Old 11-15-2005, 06:09 PM   #1
Red Rexx
Member#: 67187
2004 STi
Default Can I get away with just the Stage 2 Map with these mods or is a Protune necessary?
Heyy...I am at Stage 2 for my 2004 WRX. I have all the acceptable bolt on's for the map accept for: CAI, headers, and larger TMIC.
Do I need to upgrade to a protune in order to utilize all 3 of those mod's full hp potential or gain I just install them and see nice gains?
CAI - I know you need a protune because the map will not support it.
Headers - ??? (Is a protune necessary to gain its full hp potential?)
Larger TMIC - ??? (Is a protune necessary to gain its full hp potential?)
Thank you!
Red Rexx is offline   Reply With Quote
Old 11-15-2005, 06:18 PM   #2
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
you can run stage 2. But a protune would be better. A custom tune is always better... depending on who tunes it. In order to fully utilize your other boltons, you need a custom protune.
darksands is offline   Reply With Quote
Old 11-15-2005, 06:49 PM   #3
Red Rexx
Member#: 67187
2004 STi
I dont think I want to spend hundreds of $$$ on a custom tune. I know you need a custom tune for a CAI, so that it out of the question.
How about headers and a larger TMIC though? Would I see decent gains by just throwing them on and resetting the ECU or would I need a custom tune for full power for both?
Old 11-15-2005, 06:59 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If you want to get the best potential out of your upgrades (headers, big TMIC, etc.), you are going to need a custom tune.
Better start saving now!
Samurai Jack is offline   Reply With Quote
Old 11-15-2005, 07:08 PM   #5
23b_Rex
Member#: 79394
02 gda
wrb
get st
23b_Rex is offline   Reply With Quote
Old 11-15-2005, 07:20 PM   #6
richde
Member#: 79498
2013 XV
Thank you!
Lemme get this straight, you want to spend $1000-1500 on parts but that extra 200-300 for a tune would be just too much? How about skip the CAI since it's a waste and get some REAL gains with a real tune?
richde is offline   Reply With Quote
Old 11-15-2005, 07:44 PM   #7
Red Rexx
Member#: 67187
2004 STi
Thanks I understand what you guys are saying. All I want to know is if I will get gains by just bolting on headers or the TMIC or will I need a tune to feel them.
I have heard that you will not feel gains without a tune with headers. Is that true? How about with the TMIC?
Old 11-15-2005, 08:02 PM   #8
richde
Member#: 79498
2013 XV
BTW, if you just got a protune with your current setup you'd probably see more gains than these parts. The CAI and IC won't do much of anything for a stock turbo, the headers might give you a few hp up top at the cost of a few down low.
Old 11-15-2005, 08:23 PM   #9
Bman
Member#: 64351
2005 Legacy GT
You will not get gains from the TMIC unless you get tuned for it. Headers are very controversial anyway, its up to you if you want to spend the money on them. I would put that money towards your tune. Also with stock turbo there is no need for a CAI
Bman is offline   Reply With Quote
Old 11-15-2005, 09:43 PM   #10
Red Rexx
Member#: 67187
2004 STi
Thats what ive been learning through my research.
Anyone else?
Old 11-15-2005, 10:11 PM   #11
beast
Member#: 95242
i had my sliver 2005 wrx with headers short ram intake cat back exhaust uppipe down pipe an it was fast as **** with headers top end pulled so much harder you could easily tell the difference without all on stage 2 cobb if you want to spend the money on a protune i would first upgrade to 34 turbo sti pink injectors walbro fuel pump and maybe front mount but with a frount mount youll have tremedous lag which sucks on a 2.0 injen and really worth it unless your shooting into green turbo rage which is around 350whp were your car is very close to overheating with any top mount because of its position over the motor and since stock internals are not the greatest it is always safe to keep ypur injen as cool as possible which will help from going kaboom or melting internals from heat
beast is offline   Reply With Quote
Old 11-15-2005, 10:28 PM   #12
Red Rexx
Member#: 67187
2004 STi
Interesting...Protune is sounding promising...
Old 11-15-2005, 10:48 PM   #13
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
Is it really that hard to hit the period key?
J-Rex2004 is offline   Reply With Quote
Old 11-16-2005, 12:11 AM   #14
subeesteve25
Guest
Member#:
^^^^^^^ No S--t, lmao. I didn't know first graders drove WRX's.
Cobb Stage 2 map with these parts? WRBlueberry Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-29-2010 07:07 AM
Cobb AP 1 - stage 2 map with my mods? Ultimateone AccessPort 3 12-09-2007 01:56 PM
Can a SPT intake cause issues with an OTS stage 2 map? "B" Engine Management & Tuning 1 05-02-2007 11:43 PM
who is running stage 2 map with aftermarket headers? Mr. SUAVE AccessPort 4 06-07-2006 09:59 PM
Is it safe to use no muffler with a Cobb Stage 2 Map? caterpill Engine Management & Tuning 5 01-24-2006 03:27 AM
