Old 11-13-2005, 05:27 PM   #1
ice_bomb
Member#: 37972
2003 Impreza WRX
Question Denso Iridium 0.4mm ??
I have Denso iridium 0.4mm IK20#4 spark plugs.
are these fit 03 wrx?
I have lean codes, do you think I can get rid off the codes by changing the plugs to smaller gap?
Wrx stock gap is 0.7 right?
help.... thanks
ice_bomb is offline   Reply With Quote
Old 11-13-2005, 07:17 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
help.... thanks
....that 0.4mm is the diameter of the center electrode....NOT the gap.
....they will fit an '03 wrx
....yer lean code is NOT caused by the plugs....an intake(leak) most likely.
....proper gap will be 0.7mm - 0.8mm
BEWARE gapping these plugs....if you do not do it EXACTLY the way it is supposed to be done, you will DESTROY them.
You can NOT touch the center electrode with ANY force or you will break it off.......ask me how I know this.
Old 11-13-2005, 07:48 PM   #3
ice_bomb
Member#: 37972
2003 Impreza WRX
Ok, so what is that 0.4mm in my plugs?
before i get more confused, what is gap exactly?
I have stock intake. I dont think there is any leak.
Old 11-13-2005, 08:26 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....proper gap will be 0.7mm - 0.8mm.....0.028"
Old 11-14-2005, 12:39 AM   #5
ControlFreak
Member#: 99200
Gap is the space from the center electrode to the ground arm. Or simply the gap inbetween the thing in the middle and the little arm on the top.
ControlFreak is offline   Reply With Quote
Old 11-14-2005, 06:38 PM   #6
ice_bomb
Member#: 37972
2003 Impreza WRX
is it always necessary to gap the plugs each time changing them?
I thought it's always like 'plug ang play'
Old 11-14-2005, 08:58 PM   #7
2006STI
Member#: 96540
2006 STI
Crystal Metallic
if your air flow meter is like the newer cars, check your air flow meter. i seen them covered with dirt and dust and cause an incorrect reading to the computer. take out the two screw and with a flash light, look inside and you will see two wires. check them and make sure they are clean and not covered with oil or dirt. if they are, clean them with contact cleaner that can be bought at an auto parts store and put them back.
2006STI is offline   Reply With Quote
Old 11-14-2005, 09:39 PM   #8
ice_bomb
Member#: 37972
2003 Impreza WRX
My A/F reading keep changing.. but most of the time it shows 0.01 and sometimes 0.00.
Is this normal?
When the reading show 0.01, my battery volt goes down. I dunno why.
Sorry I'm noob, just got the car for 2 months.
[B]DENSO IRIDIUM Spark Plugs for 2.0 WRX - $19 SHIPPED!!![/B] Mr. Quick Engine/Power/Exhaust 2 11-28-2007 05:16 PM
Denso Iridium vs. NGK Iridium plugs? Thai Silk Factory 2.0L Turbo Powertrain 5 03-14-2004 03:22 PM
Denso Iridium mitch808 Factory 2.0L Turbo Powertrain 0 10-05-2001 07:37 PM
('93-'01) Denso Iridium Plugs in Your Local Napa Autos? Jason Impreza Forum 1 08-15-2001 02:51 PM
Denso Iridiums Ken General Forum Archive 2 09-08-2000 08:21 AM
Message Board Statistics All times are GMT -4. The time now is 04:34 PM.
