Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-14-2005, 04:43 PM   #1
ryan_lobo
Member#: 13437
2001 Forester
Sierra Gold
Question Valve cover gasket
Hi,
Im about to change my valve cover gasket and spark plug tube seals on my 01 forester, anything I should know before going in, anyone have instructions on how to proceed ?
Thanks,
Ryan
ryan_lobo is offline   Reply With Quote
Old 11-14-2005, 05:43 PM   #2
Hayes
Member#: 11808
I just did mine and no problems. Be aware that you need very little tighting force on the bolts (3.7 ft lbs I believe). One cover has a bolt on the end of the cover and one does not. There is a sequence to tighten the bolts and can't remember where I found it. www.endwrench.com has lots of info.
Hayes is offline   Reply With Quote
Old 11-14-2005, 09:45 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
10 mm Gearwrench. You will love it.
Take your time. It's pretty easy. And as hayes said, do not overtighten. One tip I would suggest is when you are re-installing the bolts, get them all started before you tighten one.
Oh ya, be prepared to clean up some oil. You'll be surprised at how much comes out.
Tim Sanderson is offline   Reply With Quote
Old 11-15-2005, 01:13 PM   #4
ryan_lobo
Member#: 13437
2001 Forester
Sierra Gold
Default THanks for the tips
Thanks for the replies, I tried getting info on the website but could not come accross anything on the valve covers. ALso Im assuming you have to drain the engine oil before
proceeding. is there a torque spec for the tightening or do I do it by feel ?
Are the valve gaskets for the 01 forester the same for the left and right sides ?
How many rubber washers do I need ?
THanks,
Ryan
Old 11-15-2005, 02:47 PM   #5
Hayes
Member#: 11808
You DO NOT need to drain the engine oil. You will need two valve cover gaskets, four spark plug O-Rings, 10 Cover bolt seals(rubber washers). Remove the air intake plumbing up to the air cleaner box and the washer fluid container for working room. You will also want a container to allow about 50 cc of oil to fall as you remove each cover ie I used an oil drain pan. Not a difficalt job at all. Just don't get in a big hurry and clean everthing before reinstalling. I think it took me about 1 & 1/2 hours including a smoke break and several stadups to straighten my old back. I believe the torque spec is 3.7 foot pounds which I did by feel with a 6 inch 1/4 ratchet. Cheers. Eddie
Old 11-15-2005, 02:48 PM   #6
Hayes
Member#: 11808
You DO NOT need to drain the engine oil. You will need two valve cover gaskets, four spark plug O-Rings, 10 Cover bolt seals(rubber washers). Remove the air intake plumbing up to the air cleaner box and the washer fluid container for working room. You will also want a container to allow about 50 cc of oil to fall as you remove each cover ie I used an oil drain pan. Not a difficalt job at all. Just don't get in a big hurry and clean everthing before reinstalling. I think it took me about 1 & 1/2 hours including a smoke break and several stand-ups to straighten my old back. I believe the torque spec is 3.7 foot pounds which I did by feel with a 6 inch 1/4 ratchet. Cheers. Eddie
Old 11-16-2005, 04:42 PM   #7
ryan_lobo
Member#: 13437
2001 Forester
Sierra Gold
thanks hayes, very helpful.
Im confident of fixing it this weekend
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 02:13 AM
valve cover gaskets... whos done it? bjsid Normally Aspirated Powertrain 5 09-07-2003 10:13 PM
where to find 94 wrx valve cover gaskets!?!? czo79 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-28-2003 11:25 PM
2 things here. cooling fans/ valve cover gaskets solarsvx South East Region Forum 1 01-21-2003 03:27 PM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 09:50 PM
