#1 |
Member#: 89560
E. Canada
I just picked up a set of NGK Iridium spark plugs.
The gap on the stock plug BKR6EIX is 0.030 What is the correct gap on the BKR7EIX (1 step colder)? I'd like to check the gap before installing them ![]()
#2 |
Member#: 25905
SCIC
Vehicle:2003 Silver Wagon Tuned with Enginuity |
Same gap. You could go 0.028 if it misfires under high rpm and load.
#3 |
Member#: 89560
E. Canada
I did a little searching on NGKSparkPlugs.com and I believe the BKR7EIX come pre-gapped to 0.025 (based on a 1994 AUDI S4 2.2 Turbo which use the same plug)
I guess I'll just gap them to 0.028 |
#4 |
Member#: 25905
SCIC
0.025 should be OK, too.
#5 |
Member#: 72263
SCIC
Vehicle:2008 Impreza STi Dark Grey Metallic |
does having a smaller gap have a negative effect on its performance or cause any risk to anything?
#6 | |
Member#: 64974
Vehicle:1995 WRX,APEXi,HKS,$ Faded, Stonechipped Red |
Under extreme load/boost a smaller plug gap is mandatory. The reason for this is the higher the pressure, the more voltage required to jump the gap. (That's why there's always more lightening waay up in the sky than there is down here! ). Also, the leaner the mix, the harder it is for the spark to jump the gap, (more Volts Required). Normally the electrons use the molecules of fuel as a conductor, lowering the resistance and therfore the required voltage to get the 'spark' across the primary and ground electrodes. Anyway, if you gap them TOO small, then there is insufficient 'spark face', (basically there is not enough 'match' to light the fuel). So, in short, that is why FHI have spent the money and time finding out that 0.8mm, (sorry about the metric ), was the optimum for both, (for std conditions). I have run 0.7mm for years in modified EJ series Engines of all descriptions without issue. Hope this helps, Sixpack Subaru |
| Thread Tools | |
| Display Modes | |
| Iridium spark plugs - is the iridium just on the very tippy-tip tip | Carlito2002WGN | Newbies & FAQs | 5 | 03-12-2010 12:14 PM |
| Spark Plug Question NGK BCPR7EIX | drkwtsn | Service & Maintenance | 2 | 01-19-2005 10:09 PM |
| spark plug gap NGK Iridium plugs? | SeaRex | Factory 2.0L Turbo Powertrain | 14 | 09-12-2004 09:49 PM |
| Which NGK iridium spark plug # for 2.5 liter? | JSiwek | Normally Aspirated Powertrain | 5 | 04-19-2002 11:28 AM |
| ('93-'01) NGK Iridium IX Spark Plugs... | STi21 | Impreza Forum | 5 | 07-27-2001 02:31 PM |
