Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 11-11-2005, 10:15 PM   #1
Sparcomx
Member#: 1791
Default Hydra wb install
I just got my hydra last week with the wb option but no instrctions on where to install the pins on the hydra.. i tried calling phill and left messages but no answer i think he is travaling to ca to do tunes.. someone must have this..
thanks.. im craving boost..
Sparcomx is offline   Reply With Quote
Old 11-12-2005, 04:50 PM   #2
RemlapaN
Member#: 58251
2004 Sti
GT35R 530whp @ 27psi
If you insert the CD-Rom supplied to you with your hyrda, and open it using windows explorer you will see a document entitled "Hooking up Wideband O2 to Hydra Nemesis 2" - that contains what you wanted to know.
However, for summary:
A --> Gray Connector, Pin B1
B --> Gray Connector, Pin B2
C --> Gray Connector, Pin B9
D --> Gray Connector, Pin A11
E --> Large Blue Connector, D7
That is for my 2004 STi, not sure if it is model specific or not.
RemlapaN is offline   Reply With Quote
Old 11-13-2005, 05:18 AM   #3
Sparcomx
Member#: 1791
thanks a lot
Fluttering AFRs while calibrating Hydra WB O2 - Is this normal? dexterous Other Engine Management 6 03-30-2009 06:43 AM
Hydra WB Wiring ExecNav Other Engine Management 12 10-31-2007 08:26 AM
Alternate CHEAPER Hydra WB Sensor??? White 2.5rs Other Engine Management 0 06-17-2007 07:59 PM
Hydra + engine install= no spark?? scooby-stu Other Engine Management 9 12-20-2006 09:06 AM
HYDRA WB install oldbluwrx Other Engine Management 0 09-03-2005 03:08 PM
