Old 11-14-2005, 01:55 PM   #1
billtrev
Member#: 79160
2011 WRX
Default replace clutch+timing belt+adj. lash=pull engine?
I am planning on replaceing the timing belt 97 OBS. The valve lash adjustment is also over due (117,000mi).When I bought the car (101,000mi) the clutch engagement point was very high(no freeplay at all) since this car has a cable I was able to adjust it. Now it seems that the clutch is starting to slip in 5th gear.
Since I'll be doing all this without a lift (but with air tools and access to a hoist) does it pay to pull the motor completly and do the timing belt and lash adj. with the engine out of the car?
Anything else other than the rear main to replace while the engine and tranny are apart?
billtrev is offline   Reply With Quote
Old 11-15-2005, 10:31 PM   #2
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
havent doen the lash adjust yet but removing the radiator = doing the timing belt in 90 mins I wouldn't pull the motor. On the other hand if you need a new clutch might as well pull it and replace the seals too. I havent done mine (210k miles) but they havent started to leak and the clutch is fine.
May after my first season of rally-x and auto-x I'll need a new clutch or maybe a new motor time for a 2.5 swap yay!
Have fun and be safe.
Rally_wgn is offline   Reply With Quote
Old 11-15-2005, 11:14 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I would prefer pulling the motor. Spend a day and have some fun.
Tim Sanderson is offline   Reply With Quote
Should I replace my timing belt? bhall Legacy Forum 15 09-08-2005 10:57 AM
When do I replace my timing belt? playerone Vancouver Impreza Club Forum -- VIC 2 10-27-2004 08:29 PM
So has anyone replaced a timing belt on a dohc ej25 lag Service & Maintenance 2 04-25-2004 02:40 AM
Has anyone replaced a timing belt on a dohc ej25? lag Legacy Forum 2 04-20-2004 11:03 AM
When did you replace your timing belt? Kalins1 Technical Forum Archive 2 07-27-2000 10:02 AM
