Old 11-15-2005, 06:48 PM   #1
keaniegenie
Member#: 94494
2005 Element 92x
Default What is the difference between a standard STI shortblock and a Crawford S2 shortblock
When I visit Crawford Performance's website, the only distinguishing difference between a standard STI shortblock and the S2 is the pistons. Is this right?
I'm looking to buy a 2.5l block, and a reconditioned S2 block is $1750. That's about the same as a new STI block.
New S2 blocks are $2250, the difference between a STI block and an S2 is about $500. Basically the cost of pistons. Is this right?
keaniegenie is offline   Reply With Quote
Old 11-15-2005, 07:06 PM   #2
burnin4
Member#: 59764
10 sec STi
10 sec Z06
i think the only diff between a stock STi block and crawfords S2 is forged pistons. Hope that helps!
burnin4 is offline   Reply With Quote
Old 11-15-2005, 07:16 PM   #3
WSSBOARD18
Member#: 47964
2003 WRX
WHITE
The difference is forged pistons and they change the compression if you want to use the block with stock wrx heads.
WSSBOARD18 is offline   Reply With Quote
Old 11-15-2005, 09:58 PM   #4
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
The S2 can actually be made to your desired Compression Ratio (with-in reason). This is done by designing and manufacturing proper pistons, not by changing the thickness of the head gaskets.
Chris
I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 11-16-2005, 04:05 PM   #5
keaniegenie
Member#: 94494
2005 Element 92x
Chris
I-Speed USA
Basically they make custom forged pistons based on your compression goals, correct? Or are there 2-3 sets of pistons that you choose from.
Old 11-16-2005, 06:04 PM   #6
the_colombian
Member#: 84912
2003 2.5L bugeye now
with 6 spd 20g!
Chris
I-Speed USA
wish I would have known this.
the_colombian is offline   Reply With Quote
What is the difference between the Greddy EVO 2 for the STI and the one for the WRX? Moshpit552 General Community 6 10-27-2005 01:08 PM
What is the difference between a a GC8, GF8 and a GM6? Louros Newbies & FAQs 19 11-01-2004 10:38 PM
what is the difference between a STI and WRX down-pipe junyah Newbies & FAQs 8 08-10-2004 10:21 AM
What is the difference between an STi ver.5 and STi ver.6 exhaust? Robmat Normally Aspirated Powertrain 6 06-25-2001 12:48 PM
