Old 11-14-2005, 05:15 PM   #1
donut_boi
Member#: 98007
2003 WRX
Default Overfilling Transmissiom Fluid
I was just wondering, since I think I overfield my Tranny a little more than .5 quart when I changed it. Is there any downfall if I was to keep it that way or should I drain it?
Thanks,
John
donut_boi is offline   Reply With Quote
Old 11-14-2005, 05:46 PM   #2
donut_boi
Member#: 98007
2003 WRX
I think I might have found the answer, but any other thoughts are welcome.
Thanks
John
Old 11-14-2005, 06:20 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
You don't want to overfill your gear oil. All that extra oil makes the transmission work harder, puts more stress on the syncros, etc..
Go to an AutoZone/Advanced Auto Parts/etc., get yourself a transfer pump (~$10), slip the "IN" hose into the transmission fill tube, and pump out the extra gear oil into a container.
Re-check fluid level.
If you took out too much, add some back, a little at a time until you get the right level.
Samurai Jack is offline   Reply With Quote
Old 11-15-2005, 12:55 PM   #4
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
You can pump it out through the fill hole as Jack mentions. I would just for piece of mind.
singletrack is offline   Reply With Quote
Old 11-15-2005, 01:21 PM   #5
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Too much leads to foaming, and less protection.
I've found that re-filling with about .5 quart less than total capacity shows as "full" on the dipstick. Either the capacity is wrong, or more likely, not all the gear oil drains out. When I overfilled mine, I just put the gloves back on, and unscrewed the drain plug and let the new fluid drain into a new oil pan. Then I added more slowly the second time. I've also found it helps a LOT to do this chore in warm weather or a heated garage. The stuff is so thick at cool temps that it takes forever to pour...
Stanley is offline   Reply With Quote
Old 11-16-2005, 02:55 AM   #6
Tabolt
Member#: 99006
^^ and forever to slide down the fill tube so you can get an accurate dipstick reading. in a garage @ ~40degF i had to wait around fifteen minutes (every single time) before i could get a good reading to determine whether i needed more or not.
Tabolt is offline   Reply With Quote
Old 11-16-2005, 03:49 AM   #7
Seranin
Member#: 54409
2006 Forester
so what's the proper time to wait before checking trans oil? or is this a RTFM deal ... edit- for an '04 STI, i guess i should specify, if it matters
Seranin is offline   Reply With Quote
Old 11-19-2005, 02:22 PM   #8
donut_boi
Member#: 98007
2003 WRX
Thanks for all the help and replies guys. Anyways I pumped some out and got it to the level I wanted. All is well, Thanks.
Old 11-19-2005, 05:27 PM   #9
cwarcup
Member#: 96797
Darn thread moved too quickly.
cwarcup is offline   Reply With Quote
Old 02-22-2006, 10:47 AM   #10
wrxracer87
Member#: 105715
2004 psm
WRX
What is the Tranny oil capacity for an 02 wrx manual... I am pretty sure i overfilled mine to because i didn't wait long enough before i checked it. Now shifting particularly into and outof 1st and 2nd feels really rough at least untill the car warms up. So i am just going to redo it and want to know the correct amount so i don't screw up again.
wrxracer87 is offline   Reply With Quote
Old 02-23-2006, 10:41 AM   #11
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
Fill it until the dipstick reads full. Start with about 3 quarts and then add in small increments until it reads at the proper level. Also, what fluid did you use? That can have a big influence on how the transmission "feels" after a change.
-Bryce
Carnot is offline   Reply With Quote
Overfilling Transmission Fluid in 6MT - Bad? silentt Transmission (AT/MT) & Driveline 3 10-17-2008 11:16 AM
Overfilled tranny fluid - will cause harder shifting? Hank3 Transmission (AT/MT) & Driveline 13 09-08-2007 12:31 AM
Effect of overfilling AT tranny fluid? garface Transmission (AT/MT) & Driveline 4 10-14-2004 06:52 PM
H6 automatic transmission fluid not 9.8 US QT? Overfilled! Infymus Service & Maintenance 17 05-05-2004 12:52 PM
auto tranny fluid overfilled a little bit ok? inpreza kid Transmission (AT/MT) & Driveline 3 11-28-2001 09:31 AM
