Welcome to the North American Subaru Impreza Owners Club Tuesday August 23, 2016
Old 11-14-2005, 11:50 PM   #1
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Default bolt sizes for Subaru?
Anyone know of a list of the botl sizes for the Forester, I just need the size to remove the headlights.
looks something like a 13mm socket would fit.
SubaruImpreza_power is offline   Reply With Quote
Old 11-15-2005, 12:14 AM   #2
Tricky [RCAF]
Member#: 50183
1999 06 WRX, 99 Swap
CGM & BDP (Matte white)
FYI, the bolts for my RS' headlights were 10mm.
Tricky [RCAF] is offline   Reply With Quote
Old 11-15-2005, 01:05 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....d000d......if it is a stock body/chassis Subaru bolt, it is either 8mm, 10mm, 12mm, 14,mm, 17mm, 19mm.....there are some 21mm 22mm and a few larger ones(like the axle bolts...31mm, IIRC)...and a few smaller......but the VAST majority are 10mm, 12mm, 14mm, 17mm and 19mm.
There are NO 'odd' sizes......NO 11's...NO 13's....NO 15's....NO 16's....etc....JUST the ones listed above.
Bolt size for bolt on exh mani heat shields? djoye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-08-2007 01:24 PM
What is the bolt size for bracket for exhaust? junnel20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-15-2004 05:06 PM
bolt size for mounting V5/6 wing Pikeadon Interior & Exterior Modification 0 08-10-2002 05:47 PM
bolt size for rotor removal MikeWRX Brakes, Steering & Suspension 4 03-26-2002 06:21 AM
Bolt size for airbox? blaster88 General Forum Archive 3 02-13-2001 03:49 PM
