Old 09-02-2001, 12:54 AM   #1
adamsrs
Member#: 3768
Default R/C 440 Injector Question!
I have a 2000 RS-T with the following setup. My boss will sell me a set of R/C 440 injectors for $300. Are they the ideal injectors for my setup??
-IHI RHB5 Turbo at 4-6 psi.
-91 Legacy Turbo uppipe and manifold.
-91 Legacy Turbo Fuel pump.
-Custom 2.5" downpipe with High Flow cat.
-5Zigen 2.25" catback exhaust.
-Vortech 4:1 RRFPR.
-Denso Iridium IK22 plugs. (Two stages cooler)
-EGT, Boost, and Air/Fuel gauges.
-Blitz Dual Turbo Timer.
-JC Sports Torque Chip II.
-Soon to be installed is my 28"x11"x3" GReddy Front Mount Intercooler and Blitz Super Sound Dual Drive Blow Off Valve.
-Right now I am running unintercooled!!!
Are these the right injectors for me?
adamsrs
www.unnatural.org
adamsrs is offline   Reply With Quote
Old 09-02-2001, 02:47 PM   #2
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
well I'm not sure of the exact specs of the R/C's but 440's would probably be pretty good if you're gonna stay around 6-7psi. I wouldn't push them any farther than that. Also, you'll want to make sure they will work w/ your fuel system. If they are peak-and-hold then I dont' think they'll work w/ the stock injector drivers. I also don't think you'll need the RRFPR anymore. Or at least you'll want to turn it down to 2:1 or lower, if it's adjustable. If they are stock type injectors(low impedance, I believe is the term) you MAY have idle problems, but you won't need anything to make them work. Good luck, tho. Let us know how it turns out.
mrbell is offline   Reply With Quote
Old 09-02-2001, 06:53 PM   #3
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
they seem rather large for your setup.
bill harvey is offline   Reply With Quote
TD04,440 Injectors, Intake hyceman Engine/Power/Exhaust 8 06-21-2010 12:50 AM
WTB: stock blue 440 injectors trbomp5 Private 'Wanted' Classifieds 1 01-07-2006 02:31 PM
WTB: Stock WRX 440 injectors 02mazdap5turbo Private 'Wanted' Classifieds 6 08-20-2004 07:41 AM
Fuel correction for 440 Injectors and Link RS_NW Engine Management & Tuning 20 01-14-2003 01:39 AM
Did I get the right RC 440 injectors? Marcin Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-17-2002 10:21 PM
