Old 04-26-2009, 09:58 PM   #51
JayGold
Member#: 7074
Original JDM calipers rebuilt again...
But now on my daily driven L sedan along with a '02 WRX rear disc conversion and Goodridge SS lines...talk about stopping power
Painted DBA rotor hats:
JayGold is offline   Reply With Quote
Old 05-01-2009, 05:26 PM   #52
wsmith30132
Member#: 172026
2005 LGT MT SS-18GXR
Originally Posted by unclemat View Post
Yeah, scary that in four years noone pointed this out to you.
C'mon, anyone who does ANY brake job should know that grease - or for that matter anything else that could be contaminant - is not to be put into the brake fluid. Otherwise it's best to leave the job tthe car to a pro. If you're unusre about what you're doing don't post how-tos. It does more harm than good.
I'm not saying that you are wrong but why would they send grease packets in the rebuid kit and tell you to put it on the piston seal? Also the Permetex caliper grease I bought listed it to be applied to the piston. I rubbed a little on the piston and some on the inside of the piston boot. I figured it would help condition the boot to heat/stress. I'm a little woried now. I see where you are coming from about mixing the 2 but OEM includes it...
wsmith30132 is offline   Reply With Quote
Old 05-01-2009, 05:49 PM   #53
unclemat
Member#: 114530
2005 LGT 6MT wagon
It is supposed to be put in the groove in the boot that circles piston only, not all over the piston.
unclemat is offline   Reply With Quote
Old 05-01-2009, 07:22 PM   #54
AbACUZ
Member#: 101898
1905 NINETWO EX AIRO
Prodriv.Hotchkis.Stromng.
Lightbulb
if that was the case, this thread would not be here and we would have missed all its valuable information as it has developed over the years.
All the other 90% of the DIY threads would have not been made if they had your standard since it would take some one with a phd in mechanics to know all the ins and outs and be 100% sure about everything they have done.
So i say, have an open mind ,do the best job you can, post all the steps you have made, and be ready to revise as you get new and better information..
Bravo to the OP.
AbACUZ is offline   Reply With Quote
Old 05-01-2009, 07:29 PM   #55
Garage Spec
Vendor
Member#: 133383
2004 Subaru GDB STI
that's correct.
You don't want to get any grease on the inside where the brake fluid will be flowing.
The grease is only there to help keep the dust out on the top edge of the piston where the boot sits around the top of the piston.
Garage Spec is offline   Reply With Quote
Old 05-01-2009, 08:47 PM   #56
unclemat
Member#: 114530
2005 LGT 6MT wagon
Whatever...
Old 05-02-2009, 01:55 AM   #57
wsmith30132
Member#: 172026
Well I put it on the piston too. F-it, that sucks. Any major adverse effects? Unclemat I almost pmed you the other day on legacy gt about it but I didnt. I have learned to respect what you say and have always appreciated your advice. Damnit man. Would flushing it again in a month or so help the issue?
Old 05-02-2009, 02:37 AM   #58
unclemat
Member#: 114530
2005 LGT 6MT wagon
Probably not. If you used the supplied red grease, it's not petroleum based, so it should not really "mix" with the brake fluid. I still don't like the idea of smearing it all over the piston (Subaru FSM is clear about where it needs to be used), but I guess if your brakes work, they won't suddenly stop working because of that....
Old 05-06-2009, 10:47 PM   #59
JayGold
Member#: 7074
Well I put it on the piston too. F-it, that sucks. Any major adverse effects? Would flushing it again in a month or so help the issue?
After I made the error the first rebuild time and upon disassembly the second rebuild time I noticed no adverse affects of having the supplied red grease on the pistons.
This last time I rebuilt them (pics at top of page) I cleaned and flushed the calipers throughly along with polishing the inside of the pistons as mine were rusty.
Upon reassembly I only used the red grease on the piston dust cover galley which made sliding it over the piston easier. I also wiped any grease which snuck out from the bottom after placing the cover on. What made this easy to assemble is if you cut a very small corner (like 2mm) of the grease packet and slowly squeeze it out, around and into the piston galley.
As unclemat stated, use brake fluid to cover the pistons before placing and evenly pressing into the calipers.
I've had the 4-pot fronts/WRX rear disc's on my L sedan for a couple weeks and they suprisingly work...incredible (like eye popping, brain hitting forehead brake power...literally) with the L's OEM porportioning valve.
Old 10-25-2009, 09:13 PM   #60
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
This is a good write-up, and I will be using it in the very near future as I just aquired a 4-pot set up for my car.
I love the search button.
wrXmon is offline   Reply With Quote
Old 10-26-2009, 01:24 PM   #61
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Awesome thread. I will definitely be looking this one up later.
+1 for sticky
EdHilario is offline   Reply With Quote
Old 02-13-2010, 11:45 PM   #62
ncarn8
Member#: 71419
for all people looking for this, the seal kit has been superceded to part number 26297FA051
ncarn8 is offline   Reply With Quote
Old 02-14-2010, 04:10 PM   #63
JayGold
Member#: 7074
updated pn# on page 1, thx!
Old 02-15-2010, 08:28 AM   #64
fnlyfnd
Member#: 100247
2015 Outback Premium
Carbide Gray
Last summer I tracked my car once, but I noticed that my piston boots were completely shot, cracked and mangled. It's now winter and salty. When I go to rebuild my calipers should I expect my pistons to be rusty and pitted? Can I just replace the pistons if they are really bad?
fnlyfnd is offline   Reply With Quote
Old 02-15-2010, 09:04 AM   #65
BIGSKYWRX
Member#: 7958
09 GH B+
^ you can often "freshen up" the pistons w/ some fine (1000+) sandpaper
I haven't found a source for pistons- if you find one, post it up
Old 03-18-2010, 03:16 PM   #66
TraviST185
Member#: 101861
Is there a reseal kit for the 2 pot rear calipers?
TraviST185 is offline   Reply With Quote
Old 03-18-2010, 08:08 PM   #67
BIGSKYWRX
Member#: 7958
09 GH B+
yup- don't have the part # handy though
Old 03-21-2010, 05:04 PM   #68
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
does anyone know what the subaru part # is for the seals that go between the 2 halves of the 4 pots? Im rebuilding mine and they didnt come in standard seal kit. Searched but didnt find anything, prob a long shot. thanx.
4pot piston part #: 26236FA010 - approx $20/ea from dealer yea that's $160 for all 8...
2pot seal kit part #: 26697FA000
012.5RS is offline   Reply With Quote
Old 03-21-2010, 05:53 PM   #69
BIGSKYWRX
Member#: 7958
09 GH B+
I've never seen that offered in all the schematics I've looked at
Old 03-21-2010, 10:16 PM   #70
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I have been searching that elusive 'kit' since 2002
GFL
Old 03-22-2010, 11:15 AM   #71
012.5RS
Member#: 95051
02 WRX Wagon
World Rally Blue
Anyone know where to get a seal that works? I'm missing 3...
Old 03-22-2010, 12:40 PM   #72
Uncle Scotty
Member#: 16200
OK buy Nates beans
d33333333333wd
you are FAR better off buying a new caliper than playing with what you have
there
aint
no
parts
fer
them
things
I been looking fer yeerz.....there are tales of somebody knowin somethin....tol aroun teh kampfyre....but aint nuthin ever sceen
Old 03-22-2010, 02:41 PM   #73
BIGSKYWRX
Member#: 7958
09 GH B+
you might give rallispec a shout or Vermont sports- both knowledgeable in the rally scene (and use those brakes)- they may have a source possibly (or a defunct set that they can get the seal from???), like I said I've looked at a lot of schematics over the years and have never seen those seals listed (pistons- yes, other seals- yes, but not the "half" seals)
Old 03-22-2010, 02:50 PM   #74
Masterwink
Member#: 147756
2007 WRX
It seems easy, I'm now more tempted to do it.
Masterwink is offline   Reply With Quote
Old 08-19-2011, 01:29 PM   #75
///MIKE
Member#: 234460
2003 WRX
Blue Pearl
Yes, this is back from the dead... thanks to me. Did this yesterday. Worked out great! Very useful thread.
///MIKE is offline   Reply With Quote
RacingBrake 4-pot Calipers: 50% lighter than Subaru 4-pot & fit under OEM WRX Wheels! AZP Installs Tri-State Area Vendor Classifieds 20 12-11-2012 03:27 PM
Subaru 4-pot Piston Removal/Rebuild JayGold Brakes, Steering & Suspension 12 11-10-2005 09:07 PM
Subaru 4-Pot rebuild tutorial? TROLL Brakes, Steering & Suspension 0 10-12-2005 01:01 PM
Wilwood 4 pot vs Subaru 4 pot Jaz_rs Brakes, Steering & Suspension 25 05-13-2004 12:03 PM
Wilwood 4 pot vs Subaru 4 pot BIGSKYWRX Brakes, Steering & Suspension 124 12-09-2002 11:07 AM
