Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Texas Impreza Club
Texas Impreza Club Forum sponsored by Gillman Subaru Houston
and Gillman Subaru San Antonio
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 11-10-2005, 07:05 PM   #1
vandejr
Member#: 85299
Default who is to blame for my car burning.
its been about 6 months now that i have my scubby and just today my whole car system bursted into flames. my question is the remote wire and power wire bursted into flames and burned my fuse box and my entire amp install kit. k-autosounds installed my amp and subs when i first got my scubby and now my harness under the dash is screwed. its burned bad , theres about 5 burned fuses, burned fog light harness, there is a bad short i beleive because my blinkers dont work, check light is on and the fuses wont stay good. should i contact my insurance company , or the cops and make a report, the installer, who should i blame for this or my main ? is who is to blame and can my insurance cover the damage.
vandejr is offline   Reply With Quote
Old 11-10-2005, 07:08 PM   #2
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
WTH? Are you talking about a can audio system? Why was it ever tapped into your fuse box? Amp power cable is suppose to be run directly from the battery to avoid pulling too much power through the teeny-tiny little stock wiring.
Texas25RS is offline   Reply With Quote
Old 11-10-2005, 07:08 PM   #3
BaylorRS
Member#: 48223
2001 2.5 RS
BRP
ya, im confused too.
it sounds like the install is to blame if it was cause by your am setup...and you havent done anything to it since then.
BaylorRS is offline   Reply With Quote
Old 11-10-2005, 07:12 PM   #4
vandejr
Member#: 85299
yes its the car audio, i thought an amp needed two power wires a big one at the battery and another power wire to turn the amp on when my car turned on? the wires r crisp burned ,from the battery to the trunk, carpet and all. i was told that they might of taped into the fuse box or fog light , and that it shorted out.
Old 11-10-2005, 07:14 PM   #5
vandejr
Member#: 85299
should i go confront the installer tomorrow and create a new a##hole or call my insurance company so that the dealer can fix my car and the dealer fix it.
Old 11-10-2005, 07:16 PM   #6
SAND_MAN1
Member#: 31535
2007 F150 Harley Dav
2003 Legacy GT
It's only 1 wire to the battery, the one that turns on the amp is connected through the stereo, it's the remote wire I believe. It turns on the amp when the stereo is powered on. Whoever did your install doesn't deserve to be in business.
SAND_MAN1 is offline   Reply With Quote
Old 11-10-2005, 07:25 PM   #7
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
It sounds like the installer may have wired the remote turn on lead to the fuse box (probably to a ignition on fuse) and mayhave caused the fire. A lawyer may be more in order than insurance.
Old 11-10-2005, 07:54 PM   #8
wagonpilot
Member#: 86011
2002 Wagon
Don't call a cop. It is a civil matter and a cop can't do anything until a law is broken. If you tear the installer a new one, THEN the cops can be involved.
Go to the stereo shop, show them the issue and give them the chance to make it right if they were at fault.
Patience at first is always better than yelling. Everyone gets defensive if they are confronted. Be professional, it works better.
wagonpilot is offline   Reply With Quote
Old 11-10-2005, 08:00 PM   #9
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
QFT.
also, if the stereo shop doesn't accept responsibility, take it to a real shop, have them investigate, bring the information to the installer, if they still deny, then get yer lawyer.
in the meantime, you really shouldn't do anything to your car and whoever is at fault will have to pay for all that shizzle.
you may want to consult your lawyer right away to find out if it is going to be worth it to pursue anything.
otherwise, you'll probably have to get your insurance to cover it. and yeah, you will be considered at fault and have to pay full deductible.
for speed of getting it fixed, insurance will be the quickest outlet...
Old 11-10-2005, 08:08 PM   #10
vandejr
Member#: 85299
thanks for the info everyone, ill through water in the fire im building up and call my insurance and c what they say.
Old 11-10-2005, 10:12 PM   #11
todd_fuller
Member#: 79004
2005 Impreza WRX STi
Crystal Grey
Not sure if your insurance company is going to do anything for you. This is no different than if your engine blows up, it's a problem with the car, not an accident you were involved in.
I have a co-worker who had his dash catch on fire and he quickly put it out. He called his insurance and they said, 'Sorry, we could do something if the car burnt to the ground but otherwise there's nothing we can do for you.' His car wasn't modified in any way either.
todd_fuller is offline   Reply With Quote
Old 11-10-2005, 10:27 PM   #12
nathansvt
Member#: 28650
insurance depends on your coverage. if you have comprehensive, I'd call the insurance company first. they'll then handle dealing with the audio shop. If not, you're on your own. also keep in mind that going into the shop mad is unlikely to improve the situation. Go calmly, ask for the manager and see if he has insurance coverage. If you do it right, they'll work with you to file with their carrier.
nathansvt is offline   Reply With Quote
Old 11-11-2005, 02:49 AM   #13
Davidss
Member#: 27446
If you do contact them bring a witness!!!
Davidss is offline   Reply With Quote
Old 11-11-2005, 03:37 AM   #14
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Yup... good idea...
And for the love of God, be calm and don't lose your cool... they will try to provoke you into doing something to get the cops called out if they really are shady.
And... there is always the chance you can use the news outlets to help you with their "Consumer defense" programs... but do that after you talk with the shop.
Is it normal for my car to be this bouncy? super laubo General Community 37 09-28-2007 09:28 AM
Who is to blame for nu-metal? RaceCarRiot Off-Topic 59 02-20-2006 11:28 AM
is it normal for my car to... svek Normally Aspirated Powertrain 9 06-26-2005 06:17 PM
going nuts. hate teh studying at 1:43 am..and who is to blame! Yes.. Keith Off-Topic 8 12-16-2003 03:25 AM
Who wants to Advertise one my car?! MGXsport North West Impreza Club Forum -- NWIC 3 03-05-2003 03:40 PM
