Old 11-14-2005, 09:18 AM   #1
JDM_Scobaru
Member#: 57809
Default Hesitation when car hits full boost (sometimes)
I recently just discovered that a bolt is missing from my IAC, i check it out, and it turns out that one of those bolts was snapped into 2, and a little chunk is still left in the IAC. This is the only thing that would casue my hesitation, since air,pressure, is going right past the bolt. Does this seem logical, this is the only logical answer I can think of. Sorry if this is confusing. I am going to get a new gasket, try to drill that damn bolt out, and replace with a new one.
Zach
JDM_Scobaru is offline   Reply With Quote
Old 11-14-2005, 11:10 AM   #2
MachinesWRX
Member#: 89484
2005 WRX
CGM
some people say its the switch from open-loop fueling to closed-loop fueling.
this is usually the case on 04-05 WRX.
But i get that feel in my 03. i personally think its the fuel maps taking a huge rich surge to to around 10:1 at the onset of boost. But thats just my guess. A good tune will make this problem go away and get a ton more power. good luck
-Chris
MachinesWRX is offline   Reply With Quote
Old 11-14-2005, 11:35 AM   #3
JDM_Scobaru
Member#: 57809
I have never really thought of the open/closed loop problem. That could possibly be it too. I still think that I get hesitation because of air going through some hole or something.
When is Everyone Else Hitting Full Boost on Their Vf39? stealth06wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 11-19-2007 12:19 PM
Car not hitting full boost. Drowner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-04-2006 07:31 PM
Car bucks when I hit full boost??? 01G_WRX_02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-21-2006 06:59 AM
When are you hitting full boost with stage 2 AccessECU? mpaone Engine Management & Tuning 7 10-15-2004 12:34 PM
my stage 4 txs car builds boost at 3k and doesn't hit full boost till 4100 rpm?? datdudedennis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-25-2003 11:35 AM
