Old 11-13-2005, 08:03 AM   #1
chucktoo
Member#: 59539
2005 Outback 2.5 XT
Default Convert 5x100 to 5x114.3 P.C.D.
Has anyone converted the old style STi /WRX hubs from 5x100 to 5x114.3 bolt circle without swapping hubs axels and the like ?
Is there enough material in the hubs to add an extra set of stud holes on the larger bolt circle in between the existing holes ?
I don't mind changing rotors to 5x114.3 .
There are many more wide wheels available in 5x114.3 than 5x100 .
chucktoo is offline   Reply With Quote
Old 11-13-2005, 02:19 PM   #2
Crawdads
Member#: 30907
SWP GDB-G
Besides the wider selection of wheels, the main advantage of the large STi hub is the larger/stronger bearing. If you need the wider wheels that badly (lots of autocross?) the larger bearing would be a good upgrade for you anyway.
Crawdads is offline   Reply With Quote
Old 11-13-2005, 08:48 PM   #3
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
http://forums.nasioc.com/forums/showthread.php?t=777998
driveshaft shop has made some axles that are r160 inners(diff side) and r180 outer sections(hub side). you can give that a shot, but you would also need to change the front struts as the connection from the coilover to the hub are different(to accomodate the wider 05 hubs).
Now that I think about it, I'm not too sure if the 05 rear press in hubs will fit in r160 hubs. Approximate cost from the dealership for front and rear hubs with all parts~1500. If you know someone at the dealership, maybe 1300. If you use subaru bucks, basically take another 25% off which makes it a little under 1000.
petawabit is offline   Reply With Quote
Converting 5x100 to 5x114.3 '08 WRX Pstl_Pete Brakes, Steering & Suspension 3 08-08-2009 12:31 PM
Converting 5X100 -> 5X114.3 wanalaugh74 Tire & Wheel 5 02-01-2008 12:48 PM
kics project hub converter 5x100 -> 5x114.3 wrxtremeWGN Tire & Wheel 28 12-07-2007 02:14 PM
What do you think of spacers to convert 5x100 to 5x114.3 ? Legacy Tire & Wheel 11 05-03-2007 02:05 PM
Can we convert 5x100 to 5x114.3? awdlifestyles Subaru Conversions 1 04-01-2005 07:02 PM
