Welcome to the North American Subaru Impreza Owners Club Thursday August 21, 2014
Old 11-14-2005, 10:48 PM   #1
v_dubs37
Member#: 73288
2002 2.5 RS
Dark Blue
Default Recommened Any Gear Lube?
I got to replace my gear tube, and i don't know what to buy. I've heard go things about redline lightweight, but isn't that for more extreme applications. I'm only sporting a 02 RS, but have a turbo setup coming up in January. So i might as well add some heavy stuff or just wait untill I install the turbo. Any opions?
Thanks
v_dubs37 is offline   Reply With Quote
Old 11-15-2005, 12:38 AM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Thanks
gear tube?
People seems to be happy with redline.
z is offline   Reply With Quote
Old 11-15-2005, 04:54 AM   #3
02redwagone
Member#: 87067
02 Old but tasty
SRP
Mobil works fine too. (for me)
02redwagone is offline   Reply With Quote
Old 11-15-2005, 08:34 AM   #4
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
There are literally hundreds of of thread on this. I've been reading them for a few weeks and concluded that everybody likes something different. If you're up for a scavenger hunt, try Uncle Scotty's Cocktail (search for ingredients). That seems to be a mix that many agree on.
I have no griding issues and no more serious racing than a few auto-x and an odd TSD, so I see no need to drop ~$50+ in fluids. I'm going to go with NAPA (Valvoline) 80w-90 in the gearbox ($2.79/L) & probably Valvoline Synthetic in the rear diff (~$9/L).
LordBass is offline   Reply With Quote
Old 11-15-2005, 12:33 PM   #5
edjack
Member#: 99470
1998 Legacy Outback
Default GL-5 Only
Whatever you use, make sure it's GL-5 rated, for both manual transaxle and rear diff.
Don't use hypoid lube in transaxle, it'll eat up the synchro rings.
edjack is offline   Reply With Quote
Old 11-15-2005, 07:05 PM   #6
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Here we go again.....
Gear lubes that describe themselves as "Hypoid" lubes are really just EP rated oils (since hypoid gears subject the lubricant to extreme pressures - moreso than other types of gears). By definition, the GL-5 gear oil specified by Subaru is EP rated and thus contains EP additives. Since Subaru specifies GL-5 oil for the transmission, it is safe to assume that they designed the synchros to withstand the EP additives. Furthermore, EP additives do not usually attack yellow metals until the oil temperature reaches about 240 F. While I have not actually measured the oil temperature in my WRX transmission, it should be significantly lower than this.
jac04 is offline   Reply With Quote
Old 11-15-2005, 09:38 PM   #7
edjack
Member#: 99470
1998 Legacy Outback
Dino gear lubes need corrosive agents to bond with the hypoid gears, since they mesh so tightly that they squeeze out the lube. The agent actually etches poclets in the faces of the gears, and the lube can then find a place to lubricate the gears.
True synthetic gear lube (e.g., RedLine) is able to withstand this squishing, and does not need corrosive agents. But, you still need to heed the requirement for GL-5 rated lube in trans and diff.
Old 11-15-2005, 10:43 PM   #8
v_dubs37
Member#: 73288
2002 2.5 RS
Dark Blue
well now what do you guys recommened for the front diff, and the rear diff? Cause my rs has 70k on it, and from what i know the diffs have never been changed either.
Thanks
Old 11-15-2005, 11:10 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I've been running Motul Gear 300 in both the trans and rear diff with good results - it's a decent ester based synthetic, so it's more stable than the pao based ones like Mobil.
DrD is online now   Reply With Quote
Old 11-15-2005, 11:55 PM   #10
z
Member#: 41762
04 STi
Thanks
front Diff Shares with the trans. I used Castrol Hypoid-C 80w90 in the rear with no issues. Just make sure it's meant for a limited slip diff.
Old 11-16-2005, 07:21 AM   #11
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
that only matters with the STi - for regular WRX's or the 2.5RS, the limited slip unit is sealed, so you can use pretty much whatever gl5 rated oil you want.
Old 11-16-2005, 07:56 AM   #12
jac04
Member#: 49895
09 Forester
Originally Posted by DrD
....for regular WRX's or the 2.5RS, the limited slip unit is sealed, so you can use pretty much whatever gl5 rated oil you want.
My experience is that using an oil with Limited Slip additives in the WRX transmission will lead to gear grinding - the synchros don't like LS additives. Mobil engineering has also confirmed this. So, try to find an oil without LS additives for the WRX/RS transmissions.
Old 11-16-2005, 12:49 PM   #13
z
Member#: 41762
04 STi
Actually, I was referring specifically to the rear diff when I mentioned gear oil for LSD.
and DrD, don't you still have to use a gear oil meant for LSD even though it's not a mechanical LSD like the STi? That's what I thought at least.
Old 11-16-2005, 04:53 PM   #14
jac04
Member#: 49895
09 Forester
...don't you still have to use a gear oil meant for LSD even though it's not a mechanical LSD like the STi? That's what I thought at least.
As DrD stated - on the WRX/RS it is a sealed viscous limited slip unit, so it is not affected by the type of oil used.
Old 11-16-2005, 04:58 PM   #15
shemoves
Member#: 80663
1997 Outback
How often should tranny/diff fluids be changed on cars that are auto-x/tracked 4-5 times a year vs. just driven normal?
shemoves is offline   Reply With Quote
recommened any bolt ons for the aftermarket turbo? v_dubs37 Normally Aspirated with bolt-on Forced Induction Powertrain 9 12-16-2004 09:32 AM
Gear lube changing advice cd3575 Mid West Subaru Owners Club Forum -- MWSOC 3 02-22-2002 11:18 AM
How many quarts of gear lube do I need? LehighWRX Service & Maintenance 4 02-13-2002 09:54 AM
Free Redline gear lube SuperRuWRX South East Region Forum 4 02-10-2002 05:35 AM
