Old 11-13-2005, 08:42 PM   #1
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
Default First AutoX in my STi
Well, the reason I bought my STi was so that I could have a more suited autox car. I just finished a 2 day autox and all I have to say is that I am very impressed. The STi is a fantastic car of the lot and I now know which direction I want to go in to modify it for better handling: first step, JDM pinks and Cusco sways. That's what one of the local guys was running when he won last year's regionals. The body roll is pretty intense and I need some more camber in front for sure. I think after two days my RE070s are about toast so I am going to start deciding which R-comps to run (since I am already in SM).
Another interesting thing ... I think all of my thought process about really small turbos that spool well for autox is somewhat off. When driving autoxs, I am almost always at the top of the rev range for the car. I recorded some runs on my defis and noticed that I never hit full boost and that's mostly because when I shift I am already way past where the small VF39 hits full boost (~3000 rpms on my car). I think I have finally made up my mind for the SZ49 over the 20G.
All in all, a great weekend
Nixlimited is offline   Reply With Quote
Old 11-13-2005, 09:13 PM   #2
theicewall
Member#: 70532
2004 WRX
Here is the thing. You are always on the top of your rev range in autoX, but, you are also on and off throttle with many stabs in between to get the car to act properly. If you go with a very large turbo you will not deal with the lag you get while the car is still pulling through vacuum and the lower rpm band due to the nature of your gear ratio, but you will get lag while the turbo spools at higher rpms in on/off throttle situations. Ideally you should build the car to have a solid midrange and responsiveness as well as a strong top end. You may need something larger than the VF39, but the sz and 20g might be too big.
theicewall is offline   Reply With Quote
Old 11-13-2005, 09:18 PM   #3
nimblegimbal
Member#: 91120
06 WRX ImpWag
Batmobile Black
yup, look at it this way, a laggy setup is still gonna lag to some degree on a dyno no matter where you start the pull, gotta find that happy medium
nimblegimbal is offline   Reply With Quote
Old 11-13-2005, 10:14 PM   #4
vintagemilano
Member#: 92528
2000 2.5RS coupe
blue ridge
I may be wrong..... but I thought SM (street modified) was a street tire class, no R compounds....
vintagemilano is offline   Reply With Quote
Old 11-13-2005, 10:16 PM   #5
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
A 20g is barely bigger than the VF39 and it spools the same. The SZ49 is a medium sized turbo that spools about 300-500 rpms later.
You are wrong, I was beaten by a civic running r-comps in SM today
Old 11-13-2005, 10:36 PM   #6
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
What did you drive before in autoX?
I would pass on a bigger turbo. The torque and gears help the Sti a bunch. Build your car to the class you are comfortable in. SM/STU is an expensive endeavour for an STi.
WRXedUSA is offline   Reply With Quote
Old 11-13-2005, 11:13 PM   #7
KC
Member#: 442
16 SS
00 S2000
SM must run on DOT rated tires. So, yes.. R-compounds 'technically' are street tires.
--kC
KC is offline   Reply With Quote
Old 11-13-2005, 11:29 PM   #8
Nixlimited
Member#: 86730
2005 STi
460 WHP @ 28 PSI
I still autox my other car, it is an E46 M3.
I am already past STU because I have EM (Cobb Pro-tune). I have thought about tuning a stock boost map, but it may raise some eyebrows still. Bottom line, I like to heavily modify my cars so whether or not I will have the best car for SM or not, that's likely where I will end up. It's all about having fun and learning to drive the car better. Hell, I came in 2nd today.
Road trip fuel mileage calculated for the first time in my gt30r STi modaddict North West Impreza Club Forum -- NWIC 11 04-24-2007 06:18 PM
Im going to autoX for the first time in my 2002 WRX, questions jmott Brakes, Steering & Suspension 4 06-26-2001 01:11 PM
First AutoX in the old tank Porter Motorsports 17 02-27-2001 09:30 AM
My first donut in my RS Rick Buckner General Forum Archive 3 08-07-2000 06:36 PM
