
3. Is alcohol injection hard to use?
A good system will be fully automatic after it is installed. It should know when to spray and when to stop, and also offer tunability and monitoring of the system parameters. An "In-Car" controller is preferred. Even better is a "progressive" controller that will increase pump speed as boost increases.
4. Can alcohol injection damage my motor?
Not-as long as the injection system is working properly, it can only do good things. It will tend to keep your plugs, valves, and combustion chambers very clean, since the alcohol will dissolve carbon buildup. The damage from ignoring detonation is a blown head gasket, broken piston, or worse.
5. What if it stops working?
Only a few higher-end injection systems offer a failsafe device to sense line pressure and not allow high boost unless the system is functioning properly. This is available on the SMC kits and is meant to be used with a factory or aftermarket boost control device.
6. What kind of alcohol do I use?
SMC recommends pure denatured alcohol. It is sold as a solvent in gallon cans and is available in any large home improvement store such as Lowe's or Home Depot. This is grain alcohol that has been poisoned with a bit of methanol to make it non-drinkable. You may also use methanol if you have a source for it.
Old 11-10-2005, 02:22 PM   #3
Member#: 69072
**Also within the next 6 weeks or so there will be a fail safe feature being released that will cut boost via a line that connects to wastegate line when alky pressure drops below a designated level. This will bascially make the car run wastegate pressure and keep the motor from blowing if for any reason the alky injection malfunctions. This feature will be approximately 100 and there will be a group buy for that as well. This feature adds even greater security to an already safe well thought out kit.**
Old 11-10-2005, 08:32 PM   #4
InfamousDX
Member Sales Rating: (184)
Member#: 25413
Wow... great prices on the kits dan/erik. No one I've seen has those prices... I may have to rethink things! Who would you recommend for install?
Old 11-10-2005, 08:43 PM   #5
Member#: 69072
I will actually be installing them as well at the shop. I haven't come up with prices yet though.
Old 11-10-2005, 08:59 PM   #6
Member#: 69072
You know you want to. I tried holding out with my evo but couldn't resist. Now all I need to pick up is IC pipes and some spray and it will be set.
Old 11-11-2005, 10:40 AM   #7
InfamousDX
Member#: 25413
How big is the 2.5gal tank and where do you think it would fit? Also, would CC payment be available?
Old 11-11-2005, 11:51 AM   #8
Member#: 69072
The 2.5 tank is like putting two gallon jugs of water next to each other in your trunk. That wil give you an idea of how much room it will take up. I plan on mounting my 2.5 off to the side of the trunk. CC payment will be availabel but then I will have to charge tax.
Dan
Old 11-12-2005, 02:28 PM   #9
Bunny
Member Sales Rating: (2)
Member#: 6573
03 WRX
Silver on Gold
Tri-State Area Local Vendor "IN-STOCK" Sales Only. NO GROUP BUYS!!! NO EXCEPTIONS!!!
You guys know the rules.
Bunny is offline   Reply With Quote
Old 11-13-2005, 01:23 AM   #10
Paisan
Tri-State Track Instructor
Member Sales Rating: (4)
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
The verbiage is actually carried over from the main forum. If you are a tri-state vendor you can do a group buy here.
-mike
Paisan is offline   Reply With Quote
Old 11-13-2005, 03:11 AM   #11
ERaab212
Member#: 18466
2003 GT35r Evo VIII
[email protected]
take that jackie!!!!!!
ERaab212 is offline   Reply With Quote
Old 11-13-2005, 03:36 AM   #12
Bunny
Member#: 6573
03 WRX
Silver on Gold
Actually it had been previousl discussed between Mulder and Myself. I, however, somehow managed to find myself a life this week-end so I didn't have time to come in here and unlock the thread.
Anyways, Yea I told Mulder he could go ahead and unlock this and edit out my post but he didnt want to confuse anyone with a 'mod fight' so Paisan just inadvertantly saved me the trouble.
Old 11-14-2005, 02:54 PM   #13
Member#: 69072
All PMs returned.
Dan
Old 11-14-2005, 05:35 PM   #14
Member#: 69072
4 more spots
Old 11-15-2005, 01:12 AM   #15
Member#: 69072
3 more spots left
Old 11-15-2005, 11:24 PM   #16
Member#: 69072
2 more spots
Old 11-16-2005, 11:28 AM   #17
InfamousDX
Member#: 25413
DAN... I'm ****ing in. PM me if you need any more info than that.
Old 11-16-2005, 11:28 AM   #18
Member#: 69072
All done.
Old 11-16-2005, 09:26 PM   #19
Member#: 69072
1 more spot actually.
Old 11-16-2005, 09:48 PM   #20
Member#: 69072
All spots filled, there is room for extra but it needs to be decided within the a day or two before I place the order.
Dan
Old 11-17-2005, 10:53 AM   #21
photog72
Member#: 43815
2016 Accord Touring
2006 Honda S2000
Where would this mount in a wagon?
photog72 is offline   Reply With Quote
Old 11-17-2005, 01:15 PM   #22
Member#: 69072
That is would. Let me know.
Dan
Old 11-21-2005, 12:12 AM   #23
InfamousDX
Member#: 25413
Shoot me a PM whenever you get the details together Dan
-Mike
Old 11-21-2005, 12:27 AM   #24
Member#: 69072
Will do, I have to call Steve at SMC tomarrow. I will get in touch with everyone after that.
Old 11-23-2005, 12:17 AM   #25
Member#: 69072
PMed all interested. Last minute for people to get in on this. By Friday it will be closed.
SMC Alky Kit and Omori 45 Full Color Boost Gauge Gordata Engine/Power/Exhaust 3 11-01-2006 01:17 PM
SMC Alky Kit, Perrin Catchcan, Stock WRX parts!! Gordata Private 'For Sale' Classifieds 13 07-19-2006 10:18 AM
HR: SMC alky kit w/TXS TMIC $600 D_Block MAIC Private Classifieds 7 02-12-2006 02:52 PM
SMC alky kits, GP Moto, Walbro, Slowboy Turbos, LM1, Intercoolers & DIY parts Full Throttle Engine/Power/Exhaust 15 11-22-2004 02:51 PM
