Old 11-14-2005, 07:52 PM   #26
BIGSKYWRX
Member#: 7958
09 GH B+
Originally Posted by JayGold
From www.subaruwrxparts.com website:
Seal kit: 26297FA050
Subaru 4 Pot Rebuild Kit
Cracked piston boots? Popped out a piston? Run lots of track days? Then this rebuild kit is for you! Contains parts to rebuild the seals on one set of non-Brembo 4 pot calipers- 8 piston seals, 8 piston rings, 8 piston seal retainers, and a packet of grease.
Price:$25.00
This is the complete kit I used to rebuild both calipers.
Great- that's the one I got
Old 11-14-2005, 09:45 PM   #27
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
Thank you for the great writeup! Much appreciated!
volkl23 is offline   Reply With Quote
Old 11-14-2005, 11:15 PM   #28
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
great write up!
To bad I sold them with the car! two years to late
Leonardo is offline   Reply With Quote
Old 11-15-2005, 09:19 PM   #29
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Thumbs up
After tracking the car at Gingerman Racetrack in MI, I started to swap my race pads out and noticed the outer dust boots were melted and torn open. I figured it was time to replace them and inspect the calipers which I had never cleaned up since purchase from overseas 3 years ago.
Fair enough, thanks for the great write-up.
jamesfacts is offline   Reply With Quote
Old 11-15-2005, 09:45 PM   #30
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Thanks JayGold. Great contribution.
jblaine is offline   Reply With Quote
Old 11-16-2005, 02:10 PM   #31
SeattleWRX
Member#: 10350
02 WRX Sedan
AWESOME Write up!
SeattleWRX is offline   Reply With Quote
Old 11-16-2005, 02:14 PM   #32
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Originally Posted by burnera
Sticky!
i'm w/him! great write-up!
Bishop is offline   Reply With Quote
Old 02-25-2006, 05:11 PM   #33
mrruins
Member#: 41337
2005 Toyota Tacoma
thanks jaygold
mrruins is offline   Reply With Quote
Old 10-18-2006, 04:57 PM   #34
JayGold
Member#: 7074
Thought I would bump this up right before winter strikes IL, seeing that I need to rebuild my OEM '02 WRX front calipers (used on my '00 Impreza L Sedan) due to a seized drivers side piston.
Purchased the rebuild kit from my local Subaru dealership, cost $30.00 and it includes outer dust boots, inner seals, and lube for rebuilding both front calipers.
Here we go again
JayGold is offline   Reply With Quote
Old 07-27-2007, 05:59 PM   #35
elsanto
Member#: 34832
1989 M3
Anyone know if there is anything special to do when splitting the two halves apart? my calipers came missing bolts and id like to open them up to make sure they are ok inside..
elsanto is offline   Reply With Quote
Old 07-27-2007, 07:06 PM   #36
BIGSKYWRX
Member#: 7958
09 GH B+
don't split them- no need to- the only thing to check is the seals/boots/pistons- that can be done w/o splitting them- these is a step by step tutorial on rebuilding the calipers floating aorund
Old 07-27-2007, 11:20 PM   #37
elsanto
Member#: 34832
1989 M3
any idea where to get the missing 2 bolts per caliper? the outer two bolts holding each half of the aliper together.
Old 07-27-2007, 11:42 PM   #38
JayGold
Member#: 7074
What bolts are missing on your calipers? Can you provide us a pic of your calipers?
There should be no need to split the 2 caliper halves apart unless one side was damaged and your replacing it with a new half. I believe if you do split them apart there are seals connecting the inner passages which may then need to be replaced...and I don't know of any vendor that sells those.
Old 10-27-2007, 09:37 PM   #39
woosleycoon84
Member#: 110563
04 psm Wrx
96 Dirty Outback
thanks sooo much for this thread ... It helped me out alot while i rebuilt mine
woosleycoon84 is offline   Reply With Quote
Old 10-28-2007, 12:05 AM   #40
bushflyr
Member#: 89628
'02 Wagon VF39'd
& Quick Racked
Awesome write up! I would not have even really thought about rebuilding a caliper. You make it look easy.
bushflyr is offline   Reply With Quote
Old 10-25-2008, 05:37 PM   #41
unclemat
Member#: 114530
2005 LGT 6MT wagon
This how-to is retarded. You do not put grease on piston or the inner seal - this contaminates the brake fluid with grease. The OP could have added some to brake master cylinder for a good measure as well
The grease is just to be used on the lip surface of boot where it contacts the piston. A coat of brake fluid should be applied to the seal, piston and the cylinder surface before the assembly.
unclemat is offline   Reply With Quote
Old 10-27-2008, 06:09 PM   #42
JayGold
Member#: 7074
Thanks for chiming in 4 years later...
At the time there was little info on rebuilding 4-pots and mis-information out there as well. This was the best I could do since no one else stepped forward to assist.
EDITED Thanks to unclemat
Old 01-31-2009, 03:53 AM   #43
stigc8
Member#: 32378
1993 WRX Type RA
This is a great thread, sorry to take this O/T but would this method work for calipers that are nearly 100% seized or is that when you would need to split the halves?
I have 2-pot Version 1 WRX calipers that need replacing or rebuild. If anyone has any leads on a kit for that I would be greatful
Awesome tutorial jaygold
stigc8 is offline   Reply With Quote
Old 01-31-2009, 12:25 PM   #44
BIGSKYWRX
Member#: 7958
09 GH B+
does anyone know if their is a part # for the pistons? if someone had pistons that were pitted/rusted badly?
Old 01-31-2009, 12:56 PM   #45
SobaLo_WRX
Member#: 186782
2002 WRX Sedan
Nice write up, Jay. Bookmarked!
SobaLo_WRX is offline   Reply With Quote
Old 01-31-2009, 01:08 PM   #46
unclemat
Member#: 114530
2005 LGT 6MT wagon
Yeah, scary that in four years noone pointed this out to you.
C'mon, anyone who does ANY brake job should know that grease - or for that matter anything else that could be contaminant - is not to be put into the brake fluid. Otherwise it's best to leave the job tthe car to a pro. If you're unusre about what you're doing don't post how-tos. It does more harm than good.
Old 01-31-2009, 06:57 PM   #47
JayGold
Member#: 7074
I agree, rather enlightening...and this why I placed the write-up on here; to share and learn since it was the first real 'brake job' other than swapping pads/rotors I completed so give me some credit.
It's been edited with your input and the only folks rebuilding the 4-pots at this point would be those with older JDM versions and '06 TR's-on which probably don't require rebuilds just yet unless tracked hard....so let's move past the criticism already.
Old 01-31-2009, 07:02 PM   #48
JayGold
Member#: 7074
I would be hard pressed to find out the pistons are sized drastically different than later models, but ya never know with Subaru. Apparently Nissan 300ZX 4-pots are similar and those go back to 1989 models. I'd hit up a Subaru specialist on older gen JDM models to find out the info your looking for just to be certain. Maybe the folks over at RS25.com have some info on those calipers and rebuild parts/part#'s.
Old 03-28-2009, 11:22 PM   #49
Magoozle
Member#: 37848
1997 L->WRX
1998 Legacy GT wagooon
Any idea on the torque spec for the bolts that connect the two halves?
Magoozle is offline   Reply With Quote
Old 03-29-2009, 12:48 AM   #50
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
I found the posting helpful for rebuilding my RacingBrake 4 pots though they have no boot. I didn't use and grease, just some brake fluid as I knew better
aggie113 is offline   Reply With Quote
RacingBrake 4-pot Calipers: 50% lighter than Subaru 4-pot & fit under OEM WRX Wheels! AZP Installs Tri-State Area Vendor Classifieds 20 12-11-2012 03:27 PM
Subaru 4-pot Piston Removal/Rebuild JayGold Brakes, Steering & Suspension 12 11-10-2005 09:07 PM
Subaru 4-Pot rebuild tutorial? TROLL Brakes, Steering & Suspension 0 10-12-2005 01:01 PM
Wilwood 4 pot vs Subaru 4 pot Jaz_rs Brakes, Steering & Suspension 25 05-13-2004 12:03 PM
Wilwood 4 pot vs Subaru 4 pot BIGSKYWRX Brakes, Steering & Suspension 124 12-09-2002 11:07 AM
