Old 11-11-2005, 06:42 PM   #1
gc822
Member#: 81217
Impreza GC8 rally x tire pressure
so I'm looking for some input from the experienced RallyXers...... I'm running my first Rally X tomorrow in Monticello NY. What is a good tire pressure to run on dirt?
-Mac
gc822 is offline   Reply With Quote
Old 11-11-2005, 07:28 PM   #2
MarkA
Member#: 41558
What kind of tires?
MarkA is offline   Reply With Quote
Old 11-11-2005, 07:30 PM   #3
gc822
Member#: 81217
Kuhmo Ecsta ASX All seasons
205/55/16
Old 11-11-2005, 07:35 PM   #4
Tensen
Member#: 5005
2010 Legacy 3.6R
and a lil blue wagon...
say hello...i'll be the big guy with the camera
Tensen is offline   Reply With Quote
Old 11-11-2005, 07:45 PM   #5
Duo
Member#: 38620
2005 Subaru WRX STI
i would say 40 just to be safe. I bet you could run aroun 36psi but 40 you will be fine for sure. And you can always lower your pressure If your but comes out alot drop the pressure a bit.
Duo is offline   Reply With Quote
Old 11-11-2005, 07:50 PM   #6
gc822
Member#: 81217
Impreza GC8
yeah I ran 40psi @ all four at my last autoX, did very well. However first RallyX and want to make sure that I'm not running too high of a pressure for the dirt surface
Old 11-11-2005, 08:06 PM   #7
MarkA
Member#: 41558
High pressures will only cost you an almost un-noticeable amount of traction but will make it much safer for you as it reduces the risk of blowing a bead. I'll second the recommendation for at least 40PSI.
Old 11-11-2005, 08:14 PM   #8
gc822
Member#: 81217
cool sounds good, anyone else have a recommendation?
thx guys BTW
Old 11-11-2005, 08:47 PM   #9
solo2wrx
Member#: 87982
05 Intrepid
125cc of 2 stroke fury
I third the atleast 40 pounds recommendation.
solo2wrx is offline   Reply With Quote
Old 11-11-2005, 09:14 PM   #10
cowapult
Member#: 25324
2016 WRX
Dark Gray Metallic
I've run 38F/35R (cold) and never had a problem
cowapult is offline   Reply With Quote
Old 11-11-2005, 09:55 PM   #11
CombuSTIon
Member#: 62301
2004 STI
Start @ 40, work down slowly but do not drop below 35-36 or you will be tempting the fates for a blown bead.
CombuSTIon is offline   Reply With Quote
Old 11-11-2005, 10:02 PM   #12
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
^^^ @ the last rallyX I saw 3 or 4 blown beads as the ruts got larger through the day. You will have a blast though and have fun getting sideways.
Rasmusson14 is offline   Reply With Quote
Old 11-12-2005, 12:15 AM   #13
RRR-K2
Member#: 22365
98 Outback Wagon
2000 Impreza Sedan
I know this isn't going to be in time to help this weekend, and I'm going to be the odd-ball here, but...
Depending on how packed the dirt is and what kind of ruts/berms there are, I run anywhere from around 18F/20R up to about 28F/30R with my Hakka 1's. In about 6+ years of some serious Rally-Crossing I've NEVER popped a bead (had a valve stem rip in half, but that's another story ).
If you don't believe that it's possible, check out my right-rear tire in this shot that Tensen took a few years ago:
Personally, it's one of my all-time favorite photos
Just my $.02
Matt Kennedy
www.rockyroadracing.com
RRR-K2 is offline   Reply With Quote
Old 11-12-2005, 12:39 AM   #14
Rasmusson14
Member#: 77658
very cool pic.......i am a compleate noob when it comes to rallyx
Why then do guys pop beads often? Is it just lack of skill? Where everyone kept doing was on a hard turn that had a deep bump right before the turn. If you didn't get on the brakes early enough you ran the risk of hitting the deep hole with your tires locked and turned.......then POP......rolly polly goes tire
BTW - very cool site. I wish I lived out there!!!!
Old 11-12-2005, 04:08 AM   #15
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Surface conditions, sidewall stiffness, sidewall profile, wheels...
I ran 38/36 at my first one and was fine. Did have to do the back-and-forth dance a couple of times. Never knew brakes could be so loud with a stone stuck between the pad and rotor, hehe.
Beanboy is offline   Reply With Quote
Old 11-12-2005, 04:21 AM   #16
WRX-pilot
Member#: 31162
2005 STi
Another vote for 40psi or above
WRX-pilot is offline   Reply With Quote
Old 11-12-2005, 03:11 PM   #17
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
40 or above? damn that seems high but try it out.
I rolled the bead on one last weekend and I think we were running like 35
mykrrrr is offline   Reply With Quote
Old 11-12-2005, 03:25 PM   #18
WRX-pilot
Member#: 31162
2005 STi
I did blow a bead once at 40psi but never had a problem other than that (sliding around a hairpin).
I've just always did 40psi as the Rally-x instructors told us and I have been fine with that.
Old 11-12-2005, 06:19 PM   #19
platypus
Member#: 11774
Car 334
I usually run about 26-28 psi for rallyX tires (Kumhos and Pirelli's). The proper rally tires have stiffer sidewalls and so are far less likely to roll off the bead. Drop the pressure down!
platypus is offline   Reply With Quote
Old 11-13-2005, 12:41 AM   #20
CombuSTIon
Member#: 62301
2004 STI
depends on tire mainly.. I had a set of BFG all weather and they just sucked butt @ any PSI (I tried anywhere between 35-50 with no success); but my current set of KDWS tires I just ran @ 31 PSI today without any issue.
Old 11-13-2005, 07:27 PM   #21
gc822
Member#: 81217
thanks again guys, the Rally X was a blast, ran 40psi and then dropped to 38, next time def getting better tires.
Old 11-13-2005, 07:58 PM   #22
Beanboy
Member#: 4814
2005 LGT Wagon 5MT
Garnet Red Pearl
Nice! Any pics from the event? How'd you do?
-B
Old 11-13-2005, 10:24 PM   #23
gc822
Member#: 81217
-B
did decent, had a blast....
here is the link to the Rally X thread/pics- I'm the green Impreza L #27, you'll have to look through the album
LINK
Old 11-14-2005, 10:06 AM   #24
AlbaScoob
Member#: 79847
2004 WRX rally car
TIM/Alba Rallysport
I typically run with 37F 39R (on 15" gravel tires). I alter the pressure in the rears depending on how sideways I need to get....but it all depends on your suspension setup/adjustablility, tire type/size, surface, outside temps. etc.
pic link?
AlbaScoob is offline   Reply With Quote
Old 11-14-2005, 11:15 AM   #25
gc822
Member#: 81217
oops, added the link above or here it is again
New tires, which tire pressure to go by, tire or car? NewShockerGuy Tire & Wheel 7 12-04-2004 02:33 PM
Help rally tire pressure..... LyveWRX Motorsports 21 08-30-2003 10:46 AM
Tire pressure for rally school Freeskier Brakes, Steering & Suspension 2 11-27-2001 10:39 AM
Tire Pressure- TSD Rally metroplanner Motorsports 17 06-12-2001 01:02 PM
Tire pressure for Rally-X 555wagon Brakes, Steering & Suspension 9 02-22-2001 08:53 AM
