Old 03-28-2013, 12:14 PM   #126
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
well have fun with that. personally i wont risk it.
thats why i ended up re-using the original O-rings when i rebuilt my 4-pots and 2-pots. the o-rings that came out of the rears looked pretty bad, but still sealed fine. the o-rings that came out of the front looked perfect though.
gsrcrxsi is offline   Reply With Quote
Old 03-28-2013, 12:21 PM   #127
darkmist2k1
Member#: 31364
Ver6 Trek and couple
bottle of gatorade 4boost
http://www.freshalloy.com/showthread...-McMaster-carr
and they used viton.. which is not that compatible with brake fluids. The EPDM should be same if not better..
UPDATE: I found AFLAS orings ( kinda expensive imo)
Front:
http://www.theoringstore.com/index.p...ducts_id=11570
Rear:
http://www.theoringstore.com/index.p...ducts_id=11572
darkmist2k1 is offline   Reply With Quote
Old 03-28-2013, 11:47 PM   #128
darkmist2k1
Member#: 31364
Found out that silicone or VMQ is also a suitable material for brake fluids and temperature range from -75F to 450F .. I think this win for compatibility, temperatures resistance, and price.
Front:
http://www.theoringstore.com/index.p...oducts_id=4707
Rear:
http://www.theoringstore.com/index.p...oducts_id=4709
Old 04-08-2013, 10:27 AM   #129
darkmist2k1
Member#: 31364
So i ordered the Centric caliper seal kit, apparently it does come with the SQUARE orings that goes between the calipers but only after 03/2013 (Weird thing is why they gave me 4orings when each package is for 1 caliper). Just want to point this out and share it with the nasioc community.
meanwhile i did have oring on order from the place mention above.. a set in AFLAS, VMQ(silicone) and EPDM.
The one on the left is the part package in 8/2012 and the right is package in 3/2013. BOTH still unopen
Old 04-08-2013, 11:06 AM   #130
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
very nice. glad to see that.
wonder if the centric 2-pot kit is the same.
Old 04-30-2013, 12:41 PM   #131
darkmist2k1
Member#: 31364
Update on my rebuild..
I end up using the AFLAS orings that i purchased from oring store rather than using the square ones that came with the centric kit. Ive also soak them in brake fluids and they kept its shape, size and hardness prior to install. Its been 2 weeks now, and it has no leaks. I've also done some heavy braking on hp+ pads just to get the temperature up and no leaks as well.
Old 05-28-2013, 10:45 PM   #132
northernwrx
Member#: 165099
2006 wrx
how important are the shims http://knsbrakes.com/carSeriesDetail...20.5mm%20Thick
i am doing a install of 2 new front 4 pot calipers but dont have the shims
northernwrx is offline   Reply With Quote
Old 05-29-2013, 07:30 AM   #133
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
You don't need them.
Those are Titanium shims for reducing heat transfer to the caliper.
Old 05-29-2013, 10:02 AM   #134
northernwrx
Member#: 165099
2006 wrx
thanks so much, i guess i can always install them later if i think they are needed.
Old 05-29-2013, 10:42 AM   #135
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
i dont use any shims at all. the only shims on there are the shims/plates that come attached to the StopTech SP pads
Old 05-29-2013, 10:58 AM   #136
northernwrx
Member#: 165099
2006 wrx
thats really good info because i have the same pads purchased for my car!
thanks
Old 06-09-2013, 12:20 AM   #137
monkeyposeur
Member#: 333468
1993 SS
2003 WRB WRX 205/22T
Thanks for the DIY! I just acquired some JDM STi ver 6 brakes and used your post to dismantle them.
monkeyposeur is offline   Reply With Quote
Old 06-09-2013, 07:31 AM   #138
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
some of us are smart enough to use the shims because they help keep the brake fluid from boiling...heat shields ya know
Old 06-09-2013, 12:24 PM   #139
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
For someone who's all about practicality and not wasting money on "because racecar" items and being "k00 n s hit", it would really surprise me if you actually use those shims.
You see.
1. You should be using a better more heat tolerant brake fluid anyway if you're worried about heat. And since you're all over ATE's nuts in every single brake fluid thread, I'll assume you are.
2. These are really only needed in a track racing scenario, when you are actually putting enough heat into the brakes to even get to the boiling point of your upgraded fluid.
3. You've stated to get over 50k miles on a set of STSP pads, so you're obviously not driving harder than a grandma. And obviously not subject to point #2. Plus we all know you dont go anywhere near a track.
So quit the BS Scotty.
OP, if you want to waste your money on Ti shims for street driving, go ahead. Just know that unless you plan to track your car, you'll never see the benefit.
Old 06-10-2013, 08:05 AM   #140
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Wow. How drunk are you? Isn't it only like 6am there?
I drive harder than you, I've never boiled fluid. The shims are not needed at all for street driving. Hell look at the KNS link up there. The description clearly says "on the track" multiple times. Better fluid would be a more appropriate use of funds.
Edit: I see a mystery mod has done some cleanup. Thank you
Old 06-19-2013, 06:38 PM   #141
Mechie3
Member#: 120152
Square o-rings are simply designed to allow for more axial misalignment. Sealing with square rings can be slightly lower due to a larger contact surface and thus lower pressure across the face of the o-ring. It's almost negligible.
I just bought the Z1 kit (all 4 calipers). Rear caliper kit came with round o-rings, the front kit came with square o-rings.
Mechie3 is offline   Reply With Quote
Old 06-21-2013, 10:13 PM   #142
mlthomas
Member#: 344284
2004 Impreza WRX
Nice write-up!! I've been looking into purchasing 4 pots, and more than likely used just b/c of cost, and i'll prob end up rebuilding then. This will help for sure.
mlthomas is offline   Reply With Quote
Old 06-24-2013, 08:39 AM   #143
rjs1022
Member#: 341952
2007 WRX
Anyone have the part # for 4 pot caliper pistons?
rjs1022 is offline   Reply With Quote
Old 07-01-2013, 01:49 AM   #144
Dominator
Member#: 156712
1991 Legacy SS
Pearl White
I just looked it up the other day, here you go.
OEM Number: 26236FA010
Dominator is offline   Reply With Quote
Old 11-19-2013, 05:13 PM   #145
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
In case anyone was wondering about this, no, the 2 pot kit only has boots and piston seals.
flyboymike is offline   Reply With Quote
Old 06-27-2014, 04:33 AM   #146
Eww Evo
Member#: 299687
TT3
06' Wrx Project
This thread is exactly what I needed, thanks!
Eww Evo is offline   Reply With Quote
Old 07-12-2014, 11:53 AM   #147
BoostinChick
Member#: 218971
2007 WRX
Found this thread as well in a dire need since my passenger caliper had a seized piston. Very useful, thanks much guys!! I purchased the Subaru parts, but also picked up the Centric kit for half the cost to keep as a spare. I can't believe how easy these are to rebuild compared to Brembos!
BoostinChick is offline   Reply With Quote
Old 10-06-2014, 06:30 PM   #148
Sandstorm27
Member#: 290437
06 WRX limited
This DIY was awesome, huge help. One question I have is that two Pistons were totally wrecked. I ordered two from CARiD and while they're the same size, the imprints on the bottom are different (the aftermarket Pistons don't have the three raised circles - they have flat bottoms) and they weigh slightly different (OEM is 5.1 oz vs 5.3 for aftermarket). Do you all think the new ones are usable or should I order two more from Subaru?
Sandstorm27 is offline   Reply With Quote
Old 10-06-2014, 06:34 PM   #149
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
As long as the new ones are the same in size and dimensions I think you will be all set.
Do you own a micrometer? If not harbor fright always has the cheap 9 dollar digi ones. Or be a baller and get a good one.
sackytar is offline   Reply With Quote
Old 01-04-2015, 06:01 PM   #150
darkmist2k1
Member#: 31364
Just want to update/document this, 04/2013 rebuild my 4/2 pots. I used custom material o-rings material between the halves since some kit does not provide them. (AFLAS is the material name). January 2015, and the calipers are still good. Done 2 brake pads changes, 2 fluid changes(ATE blue and then yellow).
RacingBrake 4-pot Calipers: 50% lighter than Subaru 4-pot & fit under OEM WRX Wheels! AZP Installs Tri-State Area Vendor Classifieds 20 12-11-2012 03:27 PM
Subaru 4-pot Piston Removal/Rebuild JayGold Brakes, Steering & Suspension 12 11-10-2005 09:07 PM
Subaru 4-Pot rebuild tutorial? TROLL Brakes, Steering & Suspension 0 10-12-2005 01:01 PM
Wilwood 4 pot vs Subaru 4 pot Jaz_rs Brakes, Steering & Suspension 25 05-13-2004 12:03 PM
Wilwood 4 pot vs Subaru 4 pot BIGSKYWRX Brakes, Steering & Suspension 124 12-09-2002 11:07 AM
