Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 11-06-2005, 02:30 PM   #1
xsmooth69x
Member#: 99220
2000 impreza rs
clear
Question i need help!!!!
my car runs horrible after a little (not really a wreck but when i was rallying i slide off the road and into a dirt ditch gave my car a good raddle) wreck. when i start my car now it idles at 2g and when the engine warms its normal. thought it was the spark plugs but i have platnium ngk plugs there still good replaced the wires with magnacore wires. still crappy i brought it and got codes pulled and there is a p0141 and p1133 problems the p0141 is the o2 sensor heat bank 1 sensor 2 the other p1133 is my question i cant find anything on this. but im thinking its an exhaust issue i have a custom stainless exhaust on my car, no cats so is that the p1133 code? i have a 2000 impreza rs custom turboed
side note (ever since i had the lil golt when i start my car i can smell exhaust in my cabin idk if that has anything to do with anything. maybe my wastegate is messed up? i really dont know much about my car yet or a turboed system please help me) thanks adam
xsmooth69x is offline   Reply With Quote
Old 11-06-2005, 02:39 PM   #2
NRTmotorsports
Member#: 16517
'13 BRZ
Code P1133 is a Front Oxygen sensor high input, could be in relation to the P0141 code you are getting. Sounds like you may have an exhaust leak if youcan smell exhaust fumes, you could have bent an exhaust pipe and caused a leak. Not really sure why it would be idling high, but then again you do have alot of aftermarket stuff with the turbo and all, not real sure why you do have a high idle. Well i'm not to much of a help so maybe someone else has some input. Good Luck
NRTmotorsports is offline   Reply With Quote
Old 11-06-2005, 09:32 PM   #3
xsmooth69x
Member#: 99220
2000 impreza rs
clear
man im so confused so thats a front o2 sensor? another web site said a fuel sensor curcuit respnce? dose that mean o2 sensor? and were are both these sensors i have to replace located so i can replace them. thanks adam
Old 11-06-2005, 10:14 PM   #4
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Um, not sure where you live but there's this thing called cold start idle where the idle is higher until the engine warms up.
z is offline   Reply With Quote
Old 11-06-2005, 11:32 PM   #5
xsmooth69x
Member#: 99220
2000 impreza rs
clear
ow no no i live in florida there isent coldness lol
Old 11-07-2005, 10:14 AM   #6
z
Member#: 41762
04 STi
Well it wasn't exactly "cold" here this morn, but I did think about it so I took a look and my car idled at 1500 for a while, then dropped to 750.
Old 11-07-2005, 04:39 PM   #7
xsmooth69x
Member#: 99220
2000 impreza rs
clear
when my car has bine siting in the sun for the longest time and i start it, it still idles at 2g until it "warms" up so my o2 sensors replace both of the? and thats the 2 codes?
Old 11-08-2005, 03:06 PM   #8
xsmooth69x
Member#: 99220
2000 impreza rs
clear
bump!!!!! ^_^ so these 2 codes p0141 and p1133 what exactly are they and what measures do i have to take so my car will stop throwing these codes? do i have to replace o2 sensors or whats goin on? am i damaging my engine when i keep on driving my car like i am now
Old 11-08-2005, 08:17 PM   #9
z
Member#: 41762
04 STi
I tried to look them up for you but they're not in the 04 manuals.
Did you swap out the ECU for a turbo ECU? if so, what year?
Maybe someone else can look it up.
Bump for help.
Old 11-09-2005, 07:41 PM   #10
xsmooth69x
Member#: 99220
2000 impreza rs
clear
ow i have a 2000 impreza rs its n/a and i turboed it stock ecu. thanks adam
Old 11-10-2005, 02:44 PM   #11
xsmooth69x
Member#: 99220
2000 impreza rs
clear
bump.......
Old 11-12-2005, 12:48 AM   #12
xsmooth69x
Member#: 99220
2000 impreza rs
clear
bump no one knows?
Old 11-12-2005, 09:14 AM   #13
z
Member#: 41762
04 STi
Old 11-13-2005, 06:28 PM   #14
xsmooth69x
Member#: 99220
2000 impreza rs
clear
yup p1133. also like i have a after market knock retard sensor and now when i lay on the gas it knocks 2-6 degres. my engine when u start it is so ruff what should i do anyone
Old 11-13-2005, 07:48 PM   #15
z
Member#: 41762
04 STi
^ did you click on the link right in my last post?
First off, check the wire that goes to the o2 sensor and make sure it didn't get ripped off. and just check the
Need Help, Need Help nicholas112481 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-10-2010 01:24 PM
Need help!! Need to find a +12v switched wire NOW! Please help! nxwrxfx Electrical & Lighting 16 04-25-2006 05:29 PM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
