Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 11-14-2005, 02:20 PM   #1
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
Default my tips on installing hitch for the B9
well i worked for uhaul so mine is a uhaul brand, my brother who works at a suby dealer said the OEM one, you have to trim the bumper. my guess is the only difference is the height that it drops down for the receiver.
my instructions looked like the printer ran out of ink, so i didnt get the best views on everything.
tip 1:
realize this is harder than a normal hitch to put on. there are tight areas so have someone with small hands handy.
tip 2:
make sure you drill the outer acess holes... stupid me drilled the inside ones first...
tip 3:
you might want to take off the bumper for drill out the 1 1/2" acess hole, i couldnt get my drill in there enough to ream it out to the right size with it on.
these are in no way a *problem* just some time savers.
other than that, its a simple as putting one on your rex.
took about 1 hour to install.
wiring for this should be simple. you would just need part number 13486 from uhaul. this is a 3 wire system car, so you need the converter box. wireing should take you 15-30 min.
David Medina is offline   Reply With Quote
Old 11-14-2005, 05:34 PM   #2
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
W/o a tranny cooler, you can't tow much weight with this hitch, right?
Foxbat is offline   Reply With Quote
Old 11-14-2005, 11:16 PM   #3
David Medina
Member#: 37721
2003 WRX sedan
pearl blue
only like 2,000 lbs i beleive.
tranny cooler takes about 15 min to install.
cost around $80.
Any tips on installing my JDM rainguards? wrxSTIcy Interior & Exterior Modification 9 02-05-2010 01:48 PM
Any Tips on how to tighten the rear endlinks on the XT and STi? BrysImpreza Brakes, Steering & Suspension 4 03-10-2004 03:38 PM
Any good place to install Hitch? for how much? dingaling Bay Area Impreza Club Forum -- BAIC 1 08-18-2002 02:17 AM
tips on installing a fuel pressure gauge? IMPBOY Normally Aspirated Powertrain 3 12-22-2000 05:05 AM
Anti lift kit delivered. Any tips on install? Evil-Mastermind Brakes, Steering & Suspension 9 12-04-2000 07:09 PM
