11-10-2005, 06:36 PM | #1 |
Member#: 60042
Vehicle:2004 WRX STI Rotated T67 ALLABOUTSPEED |
Are there gains with race gas with no tune?
Hey, I was suppost to get tuned for race gas with my 20G awhile back but we ran out of time.. Well now I have 6 gallons of this stuff sitting around. I rather not let it go to waste so i figured I would use it. Would I gain any power from adding it to my 93 oct tune? If not can I do anything to my utec so I can. I want it to be useful at least.
11-10-2005, 06:49 PM | #2 |
Member#: 60324
Vehicle:1998 RS |
you'll get a little out of it, but not nearly as much as tuned for.
11-10-2005, 08:57 PM | #3 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
No. It's not like you get a rocket on the back of your car by puting different fuel in. You won't gain any power unless you change the timing, boost, or a/f ratio. You might even lose power.
peace |
11-10-2005, 09:03 PM | #4 |
Member#: 87024
BAIC
Vehicle:2005 pp psm wrx with mix of v6,7,8 sti parts |
get it tuned for it there will be a huge difference i am running a super 16g and with 91 on a mustang it does 258/240 and tuned for 110 it did 288/285! that was from 16 to 20 psi on conservative maps and the bigger the turbo the more potential to gain more power.
11-10-2005, 09:28 PM | #5 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
Higher octane = more resistant to combustion, therefore less prone to knock.
It's great for more advanced timing/more compression or boost. Not great if you don't have more timing/compression or boost... -- Dave |
11-10-2005, 09:44 PM | #6 |
Member#: 9861
RMIC
Vehicle:1999 2.35 RS-T w/NOS Hybrid Rally Blue Pearl |
However, if you run enough race gas the ecu is constantly testing timing vs knock and if it doesn't sense knock it will keep adding timing in. So if you run enough race gas the ecu will learn to take advantage of it over time. Not nearly as much as a proper tune though.
11-10-2005, 09:52 PM | #7 | |
Member#: 36528
peace |
11-10-2005, 10:29 PM | #8 |
Member#: 29549
TXIC
Vehicle:2003 WRX WRB |
the flame front does move more slowly with a higher octane fuel, but when you add more of the things that make power (timing boost removing fuel) it doesn't hurt but helps
11-11-2005, 09:48 AM | #9 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
i would put the race gas in and bump up teh boost a psi or two and make sure your not knocking. the only replacement for displacement is boost .
11-11-2005, 10:54 AM | #10 |
Member#: 60042
Yeah I dont need to bump the boost considering Im already hitting boost cut
11-11-2005, 11:24 AM | #11 |
Member#: 56203
you could move boost cut up too
Tuning with race gas | turbochad | AccessPort | 0 | 04-11-2008 04:03 PM |
can i turn up the boost with race gas but no tune? | ryanpietro | Engine Management & Tuning | 2 | 08-16-2006 05:07 PM |
Is there a reason to run race gas w/out tune? | MF-DIF | Proven Power Bragging | 24 | 04-03-2006 05:28 PM |
Are there any original WRX owners with higher milage with no tranny problems?? | coolsube | Transmission (AT/MT) & Driveline | 28 | 07-22-2004 04:51 PM |
Are there any decent racing games for the PC? | Concillian | Off-Topic | 17 | 05-29-2003 09:51 AM |
