#1 |
Member#: 27264
Vehicle:2005 STi CGM |
I have been doing some searching through the forum and cant seem to come up with a definitive answer. if i have a 02 wrx, and am swapping in a 05 sti motor, aside from everything else, since the 05 sti motor is drive by wire, and the 02 is not, how could this be made to work? if i drop in the sti motor as is and use the sti ecu, the car still does not have all the necessary hardware to use the DBW system (ie pedal sensors). if i swapped out the TB and intake manifold, the sti ecu neccessary to make the motor run, will still want the dbw system, and will not work with the cable system... i dont know i am confused on this right now, and any help would be greatly appreciated.
#2 |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
get a v7 ECU, lose the DBW throttle body, lose the tumbler valve and be done with it
or run the motor on your stock ECU and reflash it but the AVCS won't work and make sure you switch the throttle bodys/engine harnes as well |
#3 |
Member#: 52186
RMIC
Vehicle:2005 LGT LTD Regal Blue |
I have done a small amount of searching for this and it seems it would be easier to just add the hardware for dbw and go that rout.
#4 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
unless your now swapping the dash and cluster +the full harnessi think hondatech has the right idea ...
but i recall something about the cam sensor being differnt as well |
#5 |
Member#: 27264
what parts would the 'hardware' consist of in order to get the DBW system up and running in the 02?
#6 | |
Member#: 6551
#7 |
Member#: 27264
HndaTch627 : a V7 ECU will run the 2.5L with avcs, and everything else in the car? but it wouldnt pass inspection no matter how hard i tried though right?
#8 | |
Member#: 6551
| Thread Tools | |
| Display Modes | |
| 05 STI swap into 04 WRX Wagon. HELP! | pismobeachrider25 | Built Motor Discussion | 6 | 04-12-2010 09:58 AM |
| 04 sti swap into 02 Wrx | neversummer489 | Subaru Conversions | 19 | 01-20-2010 10:27 PM |
| 05 sti swap into 03 wrx | RexRexRex | Subaru Conversions | 0 | 02-07-2008 08:32 PM |
| 04 STi swap into 02 WRX | overlord | Subaru Conversions | 6 | 06-09-2007 12:47 AM |
| sti swap into 02 wrx | 02redscoob | Subaru Conversions | 15 | 01-27-2007 01:03 AM |
