Old 11-13-2005, 09:15 PM   #1
STirocket
Member#: 84006
2005 Impreza WRX STi
WRB with Goldies
Default Fumoto Oil Drain Valve Rocks
I know that the Fumoto valve has been discussed before, but I thought I'd share my own first experience with it. Tks to the members here who turned me on to it.
GAWD! I've been changing my own oil for 40 years and just installed a Fumoto oil drain valve (F105) today, and it's SO KOOL!!! This is the first oil change I've done myself on my car. The last one (first oil change) was done by the dealership where I bought my car. So after changing the filter, as I was putting oil back in I got it too full, no problem, I just opened the valve and drained a little back out into the pan. Heh, that's so easy, I may have over filled it on purpose
The valve is a very high quality brass valve housing, with stainless steel valve parts and a spring loaded valve lever that you lift to unlock then turn 90 degrees to open the valve. It came with a green fiber washer that I used instead of the crush washer I bought from the dealership when I bought my filters. I figured if it leaked I'd put the crush washer on. I drove around a little today, and so far no leaks. I'll keep a close eye on it for a month or so, but I think this is going to be a really good thing. I'm actually looking forward to my next oil change... Check 'em out at www.fumotovalve.com.
Rocket's two cents...
STirocket is offline   Reply With Quote
Old 11-14-2005, 07:06 PM   #2
lDeez lNutz
Member#: 94339
2005 STi
i just put mines on yesterday too, i can't wait for my next oil change
lDeez lNutz is offline   Reply With Quote
Old 11-14-2005, 08:25 PM   #3
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
Just installed mine today..Decided to go with the OEM crush washer over the fiber washer.. A few guys at LegacyGT.com have had some seeping with the fiber washers..
I overfilled a bit and it was so nice to just open the valve to drain the .1 qt that I overfilled by..
wrx05 is offline   Reply With Quote
Old 11-15-2005, 01:55 PM   #4
ExitVisa
Member#: 15276
2003 WRX
The fiber washer had started to seep on my WRX so I replaced it with the crush washer, but other than that this thing is great.
ExitVisa is offline   Reply With Quote
Old 11-15-2005, 01:58 PM   #5
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Be careful if you autocross and have a fumoto installed.
thrdeye is offline   Reply With Quote
Old 11-15-2005, 02:39 PM   #6
Wagon Joe
Member#: 34436
No, he must have pressed the oil slick button, to thwart his fellow competitors.
Wagon Joe is offline   Reply With Quote
Old 11-15-2005, 04:16 PM   #7
lDeez lNutz
Member#: 94339
2005 STi
what the hell happened??
Old 11-15-2005, 04:23 PM   #8
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Co driver ran over a cone and it some how opened the valve. Car only ran for 20 feet with the valve open. No damage, but could have been bad if no one had noticed the valve was open.
I got a free oil change out of the deal
Old 11-15-2005, 04:29 PM   #9
lDeez lNutz
Member#: 94339
2005 STi
man you almost had me worried. it's still hard to believe a freakin cone opened that valve, it's hard enough to open with your hands as it is, and the position of the valve is pretty tucked in and above the dust guard...
any damage to the valve?
Old 11-15-2005, 04:48 PM   #10
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Yeah, I think it's a one in a million that it opened it.
No damage to the valve.
Old 11-15-2005, 05:00 PM   #11
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
I plan on get this for my next oil change. I was interested in getting the valve with the nipple. Would you strongly recommend against the nipple if I plan on lowering the car by an 1.25" in the front, and an 1" in the rear or do you think it would be fine. I know the website says no, but is anyone else using this with a lowered ride.
HappyIdiot is offline   Reply With Quote
Old 11-15-2005, 05:00 PM   #12
shwaggin
Member#: 90017
2003 Forester 2.5X
WRC Wim-Wam Shaft
I've had a Fumoto valve on my car for about 18 months now, and I can attest to how simple, reliable, and solid they are. I used the fiber washer and have had no seapage problems, although it sounds like some others have.
As far as the quality of the valve, I actually bottomed out my car on a rock while offroading, hitting the Fumoto valve directly. The impact was strong enough that the oil pan bent, but the valve itself is undamaged - it didn't open and it doesn't leak. To make that clear, the rock hit the end of the valve, not the oil pan, with enough force to bend the oil pan. The only damage to the valve is a small surface scratch.
That does raise the concern that some have about the valve sticking out further than the OEM drain bolt, but Fumoto makes valves with and without nipples, so you can have a shorter valve if need be. But even with the longer one (that I've got), it stood up to my stupidity with no problems.
shwaggin is offline   Reply With Quote
Old 11-15-2005, 05:18 PM   #13
InfamousDX
Member#: 25413
I've had it for about 3 years now... nice for $20.
Old 11-29-2005, 02:44 PM   #14
Jfrankon
Member#: 20254
2010 VW GTI
2013 Outback 3.6R
+1 on both my cars. Good product.
Jfrankon is offline   Reply With Quote
Old 11-29-2005, 03:18 PM   #15
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Indeed the Fumoto does rock. I have one on the Sube and all the Triumphs.
That is pretty amazing to me that your valve opened, but I guess it can still happen no matter how statistically improbable.
specialev is offline   Reply With Quote
Old 11-29-2005, 03:24 PM   #16
2fas4u
Member#: 90691
2005 STI / 2009 STI
they are the faschniscial (sp??) well yeah they rock!
2fas4u is offline   Reply With Quote
Old 11-29-2005, 07:47 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...I just installed my Fumoto on my '06 ......I drilled the valve tab for saftey wire
Old 11-30-2005, 03:57 AM   #18
volkl23
Member#: 39092
2004 WRX STi
Java Black Pearl
I've had it on for around 15k miles now. A lot less messier and is sooo easy! No more looking for the drain bolt when I accidently drop it in the oil pan!
volkl23 is offline   Reply With Quote
Old 11-30-2005, 03:23 PM   #19
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Great idea! I am gonna copy your good idea on my next oil change!
Cheers
Old 11-30-2005, 03:33 PM   #20
poison
Member#: 37678
It's especially handy when your jilted lover or angry co-worker realizes that all they have to do to get revenge is flip a lever...
poison is online now   Reply With Quote
Old 11-30-2005, 03:51 PM   #21
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
Then all I have to do is flip my foot in their ass.
Old 11-30-2005, 04:35 PM   #22
boxxxer
Member#: 84647
Nothing like a no tools oil change! Instead of drilling, I just use a small zip tie that fits in the lever groove.
I've had one on my wife's car and mine for 2 years with no issues. Great product!
boxxxer is offline   Reply With Quote
Old 11-30-2005, 04:36 PM   #23
boxxxer
Member#: 84647
Don't you think you would notice the 5 quarts of oil under your feet?
Old 11-30-2005, 06:05 PM   #24
peterex
Member#: 27021
2015 WRX
Not if the jilted lover or angry co-worker drains the oil into a container...
peterex is offline   Reply With Quote
Old 11-30-2005, 09:11 PM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....andjusthowinthehellaretheygonnaknowaboutthefo okingvalveunlessyouarestoopidenoughtotellthem????? ????????????????????????????????
Fumoto Oil Drain Valve 15% Discount jjjheimer Canada Region Forum 7 11-15-2003 05:07 AM
current Fumoto oil drain valve discount code? bigpaulo Service & Maintenance 16 05-30-2003 03:24 PM
Installed my Fumoto Oil Drain Valve the other day drees Service & Maintenance 0 11-18-2002 01:04 AM
Fumoto Oil Drain Valve Group Buy Ooter Vancouver Impreza Club Forum -- VIC 9 08-16-2002 12:36 AM
10% off on Fumoto Oil Drain Valve hman General Community 12 11-26-2001 10:04 PM
