Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-13-2005, 05:04 PM   #1
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
Default Pictures anyone?
if possible could everyone post pics of thier engine bays? Preferably where the turbo sits etc, Also does anyone have a pic of what coolant lines they tapped for their turbo? thanks
-cameron
2.5 Blue Roo is offline   Reply With Quote
Old 11-13-2005, 05:57 PM   #2
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
I dont have any pics with me but as far as the coolant lines, I would "T" the ones that go to the heater (Use the one that goes in as inlet for the turbo and the one that comes out as a return line) If you need to take a look at an engine bay... and you are around the Rockville area one night PM me and I'll meet with you.
maxiav is offline   Reply With Quote
Old 11-14-2005, 01:31 AM   #3
buhrietoe
Member#: 39280
2001 Impreza 3.0RSR
2004 STi
you dont HAVE to run coolant lines, just be sure to let it cool after a hard run. I have a T04E w/ no coolant lines run and about 40k on turbo and its fine with virtually no shaft play.
buhrietoe is offline   Reply With Quote
Old 11-14-2005, 08:26 AM   #4
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
Turbo Timer Itll cool it down for you
WallyKincaid is offline   Reply With Quote
Old 11-14-2005, 10:22 AM   #5
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Mine is oil cooled.... and I do have a Turbo timer... but I'd switch to a watercooled turbo anytime....
If the turbo is water cooled... just "T" the lines... it will take you less than an hour...
Old 11-14-2005, 11:48 AM   #6
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
Cant you run both, oil and water? I was going to run both but my friend told me its not worth the hassle right away, just to go oil.
Old 11-14-2005, 11:57 AM   #7
maxiav
Member#: 40413
2001 BRP RS-T EJ257
You run both... and its no hassle. You need the oil lines no matter what, and once again, the coolant lines is only two "Ts" from Home Depot and a chunk of hose. Shouldn't take you more than an hour to do this.
Old 11-14-2005, 12:21 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
heres a few of mine
Old 11-14-2005, 03:05 PM   #9
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
Is the steel cable over your intake the oil line? I have to get oil lines made for my set up and dont know how long, what they look like where to go etc...
Old 11-14-2005, 05:48 PM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
nah thats my power steering line
i wouldnt make the line any longer than a foot
and get the ISR oil feed kit, if they still have it available
if they dont, pull the plug thats in the oil feed now, drill it, and insert a fitting you can use to connect to an oil line
Old 11-14-2005, 07:55 PM   #11
Tats
Member#: 5692
WTF? YES! I am
better than you!
Crappy pic of what you're looking for but here:
Tats is offline   Reply With Quote
Old 11-19-2005, 01:22 AM   #12
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
any pics of oil line setups? preferably SS oil lines...thanks!
Old 11-19-2005, 11:23 AM   #13
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
I used 3ft of -4 SS line. An oil restrictor line (search) and it plugs into the oil galley plug below the throttle body. You can get a replacement plug from Subaru for the oil pressure sending unit to use.
Chad
93 2.0L
subachad is offline   Reply With Quote
Old 11-19-2005, 11:57 AM   #14
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
-Brett
ExecNav is offline   Reply With Quote
Old 11-21-2005, 06:13 PM   #15
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
This is what I have currently, I can get better pic's if need be. I ran the heater core output into the turbo then out of the turbo and back into the engine. This allows me to use the heater core to help shed some heat.
You can see where I tapeed into the heater lines to cool the turbo, all I used were two t fittings and some hose.
CUNNINGHAM is offline   Reply With Quote
Old 11-22-2005, 07:52 PM   #16
buhrietoe
Member#: 39280
2001 Impreza 3.0RSR
2004 STi
I see you have a parallel fuel setup. Do you have pics of your fuel rail? I want to see!
Old 11-22-2005, 08:59 PM   #17
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
I am running the Perrin 05 STI fuel rails. I had to make some billit adapters. I then re routed the fuel lines under the intake for a cleaner look. I may have some better pics. I will try to find them.
Old 11-23-2005, 11:34 PM   #18
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
nice pics! this is helpin me a lot, thanks, a few more questions, what size is the banjo bolt on the VF-11 turbo (im sure it is the same size as a wrx) also what size is the stock oil return line from the turbo? thanks!!
Old 11-25-2005, 11:40 AM   #19
2.5 Blue Roo
Member#: 45727
1981 Audi Rally Ur
Quattro
anyone?
tinted guague pictures anyone? ultramagnus Interior & Exterior Modification 11 05-18-2007 10:57 AM
LSD rear diff picture anyone supermoose Transmission (AT/MT) & Driveline 1 06-19-2005 10:25 AM
Helix TMIC installed picture anyone? aspenwhitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-13-2005 03:01 AM
HKS and Blitz pictures anyone? Purdue WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-13-2003 11:06 AM
bomex wing pictures???anyone have beobe99 Interior & Exterior Modification 0 11-02-2002 03:14 PM
