11-12-2005, 10:41 AM | #1 |
Member#: 100541
Vehicle:2005 WRX |
05 hesitation under hard throttle
Hello all, I've had an 05 wrx for over a year. Yesterday I did matched-revs down shift from 5th to 4th and nailed the throttle to get out of the way of an emergency vehicle. The car bogged HARD-seemed as if power went away completely, then came back on. Unfortuately I had lifted when this happened, so I don't know what would have happened if I stayed at WOT. Looked through the 2.0 l turbo thread about det., but I'm not sure if I have the same issue. Car seems to run weird at times. I rarely get on it that hard, or take it above 5k. Car is bone stock, 93 octane, ambient temp was ~40deg. Thanks for any help.
11-12-2005, 11:07 AM | #2 |
Member#: 35584
South East
Vehicle:1965 FFR Roadster Coyote + TR-6060 |
Wirelessly posted (Treo 600: Mozilla/4.0 (compatible; MSIE 6.0; Windows 95; PalmSource; Blazer 3.0) 16;160x160)
When exactly was the hesitation? If it was imediately after you release the clutch, it could've simply been the a combonation any number of things like: turbo lag, hesitation of the computer, bad gas or something causing detonation... which in turn caused the computer to retard timing, your air filter needs replacement, your fuel filter is clogged or needs changing, etc, etc. You see where I'm going with this? It's hard to diagnose a problems that includes so many factors. The first steps should always include making sure everything is maintained correctly. If that doesn't fix it, bring it somewhere where they can more acurately diagnose, like the dealership. You've got a waranty Just one person's opinion. |
11-12-2005, 11:24 AM | #3 |
Member#: 100541
Vehicle:2005 WRX |
Thanks for the reply. Air filter is new, fuel filter is original, so perhaps that's a thought....The 'bog' did happen when I released the clutch, just felt very weird, scared the heck out of me. Almost as if the motjor just stopped for a second, then wound back up. hmmmm, bizzarre. Any other thoughts, comments?
11-12-2005, 11:47 AM | #4 |
Member#: 67518
NESIC
Vehicle:2013 Focus ST TB |
Its the stock EM
11-12-2005, 11:58 AM | #5 |
Member#: 100541
Vehicle:2005 WRX |
Factory EM is what it felt like to me, if that makes any sense. Any stock fixes? Haven't approached the dealer yet.... Wondering if there is a factory reflash or some such thing. Thanks for the help guys.
11-12-2005, 03:36 PM | #6 |
Member#: 54203
NESIC
nope, no factory fixes, they made it that way for a reason (emissions). reflash is your only option at this point really.
11-12-2005, 04:06 PM | #7 |
Member#: 17979
Vehicle:335i Blue |
yeah this happened to me to for the first time last week. There is a thread somewhere on here that talks about this in detail. I just swing through the 4800-5300 rpm band to avoid it
11-12-2005, 04:07 PM | #8 | |
Member#: 17979
Vehicle:335i Blue |
11-12-2005, 04:39 PM | #9 |
Member#: 100541
Vehicle:2005 WRX |
I know, I should be winding this thing out a bit more....I guess I was thinking that the motor would last longer if I carried fewer revs, and know that I may have some sort of problem, I'm even less likely to do so-don't want to unload the motor due to det. or something...but I should be able to have fun with this thing, thats why I bought it.
11-12-2005, 07:47 PM | #10 |
Member#: 69621
TXIC
Vehicle:05 mines wrx RIP still hatin ROTAS |
its the OL/CL crossover. Em is the only way to fix it.
11-12-2005, 07:51 PM | #11 | |
Member#: 17979
Vehicle:335i Blue |
11-12-2005, 08:14 PM | #12 |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
Did the check engine light come on after this happened? Does it still continue to drive like crap? How high did the RPM's go? It sounds like you could have put it into safe mode, due to the higher RPMS.
11-12-2005, 08:32 PM | #13 |
Member#: 100541
Vehicle:2005 WRX |
No check light, I think the revs only climbed to ~5200, maybe 5500. Not high really, because I did lift when it bogged; just surprised me, so I jumped out of it.
Thinking of having the ecu flashed-a conservative tune if possible. Thank you to everyone for their help |
11-13-2005, 07:53 AM | #14 |
Member#: 67518
NESIC
11-13-2005, 11:01 AM | #15 |
Member#: 100541
Vehicle:2005 WRX |
Yeah, the Cobb thing sounds sweet; thanks for the link. I'd be interested in paying someone to upload a map as opposed to shelling out $600 for my own unit. I'm not interested in tuning the motor (I'm a suspension/chassis guy), just like a conservative map that addresses this issue. If there is anyone in the Rochester, NY area that does this, let me know.
11-13-2005, 11:45 AM | #16 |
Member#: 54203
NESIC
MaxFy,
The way the accessport works, no one can just "upload" a map and let you use it. The accessport "marries" itself to your ECU. |
11-14-2005, 03:30 AM | #17 |
Member#: 85227
VIC
Vehicle:2005 STI Silver |
I have a similar problem with my 02 WRX. Coming out of a corner and accelerating, I get this in 2nd gear at roughly 6500 rpm, and 3rd gear at roughly 4500 rpm. It basically feels like the engine hits a brick wall, and then comes back 1s later. I noticed this started to happen after I installed an ACT clutch and flywheel, but wrote it off as coincidence. At first, it only happened once in a while, but recently it became worse... but then better again... go figure. I have roughly 75,000 kms on the car. I have not changed the fuel filter so that is what I was thinking. Air filter is clean.
Can the dealer fix this under warranty? |
11-14-2005, 07:37 AM | #18 | |
Member#: 100541
Vehicle:2005 WRX |
11-14-2005, 09:17 AM | #19 |
Member#: 17979
Vehicle:335i Blue |
I wonder if any damage is being done during that bog... it doesn't sound like it would be good for the drivetrain or existing EM
12-03-2005, 12:56 PM | #20 |
Member#: 95780
SCIC
Vehicle:2008 Infinity G37S Ivory/Black |
I had the same problem yesterday, in 3rd getting on the freeway, let it loose to get around a slow car and I was waiting for my subie to really start moving, I had my neck braced and it never came, then right around 5200, it shot off like a bullett...... so strange, it was doing it all day till I came home, reset and took it out, runs fine now. 2.5 Catless TBE is my only mod.
What it boils down to is....I need an Access Port..... |
Hard shift from 1st to 2nd under light throttle in a 04 Baja Turbo with 4eat | 440racer | Transmission (AT/MT) & Driveline | 4 | 05-20-2008 04:59 PM |
stock 02 wrx wagon hesitates and cuts out under hard accelleration | gregsmith | Newbies & FAQs | 0 | 03-01-2006 05:44 PM |
Hesitation under light throttle 2400-3000 rpms | RunForest | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 10-02-2005 10:24 PM |
under hood chattering under part-throttle boost | beauhawk | Engine Management & Tuning | 4 | 09-23-2004 09:06 PM |
Hesitation under light throttle. | mightbewrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 35 | 07-11-2003 02:27 PM |
