Old 11-13-2005, 02:00 PM   #1
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
Default Installing 2002 WRX cd-changer in 2005 RS....
I know the harness will plug right in, but are there any mounting brackets needed? All I have is the cd-changer and mounting screws, no brackets or anything, like this picture:
I'm selling this to someone with a 2005 RS, and I want to make sure I'm not sending him something he can't install correctly. Thanks!
-E
e11ys is offline   Reply With Quote
Old 11-13-2005, 03:24 PM   #2
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
ya, you need the mounting brackets that go on the sides of the radio. Althgouh, the person your selling it too might have them as well with his stock radio.....
vipernj is offline   Reply With Quote
Old 11-13-2005, 03:47 PM   #3
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
He already has the stock 2.5 RS radio. Can you use those brackets for the cd-changer?
Old 11-13-2005, 03:54 PM   #4
minerva1856
Member#: 79000
Ver8 EJ207
I tried to do this once before( 02WRX 6disc ---> 05 TS). The antenna, harness etc didn't match like I expected. Are you sure it's a clean swap? There was a difference in the in-glass antenna etc
minerva1856 is offline   Reply With Quote
Old 11-13-2005, 04:32 PM   #5
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
That seems to be the general consensus from the searching I've done, but I may be wrong. What did you do to get it to fit? And again, does anyone know if the brackets from the RS radio will work for the cd-changer?
Old 11-13-2005, 04:40 PM   #6
minerva1856
Member#: 79000
Ver8 EJ207
I didn't get it to fit. I didn't have the interest in fabbing a connector either. I wish I could direct you to a complete solution that works. But rest assured this will NOT work with the existing connectors. Brackets on the other hand ought to be just fine.
Old 11-13-2005, 04:45 PM   #7
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Originally Posted by wrx580
... are there any mounting brackets needed? All I have is the cd-changer and mounting screws, no brackets or anything ...
All Impreza/WRX's from 1993-up have used the same 14-pin radio harness with the same pin-out.
Or to put it another way, if your radio has a single, 14-pin connector for speaker/power then it has this pin-out.
In some cases you'll need to add a 12" to 18" extension cable for the coax antenna wire to reach the back of the radio (the antenna jack on earlier Subaru radios was at the end of a ~17" pigtail).
The buyer should use the mounting brackets that came with his car. If he no longer has those, he'll need to get replacements (try a junk yard, or http://subaruparts.com).
There's a small chance that your brackets would work in his car, but you should keep them (and the screws) to use in your own car. Generally, after-market radios don't include the screws, so you have to re-use what was originally in your car.
SVXdc is offline   Reply With Quote
Old 11-13-2005, 06:22 PM   #8
e11ys
Member#: 77106
'02 Brodozer
'11 Outback 3.6R
Okay, this completely contradicts what the other person was saying, although you do sound like you know what you're talking about. He does have his stock radio, so I guess mounting won't be a problem. Can anyone else clear this up, or verify that the 2.5 RS radio harness will, in fact, plug right into the 2002 WRX Cd-changer?
Old 11-13-2005, 11:48 PM   #9
minerva1856
Member#: 79000
Ver8 EJ207
The harness from the RS will plug into the Changer from the wrx. The antenna lead from the WRX is different than the antenna lead from the RS cause it's an in-glass style. You will have to make an interconnect like the previous poster said.
Old 11-30-2005, 03:41 PM   #10
Subie2
Member#: 14750
2007 Element SC
Root Beer Metallic
Since when does an 02 wrx have an in glass antenna? Mine sure doesnt. Or does the RS have the in glass antenna?
Subie2 is offline   Reply With Quote
Old 11-30-2005, 03:55 PM   #11
MidnightBlackPearl
Member#: 83751
2015 BRZ
Ice Silver Metallic
The RS doesn't, or at least mine didn't, so I don't know
MidnightBlackPearl is offline   Reply With Quote
Old 12-01-2005, 02:09 PM   #12
05RS
Member#: 79944
my 2005 RS has an in glass antenna
05RS is offline   Reply With Quote
Old 12-01-2005, 05:06 PM   #13
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
All the '04 and later Imprezas have an in-glass amplified antenna. In order for it to work correctly, there is an extra lead that needs to be connected to switched +12V to power the antenna. This should already be connected in your recipient's car, but if not, there are a number of threads describing it (including ones in the forum sticky, I believe).
2002 WRX CD Changer question (also gen. maint.) jburk Car Audio, Video & Security 3 04-13-2004 12:43 PM
WANTED: STOCK 2002 WRX 6 Disc In Dash CD Changer/Head Unit clsmooth71 Bay Area Impreza Club Forum -- BAIC 11 04-24-2002 04:30 AM
WANTED: Stock 2002 WRX 6 Disc In-Dash CD Changer/Head Unit clsmooth71 Southern California Impreza Club Forum -- SCIC 7 04-23-2002 06:18 PM
WRX Radio/CD changer in a 2001 RS gaylemd Mid Atlantic Impreza Club -- MAIC 2 07-27-2001 11:18 AM
Anybody put a WRX CD changer in a Legacy? dvancleve Car Audio, Video & Security 3 06-04-2001 12:16 AM
