Old 11-14-2005, 09:35 PM   #1
moby4dick
Member#: 51901
'04 WRX
Default Alky injection/safe power for 2.0?
Hey All,
All this talk of alky injection and higher power has got my mojo woikin...
I hear that it can increase your HP like 20-30%, for less than some fancy plumbing. So cool, but I'm just wondering if the stock block can handle a turbo upgrade plus the alky, which based on the HP increase, with the turbo I'm considering (DB Super 16g), would cause reliability issues with the block.
Or is it really just detonation that's the problem, and with a conservative tune I'll be okay?
MB
moby4dick is offline   Reply With Quote
Old 11-15-2005, 12:45 AM   #2
stu
Member#: 25768
35R bugeye
Slowbaru
you can use alky and you will make more power, but it will be safer power. I is just like using higher octane gas but cheaper in the long run. I have been using it for about a year and I never have knock issues. good luck.
Later Jeff
stu is offline   Reply With Quote
Old 11-15-2005, 06:03 AM   #3
garie
Member#: 26607
2002 wrx wagon
yes you should be fine.
garie is offline   Reply With Quote
Old 11-15-2005, 08:15 AM   #4
samwY
Member#: 31816
50/50 alky/water for performance
samwY is offline   Reply With Quote
Old 11-15-2005, 09:57 AM   #5
notraceready
Member#: 64556
2003 Stg 4 WRX sedan
I just had my car retuned (conservative) with alky/water mix (50/50) and the sr30 turbo. I'll post graphs later but I got 292 whp and 275 torque. I don't believe that was 20-30 % more whp but probably 20-25 more ponies. My tuner said he was able to lean out the a/f ratio due to the alky and push the boost to 20 psi and still keep it safe. Perhaps with straight alky or methanol you could expect more gains.
notraceready is offline   Reply With Quote
Old 11-15-2005, 10:11 AM   #6
lowblow
Member#: 56902
2009 VW Jetta SE
If anything it will help make the car last longer if tuned properly because the cylinders will experience lower temperatures while water and alky clean the inside of the engine.
lowblow is offline   Reply With Quote
Old 11-15-2005, 02:19 PM   #7
nuhga
Member#: 80770
2005 v7 spec-c
However, if your pump or whatever decides to fail wile WOT, you engine will be nuked.
I read engine will last no longer than 4 sec running that lean w/o alky.
but if you can live with that.. it's a great mod! tunning is everything tho im getting mine tuned this saturday! bigger your turbo is, you will gain more.. because you are basically getting power from more boost/timing/afr not from alky itself.
nuhga is offline   Reply With Quote
Old 11-15-2005, 06:14 PM   #8
Rickyh
Member#: 40453
I use 1 gallon denatured alky 2 gallons of water. I can hammer on the car all day long and it doesn't knock. My turbo(vf39) is going south, but the engine is fine. I guess 20 psi on that turbo wasn't a good idea
Rickyh is offline   Reply With Quote
Old 11-15-2005, 06:41 PM   #9
03blackwrx
Member#: 93651
2003 400+whp BUGEYE
i have a stage 4 wrx, with a vf 34 turbo, before the alky i made 276 whp with 270wtq, now i make 297whp and 305 wtq, now tell me thats not worth the money, i can post the dyno comparrison in a couple hours when i am home
03blackwrx is offline   Reply With Quote
Old 11-15-2005, 08:05 PM   #10
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
So how much do you guys spend per tank of gass on the alky?
HerculesPeanut is offline   Reply With Quote
Old 11-15-2005, 08:25 PM   #11
Rickyh
Member#: 40453
I spend 10 bux on a gallon of alky, and mix it with 2 gallons of water. I have a 3 gallon fuel cell in the trunk. 3 gallons lasts about 2-3 months.
Old 11-15-2005, 08:36 PM   #12
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
So what set-up are you using and how many miles do you drive?
Old 11-15-2005, 08:40 PM   #13
TJRCS
Member#: 59199
2008 STI
That's exactly wat i'm planning to do. (If i don't get STi and STUCK with WRX) Please post up DYNO and full mods. Thanx
TJRCS is offline   Reply With Quote
Old 11-15-2005, 09:01 PM   #14
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
I buy sunoco methanol at 5 gallons for 30 bux. I mix about 40meth/60 water. I gained 30Hp, and 30ft lbs of tq on XXtuning's Dynapack, but I am using my smallest nozzle. My tuner, told me he went to the next size up on his car and it made a bigger difference. I am using a 175cc nozzle right now, and am going up to 325 IIRC, I have to check. Anyway. the bigger nozzle should let me easily go over 300 HP/300Tq. Here is my plot.
The lower lines were the baseline pull without WI, and the top lines are the gain that day with tuning.
I also found out later that day that my supply line from the pump to the intercooler had a crack in it and was leaking, so I tuned with a lower pressure getting to the nozzle. Without the crack, I probably could have squeezed more out. So when I get retuned I expect over 300 at the wheels on both figures.
Here is AFR/Boost:
Check out this forum, good info there.
http://www.waterinjection.info/phpBB2/
But the gains are worth it, and real. I spent aboot $400 for the kit, and another $150 for tuning, and made those gains with a less than optimum injection pressure.
Here is the setup:
VF-22 at 22 lbs (I can vary using a turbosmart in cabin MBC) I use this for peak boost adjustment.
MRT TMIC
HKS downpipe with garage mod wastegate divorce pipe
TurboXS UP
UTEC
Ceramic coat stock exhaust mani
stromung catback
Perrin short ram
NGK double platnums gapped at .026
Snow Performance WI stg 2 kit with 175 nozzle (going to 325 though), set to spray partial at 9lbs, and 14 lbs full (snow uses a dual pressure controller to kick the pump on paritally at the lower pressure and turns it on fully at the higher pressure. That way you don't quench the spark/flame kernel under low engine load.) The pump pushes 100PSI+
DP
EDIT:
Of note the baseline dyno lines are low on a VF-22 because my tune was really rich because of a injector leak the day I got my original stg 4 tune. My tuner had to add a lot of fuel to keep from misfiring, and we didn't know we had a leak, until I found it a few days later. So once the leak was fixed, the car was really rich.
Also, here is a good source for meth:
http://highfuelsn.goemerchant7.com/index.cgi?PageToView=catalog&Department=81051&Cart id=283401067729423&Merchant=highfuelsn&ExpandedDep ts=81113|81050
Or if in New England,
DP
DonkeyPunch is offline   Reply With Quote
Old 11-15-2005, 10:44 PM   #15
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
I have been running W.I. for a while now and it definitely helps out a lot. I recently switched back to 100% water, seeing as it actually removes more heat than the alcohol. I do not need the fuel properties of the alky, I have plenty of fuel already with modded stockers. Anyhow, I am able to run 20psi at 12:1 afr and it does not knock at all. I had a plug issue which caused knock in the past but since switching to proper plugs, I have not had ONE single knock event running like mentioned above. Btw, I am running a super16G style turbo that flows somewhat like an 18g, its a hybrid but anyways you should be fine with a big16G, 20psi and water/alky injection. It is a good way to make a solid 300whp if that is the direction you want to go.
I have a 1gph nozzle come on at 7psi and a second 1gph nozzle come on at 14psi. It equates to between 10-15% mix, which is a good ratio. 20% is about the max you want to run and no less than around 5 for the minimum. My windshield washer tank full of water has lasted me around 5 tanks of gas and its still like 40% full. Back when I was spraying a considerable amount more I would go through a tank per tank of gas but now its like it will never run out. When I wasnt running pure water I was running 50/50 isopropyl rubbing alcohol and water, which worked well but I just didnt need the alky in there.
Jeff
Last edited by NavyBlueSubaru; 11-16-2005 at 10:01 AM. Reason: wrong w.i. nozzle size...both are 1gph, not 1 then 2
NavyBlueSubaru is offline   Reply With Quote
Old 11-16-2005, 12:04 AM   #16
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
what kits are u guys running, because i dont knwo which kit is good for me ; (
Thran is offline   Reply With Quote
Old 11-16-2005, 12:08 AM   #17
line
Member#: 76189
WRX: Parking Lot
Racer in Training
I have a quick question for you alky guys, you talk about switching from a 50/50 mix to a straight water mix, does this involve tuning? Iím sure the best results would involve tuning but is it safe to get tuned for straight water then add some alky?
line is offline   Reply With Quote
Old 11-16-2005, 12:21 AM   #18
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Tuning is required. If you are running 50/50, you need to account for the extra fuel via alcohol when tuning. If you are running strait water then your A/F ratios will not be affected by the water you are injecting. If you are tuned with a 50/50 and switch over to strait water, you will be running leaner with the same tune. I would not suggest you do any W.I. tuning without a WB02 at a minimum.
Jeff
Old 11-16-2005, 08:41 AM   #19
lowblow
Member#: 56902
2009 VW Jetta SE
I am getting the SMC kit...some people have had luck with the Alky Control and CoolingMist kits.
Like Navy stated...tuning is required if switching between mixes of alky and water because one of the main points of alky injection is to reduce the amount of gas injected while using the higher octane of methanol as a fuel source yso you can run more boost, timing and lower IDCs.
So if you get a tune for straight alcohol and then change it to a 50/50 mix, you will be lacking in the octane available for combustion, causing the engine to be prone to knock while running more timing advance and higher boost levels.
Old 11-16-2005, 10:25 AM   #20
nuhga
Member#: 80770
2005 v7 spec-c
snow performance
Old 11-16-2005, 11:45 AM   #21
line
Member#: 76189
WRX: Parking Lot
Racer in Training
The reason I was asking is because I was thinking of running straight water and adding some alky in the winter to keep it from freezing.
Do you guys just turn it off in the winter or do you make sure to run an alky mix?
Old 11-16-2005, 05:36 PM   #22
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Run alky or it will freeze. Check this out.
http://www.ashchem.com/adc/chemicals...=3&is_header=N
Old 11-16-2005, 05:55 PM   #23
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Yea thats a good point. Im in florida where it rarely drops below 80f.
Old 11-16-2005, 07:50 PM   #24
HerculesPeanut
Member#: 35421
2003 WRX
W R Blue
yeah, 83 today in north florida.
Old 11-16-2005, 10:52 PM   #25
Rickyh
Member#: 40453
south louisiana. Hell it was 80 degrees yesterday.
I've been rockin the coolingmist setup for a while.
Blown Motor... heads indicate Alky injection was only entering 2 cylinders... TROLL Water/Methanol Injection, Nitrous & Intercooler Cooling 76 06-04-2010 02:28 AM
2 Utecs one for 2.0 wrx one for STi turboedracer NWIC Private Classifieds 0 01-04-2009 04:17 AM
Dissapointed in power from 2.0 kirkeemonster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 107 02-28-2007 12:52 PM
2.5 Legacy Engine Swap for 2.0 Legacy brakemans Normally Aspirated with bolt-on Forced Induction Powertrain 2 08-20-2002 11:47 PM
What has more NA power? the 2.0 or the 2.5? STiWRXdotcom Normally Aspirated Powertrain 34 06-08-2002 01:17 PM
