Old 11-12-2005, 03:01 AM   #1
whiteryce87
Member#: 90810
Question Check Engine Light leads to different error codes each time
I have an 01 legacy that keeps having the check engine light come on. The error code readout reads missfire valve 1, then i reset it. Like almost a week later the light came on again. This time the code was missfire valve 4, i reset it and went on my way. Well then like 4 days ago the light came on again and the code was valve 1. Do u have any idea what may be going on with my car?
whiteryce87 is offline   Reply With Quote
Old 11-12-2005, 09:04 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...post the codes.....as in '"Pxxxx"....seems like ya got a random issue with the passengers side of the engine.
Old 11-13-2005, 12:47 PM   #3
rick-l
Member#: 33868
2003 wrx
srp
Is this a wasted spark ignition where there is one coil for two plugs? Are cylinder #1 and #4 on the same coil?
Hope it's the coil, wires or broken plug and not the ECU
rick-l is offline   Reply With Quote
Check Engine light, AP says no cel codes kingypoo AccessPort 12 07-09-2011 03:12 AM
Check Engine light is on but no code wtf nikiSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-04-2010 12:16 AM
Check engine light on.... car throws two codes. Why!!!! subie_nation Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 02-18-2009 03:11 AM
Check engine light 150 miles after having water pump/timing belt replaced Dural Service & Maintenance 1 06-29-2008 05:21 PM
how eliminat the check engine light due to a high flow exhaust or a catless exhaust minisiu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-13-2002 03:28 AM
