Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 12-06-2005, 08:03 PM   #1
SkylineR35GTRx
Member#: 25119
2005 Impreza WRX STi
Default Oil Change specific question (already searched)
So I already searched intensively on this subject. I am about to do my first oil change in my STi at 3000 miles (and yes some people do it at 1000). So the concensus seems to be that the parts I choose isn't the most important. I will be using the new OEM filter for the imprez part 15208AA09A and crusher that comes with it. I have a 17mm socket wrench, bracing myself for a hard time taking out the drain plug, catch pan, funnel, and my questions are....
Which oil should I use? I read that you can either use synthetic or regular, but some poeple say not to change to synthetic until 8k+. I will take their advice, so should I be using Pennzoil or Havoline as Unabomber suggested?
Second question. When is the optimal time to check engine oil level. I read that many poeple had problems with their engine oil reading. My plan is to warm up the car for about 2 minutes and let it cool down overnight and check the oil in the morning. Is the dipstick calibrated to check oil when it's hot or cold? I know that when the engine oil is hot it is expanded, but the question is what is the dipstick calibrated to measure? I will be putting 4.8 qts in the engine. I hope I don't overfill. Thakns for your time!
SkylineR35GTRx is offline   Reply With Quote
Old 12-06-2005, 08:33 PM   #2
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
I'm sorry, but every question you asked has been answered about 50 gazillion times, each with a different response. There's no right answer. Search some more.
heffergm is offline   Reply With Quote
Old 12-06-2005, 08:51 PM   #3
SkylineR35GTRx
Member#: 25119
Yes I know there are different responses and they were answered 50 gazillion times and that is why it is so confusing. I just want to clear it up.
Old 12-07-2005, 12:40 AM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Warm your car and then check your oil on a LEVEL surface. The best time/place for this is during a fill-up as gas stations are normally very level and since you drove there, the car is warm.
Use whatever oil you like and fits your budget as the primary concern is a schedule of change rather than the brand/type of oil. Bravo to you for having concern about this, but relax.
P.S. I DO recommend you get a Fumoto valve to make changes easier though. I've had one since my first oil change and I giggle like a school girl every time I use it.
Old 12-07-2005, 08:06 AM   #5
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
See, and here you have your first disagreement. You shouldn't check your oil level when the car has recently been shut off. Subaru's (mine anyway) are notoriously difficult to take oil level readings from when they've recently been run. Besides, you should always check all fluid levels on a bone cold vehicle unless stated otherwise in your manual. All the capacities listed in the manual are cold, and when fluids warm, they expand.
Secondly, I say stay away from the fumoto valve. I've had oil filters damaged by flying debris, and the last thing I want is something hanging off my oil pan that, if damaged, could drain my car of oil in about 10 seconds.
Removing the oil pan drain bolt and replacing it with another crush washer doesn't take anything remotely resembling super-human strength. I would recommend a torque wrench however (33 ft/lbs for the drain plug).
Oh, and the best time to change to synthetic is whenever you decide to, which for me was at 1500 miles. My service schedule is here should you care to look:
http://www.photoslave.com/journal/auto/wrx_maint.html
Old 12-07-2005, 08:31 AM   #6
RUrunning
Member#: 68758
15 STi
LE
the imagery is nothing short of amazing
RUrunning is offline   Reply With Quote
Old 12-07-2005, 11:01 AM   #7
imaaaron
Member#: 74047
2005 STi
Muscle up. Those japs are on steriods. That oil filter will not come off without a filter wrench.
imaaaron is offline   Reply With Quote
Old 12-07-2005, 11:23 AM   #8
2fas4u
Member#: 90691
2005 STI / 2009 STI
Pffft, if you hit something that hard that the protective cover and fugitmoto come off, you probably wont drive much further anyway. Ive run one for a long time and zero problems at all!
2fas4u is offline   Reply With Quote
Old 12-07-2005, 11:42 AM   #9
peterex
Member#: 27021
2015 WRX
I managed to get mine off by gripping it with some low grit sandpaper.
peterex is offline   Reply With Quote
Old 12-07-2005, 07:17 PM   #10
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
and adding your post to the 50gazillion other posts will help clear things up?
YOu can't go wrong with engine oil. Just use one that you like. Everyone has their favorites. Mobil 1 is quite popular if using a synthetic. I personally use German-made Castrol Syntec and love it.
volkl23 is offline   Reply With Quote
Old 12-08-2005, 08:34 AM   #11
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
One additional thing to watch out for on the first oil change. Oftentimes the crush washer installed at the factory on the drain plug is "glued" to the drain plug via paint, and can easily be missed if you're not looking for it. The resulting doubled-up crush washer can then leak. I had to carefully pry the factory crush washer off the drain plug with a thin-bladed flat-head screwdriver after first "scoring" the paint between the plug and the crush washer.
AndyH is offline   Reply With Quote
high idle after oil change. quick question before a trip. Woofy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 09-13-2008 04:35 PM
Oil change weight question? 4banger Canada Region Forum 1 09-28-2005 09:13 AM
STi oil change procedure question - Car's on the ramps now! fastwrx Service & Maintenance 9 08-09-2004 06:03 PM
Documenting Oil Changes - Warranty Question cracker196 Service & Maintenance 3 07-16-2004 03:14 PM
Dumb gear oil change interval question Bimmer Service & Maintenance 7 12-24-2003 09:12 PM
