Old 11-10-2005, 02:38 PM   #1
markreda
Member#: 89560
Default Mobil 1 0W40 Synthetic: Need Opinions
I'm about to do an oil change and I'm trying to decide which grade of oil to use...
Would it be advisable to run Mobil 1 0W40 Synthetic in a 02 WRX?
I live in Toronto, Canada and our winters can get pretty brutal.
I have a short drive to and from work, barely enough warm up the engine.
Any suggestions would be greatly appreciated.
markreda is offline   Reply With Quote
Old 11-10-2005, 02:41 PM   #2
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
I've read here that it is the recommended oil for BMWs and VWs and that it is a good choice.
I am currently running it and I must say that oil consumption is spectacularly bad. Like 1qt in 2K miles or less.
powerlabs is offline   Reply With Quote
Old 11-10-2005, 03:24 PM   #3
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
The M1 0w40 will work well, but if you rarely get the car fully warmed up, I would use the 0w30 instead. Make sure you change the oil at 3k intervals, short trips are hell on oil due to how rich the engine runs when cold and not warming up fully doesn't burn off all the water that condenses in the sump.
Make sure you avoid romping on it for at least a few minutes after the temp gauge hits normal levels.
drees is offline   Reply With Quote
Old 11-10-2005, 03:25 PM   #4
markreda
Member#: 89560
I work in the parts dept. at a Porsche dealership and Mobil 1 0W40 is all we use for Cayenne (Turbo and N.A.), 911's (98 and newer Turbo and N.A.), and all Boxsters.
Granted there is a bit of consumption on the Turbo models but its only to be expected.
Old 11-10-2005, 03:31 PM   #5
skimobile
Member#: 92114
03 WRX (NAVY Camo)
in"Special Ed." Run Group
should be using 5W-30 per manufacturers directions regardless of brand name.
skimobile is offline   Reply With Quote
Old 11-10-2005, 03:32 PM   #6
markreda
Member#: 89560
Believe it or not Porsche recomends changing the oil every 24 000kms or once a year for the 996, 997, and all Boxsters (9 litres of oil).
For the Cayenne, Porsche recomends 30 000kms or once a year (8 litres for the V8 and 7 litres for the V6).
Old 11-10-2005, 03:36 PM   #7
boxxxer
Member#: 84647
Incorrect. The manual lists a temperature range and different weights of oil for each range. 5w 30 just happens to be very common. Read what Uncle Scotty has to say about Mobile 1 5w 30.
boxxxer is online now   Reply With Quote
Old 11-10-2005, 03:37 PM   #8
richde
Member#: 79498
2013 XV Silver Slug
'84 Porsche 911-sorta red
Originally Posted by markreda
Believe it or not we recomend changing the oil every 24 000kms or once a year for the 996, 997, and all Boxsters (9 litres of oil).
For the Cayenne we recomend 30 000kms or once a year (8 litres for the V8 and 7 litres for the V6).
..and yet again the oil change myth raises it's ugly head.
richde is offline   Reply With Quote
Old 11-10-2005, 03:47 PM   #9
drees
Member#: 25905
2003 Silver Wagon
Those Porsche's have huge sumps. No problem running long oil change intervals as long as you get in a good trip to fully warm up the engine every now and then.
Old 11-10-2005, 04:18 PM   #10
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
the manual also says 10w-30
Quack is offline   Reply With Quote
Old 11-10-2005, 04:26 PM   #11
markreda
Member#: 89560
And the oil/water seperators help too.
Old 11-10-2005, 04:28 PM   #12
ericd735i
Member#: 98802
2005 9-2x
I agree with Boxxxer, the manual does list 40wt as appropriate for hotter climates, like here in central FL. We had 40+ days over 90 degrees this summer, and I'm not gonna run 30wt in those conditions. I've been running Mobil 1 0W40 with no problems.
ericd735i is offline   Reply With Quote
Old 11-10-2005, 04:42 PM   #13
markreda
Member#: 89560
I was running Mobil 1 15W50 Synthetic for the summer months with no probs.
In Toronto our summers can get as warm as 35C/95F and our winters as cold as -40C/-40F
Old 11-10-2005, 08:03 PM   #14
dcwrx2
Member#: 69005
'04 4EAT Wgn
Why people always use other cars as an example for oil change when the owner's manual is right in the glovebox?!
Porsche, BMW, Viper, ... so?
A car sells at higher price doesn't mean the suggested oil change interval and oil grade is suitable for Subaru, IMHO.
dcwrx2 is offline   Reply With Quote
Old 11-11-2005, 08:57 AM   #15
bluesubie
Member#: 767
04 FXT
Jeez, don't you get it? Nobody reads that thing?!
0W40 would be a great choice, unless you make short trips as drees already mentioned.
-Dennis
Old 11-11-2005, 09:05 AM   #16
Hayes
Member#: 11808
I'd rather do what my vehicle manufactures recomends instead of what somebody thinks I should do based on some GM recomendation or another.
Hayes is offline   Reply With Quote
Old 11-11-2005, 11:33 AM   #17
markreda
Member#: 89560
If I lived in Florida I wouldn't even think of using anything thinner than a 10W40, although I would probably use Mobil 1 Synth 15W50.
Car manufacturer provide a guideline, as they cannot account for all driving conditions and weather conditions.
Like I said in a previous post, our winters get pretty cold here, I'm hoping that somone may have an opinion on a 0W40 weight in cold weather climate.
I know the difference between a 5W30 and 0W40 isn't far off.
I don't want to piss anyone off, but I would like to get people thinking, asking questions and discussing different oils/grades/ etc.
Old 11-11-2005, 06:38 PM   #18
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Mobil1 Synthetic 0W40. New England (Mass./NH border) winters (and summers). No problem. No oil consumption. 6000 mile oil change intervals.
Synthetic oils have longer change intervals than conventional (dino) oils. They are more stable and have better long-term lubricating properties.
There is a recent thread, I think in the Service&Maintenace Forum, that talks about synthetic oils. It references some testing a Company did on synthetic oils, which included Mobil1, Redline and AMSOil. They even used oil analysis as part of the testing process.
End result for Mobil1: With no oil consumption, the oil maintained its properties for 8000 miles before it needed to be changed. I don't remember the oil weight.
Depending on how much oil consumption the particular engine had, that oil change interval was actually extended since the addition of new oil to replaced the lost oil brought the oil properties back up to "safe" levels.
Samurai Jack is online now   Reply With Quote
Old 11-11-2005, 07:14 PM   #19
minerva1856
Member#: 79000
Ver8 EJ207
Mobil 5W40 T&SUV FTW
minerva1856 is offline   Reply With Quote
Old 11-12-2005, 03:15 AM   #20
garie
Member#: 26607
2002 wrx wagon
^^ supposed to be good stuff go over to
bobtheoilguy.com and run a search for m1 5w40.
garie is offline   Reply With Quote
Old 11-14-2005, 10:16 PM   #21
markreda
Member#: 89560
a correction needs to be made...
the correct web address is www.bobistheoilguy.com
Old 11-15-2005, 05:16 AM   #22
garie
Member#: 26607
2002 wrx wagon
hehe my bad.
Old 11-15-2005, 09:01 AM   #23
todd_fuller
Member#: 79004
2005 Impreza WRX STi
Crystal Grey
It's fine. I used that weight oil in my STi on my first oil change. Did an oil analysis which showed I could have run longer than the 7500 miles I did on the oil.
todd_fuller is offline   Reply With Quote
Old 11-15-2005, 09:07 AM   #24
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
WAKE THE HELL UP!!!!!!!!!!!!!
Old 11-16-2005, 03:04 AM   #25
Tabolt
Member#: 99006
*feel* the anger of red-
behold,
the effectiveness of exclamation points
Tabolt is offline   Reply With Quote
mobil 1 0w40 + 15w50 CT26SupraTurbo Service & Maintenance 3 05-26-2010 12:13 AM
Mobil 1 0W40? edykh Service & Maintenance 9 01-29-2005 07:45 AM
need to take drug test... it's been a month-ish.. need opinions/facts iloveturbos Off-Topic 28 01-27-2005 10:17 AM
Need new pads need opinions Davenow Brakes, Steering & Suspension 6 07-16-2003 01:45 PM
Need opinion on Diamond Audio sub's, and opinion on choosing a sub! well_armed Car Audio, Video & Security 12 04-18-2002 01:56 PM
