Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 11-11-2005, 06:03 PM   #1
billtrev
Member#: 79160
2011 WRX
Question replace oil pump at 117,000mi.?
I am going to replace the timing belt and the timing belt tensioner adjuster on my 97 OBS(ej22-mt). While I'm in there I plan on replacing the water pump,t-stat,cam seals,and the oil pump seal and o-ring.
My question is would you replace the oil pump or inspect and reinstall?
billtrev is offline   Reply With Quote
Old 11-11-2005, 07:23 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Are you having an issue with oil pressure? I would probably inspect/reinstall.
Tim Sanderson is offline   Reply With Quote
Old 11-11-2005, 08:30 PM   #3
NRTmotorsports
Member#: 16517
'13 BRZ
Theres no need to replace the pump unless you are having an issue with it, just get a new seal clean it up and reinstall it.
NRTmotorsports is offline   Reply With Quote
Old 11-11-2005, 08:31 PM   #4
billtrev
Member#: 79160
2011 WRX
thanks for the quick reply
No issues with oil pressure that i'm aware of.
I found the inspection specs for the oil pump-tip,case,and side clearance.
If its within spec it looks like I just might have saved $100
Old 11-12-2005, 10:03 PM   #5
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Default oil pump
I just helped a fellow the other day with his oil pump. Most issues with the oil pump are from the screws in the back coming loose. Just take them out, apply loc-tite, and tighten with a big handled phillip screwdriver.
Oil pumps aren't usually replaced unless the housing is cracked.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 12-08-2005, 06:49 AM   #6
xS2k
Member#: 85112
nevermind...
xS2k is offline   Reply With Quote
Replaced Oil Pickup Tube - 2006 STi, 54,000mi Stock Slaven Warranty Issues & SOA Problems 10 04-29-2010 07:19 PM
Replacing Oil Pump Seal? pittsburghscoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-21-2009 10:22 PM
replaced oil pump, now won't start sureshot007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-06-2008 04:35 PM
Replacing Oil Pump on 1.8L - Advice Needed speedblind Service & Maintenance 10 06-06-2005 11:08 PM
Replaced front main seal and oil pump o-ring archer Normally Aspirated Powertrain 4 12-28-2001 04:28 AM
