Old 11-13-2005, 04:31 PM   #1
mrtrex
Member#: 12223
2005 WRX
Default What do I need to adjust on my EM to run the GM Boost Solenoid
I am getting tuned next tuesday and I am installing this right before I go. I want to give the tuner a heads up. What areas are going to need to be changed in order to adapt with this mod.
mrtrex is offline   Reply With Quote
Old 11-13-2005, 06:49 PM   #2
BigBoosting
Member#: 48553
If you have UTEC you need to adjsut the boost map.
Its going to have to be drastically different than the stock boost map, jsut have to play around with it and drive, and repeat.
BigBoosting is offline   Reply With Quote
Old 11-13-2005, 06:58 PM   #3
mrtrex
Member#: 12223
2005 WRX
I am going to be running the Cobb AP. I am going to have it protuned next tuesday. I just want to know what to tell the tuner to look at.
Old 11-13-2005, 08:19 PM   #4
BigBoosting
Member#: 48553
I dont know about the AP, but i know if your gonna be isntalling it on your car before the tune that is a really bad idea. The stock boost maps with the GM solenoid installed will cause you to make tons of boost, something like 20+ psi. better not boost until you get it tuned
Old 11-13-2005, 08:30 PM   #5
mrtrex
Member#: 12223
2005 WRX
I will be installing it right before I go on the dyno
Old 11-14-2005, 11:49 AM   #6
quazimoto
Member#: 70395
It takes like 15-30 min to install,why not just do when you get up there or have them install it real quick.
quazimoto is offline   Reply With Quote
Old 11-14-2005, 12:00 PM   #7
TheMadScientist
Member#: 23717
2005 Big red
Temp comp maps, High and low WG duty cycle maps, fine and coarse gain maps all need to be adjusted for the GM solenoid.
TMS
TheMadScientist is offline   Reply With Quote
advantages of the gm boost solenoid? ultramagnus Newbies & FAQs 5 08-26-2007 02:25 AM
Anyone running the perrin Boost solenoid? scooby-stu Engine Management & Tuning 3 09-17-2006 09:09 PM
What's the GM boost solenoid part # Henryk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-14-2006 04:32 PM
When installing the GM Boost Solenoid do you keep plastic restrictor in Vacume Line mrtrex Engine Management & Tuning 3 11-13-2005 12:16 PM
What do I need before I turbo my car? IBO Normally Aspirated with bolt-on Forced Induction Powertrain 26 09-06-2001 04:03 PM
